I did a post a time ago asking for tips on a clean install:
So, after more than 4 years using Manjaro I’m gonna do a clean install and I’m looking for any advice or tips since many things must have changed since all those years.
I know for example I must have base-devel package installed if I wanna use AUR,
meld to use pacdiff, Install-grub to detect updates on the grub package…
I don’t know if I have to install codecs like some other distros (don’t remember doing that last time),
I have to do something regarding screen tearing (a friend helped me wi…
But because of work I had to install Windows 10 and so I did, but I was missing Linux and Manjaro so I used the Windows disk manager and shrinked the volume 128GB…
With that I experimented Manjaro KDE but both on Wayland and X11 session the things were bugged and didn’t render correctly so I come back to XFCE!
The installation went well, I choosed ext4 instead of BTRFS but the installer didn’t create a swap partition/file, but that’s ok since I wanna enable ZRAM… so my question is how i do that?
Also wanna install i3 WM, can you guys tell me what packages I must install so I can have a complete and confortable experience with i3?
Install and Configure ZRAM using zram-generator
Note that zram is not compatible with hibernation unless combined with a swap device.
If you are here just to have a quick install method you may skip to this section .
Install zram-generator
Execute:
sudo pacman -Syu zram-generator
Configure zram-generator
Create file /etc/systemd/zram-generator.conf with contents:
[zram0]
zram-size = ram * 2
compression-algorithm = zstd
swap-priority = 100
fs-ty…
manjaro-i3-settings
will make it comfortable, but you cannot use 2 different settings packages at a time.
Thank you for the tips, btw I forgot the system info, here:
Kernel: 6.12.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=6fd80dcf-95d4-4d94-9d4b-4bf32ffdc9bc rw quiet splash apparmor=1
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: Hewlett-Packard product: HP Pavilion 15 Notebook PC
v: 0975110000405F00000620180 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 2269 v: 73.41 serial: <superuser required>
part-nu: K1V95EA#AB9 uuid: <superuser required> UEFI: American Megatrends
v: F.43 date: 08/19/2015
System RAM: total: 4 GiB available: 3.27 GiB used: 2.06 GiB (63.1%)
Array-1: capacity: 4 GiB slots: 2 modules: 1 EC: None
max-module-size: 4 GiB note: est.
Device-1: Bottom-Slot 1 (left) type: no module installed
Device-2: Bottom-Slot 2 (right) type: DDR3 detail: synchronous unbuffered
(unregistered) size: 4 GiB speed: 1600 MT/s volts: curr: 2 min: 1.35
max: 2 width (bits): data: 64 total: 64 manufacturer: Hynix
part-no: HMT451S6BFR8A-PB serial: <filter>
Info: model: AMD A8-6410 APU with AMD Radeon R5 Graphics bits: 64 type: MCP
arch: Puma level: v2 built: 2014-15 process: GF 28nm family: 0x16 (22)
model-id: 0x30 (48) stepping: 1 microcode: 0x7030105
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: <unsupported> cache:
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 1x2 MiB
Speed (MHz): avg: 998 min/max: 1000/2000 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 998 2: 998 3: 998 4: 998
bogomips: 15979
Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avx bmi1
bpext clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8
de decodeassists extapic extd_apicid f16c flushbyasid fpu fxsr fxsr_opt
ht hw_pstate ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor
movbe msr mtrr nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae
pat pausefilter pclmulqdq pdpe1gb perfctr_llc perfctr_nb pfthreshold pge
pni popcnt pse pse36 ptsc rdtscp rep_good sep skinit ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 svm svm_lock syscall topoext tsc tsc_scale vme vmmcall
wdt xsave xsaveopt
Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
Device-1: Advanced Micro Devices [AMD/ATI] Mullins [Radeon R4/R5 Graphics]
vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu
arch: GCN-2 code: Sea Islands process: GF/TSMC 16-28nm built: 2013-17
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:01.0 chip-ID: 1002:9851
class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Topaz XT [Radeon R7 M260/M265
/ M340/M360 M440/M445 530/535 620/625 Mobile] vendor: Hewlett-Packard
driver: amdgpu v: kernel arch: GCN-3 code: Volcanic Islands
process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 1002:6900
class-ID: 0380 temp: 36.0 C
Device-3: Chicony HP Truevision HD camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 4-1.2:3
chip-ID: 04f2:b40e class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.16 compositor: xfwm4 v: 4.20.0
driver: X: loaded: amdgpu,radeon unloaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: radeon display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 mapped: eDP model: Samsung 0x4951 built: 2013 res:
mode: 1366x768 hz: 60 scale: 100% (1) dpi: 101 gamma: 1.2 chroma: red:
x: 0.576 y: 0.333 green: x: 0.341 y: 0.561 blue: x: 0.161 y: 0.125 white:
x: 0.314 y: 0.329 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1366x768, 1280x720, 1152x768, 1024x768, 800x600,
848x480, 720x480, 640x480
EDID-Warnings: 1: parse_edid: unknown flag 2
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: KABINI (radeonsi ACO DRM 2.50
6.12.25-1-MANJARO) device-ID: 1002:9851 memory: 500 MiB unified: no
x11: xprop,xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Kabini HDMI/DP Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:01.1
chip-ID: 1002:9840 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] FCH Azalia vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d
class-ID: 0403
Device-3: Generalplus USB Audio Device
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 1b3f:2008 class-ID: 0300
API: ALSA v: k6.12.25-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:b723
class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: c000 bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 2.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.3:3 chip-ID: 0bda:b001
Local Storage: total: 465.76 GiB used: 39.77 GiB (8.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABF050
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 2C scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVDRW DU8A5SHL rev: ZH63
dev-links: cdrom
ID-1: / raw-size: 128 GiB size: 124.93 GiB (97.60%) used: 39.74 GiB (31.8%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 6fd80dcf-95d4-4d94-9d4b-4bf32ffdc9bc
used: 30 MiB (31.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 0A8C-A730
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 337.13 GiB fs: ntfs label: N/A
uuid: 7EC68FB3C68F69EB
ID-3: /dev/sda4 maj-min: 8:4 size: 532 MiB fs: ntfs label: N/A
uuid: 52E0B75BE0B743CF
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 1-1:2 info: Generalplus USB Audio Device type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
Device-2: 1-2:3 info: Sunplus Innovation GameMouse type: mouse,keyboard
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1bcf:08b8 class-ID: 0300
Hub-2: 2-0:1 info: super-speed hub ports: 2 rev: 3.0
Hub-3: 3-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 3-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
chip-ID: 0438:7900 class-ID: 0900
Device-1: 3-1.3:3 info: Realtek Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 2.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:b001 class-ID: e001 serial: <filter>
Hub-5: 4-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-6: 4-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
Device-1: 4-1.2:3 info: Chicony HP Truevision HD camera type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b40e class-ID: 0e02
System Temperatures: cpu: 47.1 C mobo: N/A
Fan Speeds (rpm): N/A
GPU: device: amdgpu temp: 39.0 C watts: 572.15 device: radeon temp: 40.0 C
Packages: 1473 pm: pacman pkgs: 1430 libs: 511 tools: pamac pm: flatpak
pkgs: 43
1: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
2: https://mirrors2.manjaro.org/stable/$repo/$arch
3: https://mirrors.manjaro.org/repo/stable/$repo/$arch
4: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
5: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
6: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
7: https://manjaro.kurdy.org/stable/$repo/$arch
8: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
9: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
10: https://mirror.init7.net/manjaro/stable/$repo/$arch
11: https://manjaro.ynh.ovh/stable/$repo/$arch
12: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
13: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
14: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
15: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
16: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
17: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
18: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
19: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
20: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
21: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
22: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
23: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
24: https://mirror.23m.com/manjaro/stable/$repo/$arch
25: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
26: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
27: https://mirror.easyname.at/manjaro/stable/$repo/$arch
28: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
29: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
30: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
31: https://mirror.koddos.net/manjaro/stable/$repo/$arch
32: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
33: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
34: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
35: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
36: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
37: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
38: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
39: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
40: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
41: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
42: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
43: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
44: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
45: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
46: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
47: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
48: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
49: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
50: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
51: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
52: http://manjaro.grena.ge/stable/$repo/$arch
53: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
54: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
55: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
56: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
57: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
58: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
59: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
60: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
61: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
62: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
63: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
64: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
65: http://mirror.fcix.net/manjaro/stable/$repo/$arch
66: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
67: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
68: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
69: https://muug.ca/mirror/manjaro/stable/$repo/$arch
70: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
71: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
72: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
73: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
74: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
75: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
76: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
77: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
78: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
79: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
80: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
81: https://mirror.dc.uz/manjaro/stable/$repo/$arch
82: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
83: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
84: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
85: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
86: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
87: http://manjaro.mirror.ac.za/stable/$repo/$arch
88: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
89: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
90: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
91: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
92: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
93: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
94: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
95: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
96: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
97: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
98: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
99: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
100: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
101: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
102: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
103: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
104: https://linorg.usp.br/manjaro/stable/$repo/$arch
105: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
106: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
107: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
108: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
109: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
110: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
111: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
112: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 247
1: cpu: 60.0% command: ps pid: 9282 mem: 3.73 MiB (0.1%)
2: cpu: 17.1% command: msedge pid: 8227 mem: 295.9 MiB (8.8%)
3: cpu: 13.9% command: msedge pid: 7776 mem: 194.1 MiB (5.8%)
4: cpu: 11.5% command: msedge pid: 7709 mem: 314.9 MiB (9.4%)
5: cpu: 8.7% command: xfce4-terminal pid: 9253 mem: 53.0 MiB (1.5%)
Memory top: 5 of 247
1: mem: 355.8 MiB (10.6%) command: exe pid: 7612 cpu: 8.2%
2: mem: 314.9 MiB (9.4%) command: msedge pid: 7709 cpu: 11.5%
3: mem: 295.9 MiB (8.8%) command: msedge pid: 8227 cpu: 17.1%
4: mem: 194.1 MiB (5.8%) command: msedge pid: 7776 cpu: 13.9%
5: mem: 158.0 MiB (4.7%) command: msedge pid: 7900 cpu: 1.2%
Processes: 247 Power: uptime: 1h 16m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 1.29 GiB services: upowerd,xfce4-power-manager
Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: xfce4-terminal
inxi: 3.3.38
BTW if I have screen tearing how I solve that?
I know that I have to edit a file in order to do it…
Thank you!
BTW do I need a swap file with ZRAM enabled since I only have 4GB RAM?
Ok and how is the procedure to creat a swap file?
I swear this is the last time I ask a question xD
Seriously, thank you so much for the help today!!!
Oh and I noticed that Install-grub
comes pre-installed now? Saw it during my first update…
The installer doesn’t create a swap
space automatically - the option is offered during install but you must actually choose the option that suits you.
There is a select (dropdown) where you choose the settings you need depending on whether you wish to use Hibernation.
I’m guessing you kept clicking Next and missed it.
Swap;
With only 4GB of RAM, I’d suggest swap
space of perhaps 12GB might be warranted; even more if you wish to hibernate the machine.
I would also prefer a swap
partition rather than a file, given the low resources, but that’s your choice.
Could not be easier:
Making sure you're not a bot!
Arch Wiki has bot protection - here is the link to the section in the Wiki in a different form
Any size you like - if you need a different size - just swapoff and create a new file …
The swap file created by the installer is too small anyway in almost any case.
(IMO)
The option to create swap partition/file appeared if I selected “Use all Disk” but disapeared when I choose the 128GB of space unalocatted that I created, so I just continued, I tought that maybe it created one automatically like some distros…
I didn’t miss it, because I choose carefully ext4
instead BTRFS
since this laptop no longer as a working battery and I heard BTRFS
doesn’t deal well with power failures that actually happens here time to time… last time lasted 10 hours xD
That’s why also I don’t update the BIOS in Windows because I’m afraid of a power failure during the process…
Usually double the RAM size right?
Does it make a difference using swap partition instead of a swap file?
I already have so many partitions xD
Ah, yes, I see. The better choice would have been to choose manual partitioning and you could have created a swap
partition to suit your needs - but, what’s done is done.
As much as you need - if you want to hibernate, at least the size of RAM.
That is what I have - I have 8 GB RAM and 8 GB swap as a swap file and never ran into problems,
You can err on the side of caution - or you can simply start with a lower value and if it is not enough - simply create a new, bigger one.
No, not performance wise - and it is more flexible than a partition - a swap file is easily created or adapted in size.
Ah I see, I should have created the swap partiton and the root partition in the unalocatted space manually, but I remember that the option “manual partitioning” also did not appeared like Joe Hendry…
Only option I had was to “erase/use all disk” and “select partition” (wich I did), I did think it was odd… maybe because I’m dual booting idk.
But the good thing is on Linux we find a way to solve issues, that’s why I like it so much and the reason I come back to Manjaro XFCE at a cost of some disk space because you never know when Windows gonna implode… God’s know that reseting Windows it’s not a good solution and restoration point is useless there…
Thank you so much for the help you guys, I’m gonna give a check mark on “Solved”, I have everything I need, already installed my things and tinkered a bit, I’m just go to procede with the info you guys gave me and when it’s all done just doing a snapshot on Timeshift just in case…
Enabled ZRAM I think (How I see if it is enabled?), created a swap file with 8GB and installed i3.
Didn’t noticed any screen tear this time, idk what changed in kernel or something else to not having it now…
You can use either of these commands:
swapon --show
or
cat /proc/swaps
I use zram
& this is the output of those commands on my machine:
swapon --show
NAME TYPE SIZE USED PRIO
/dev/zram0 partition 28.3G 25.4M 100
cat /proc/swaps
Filename Type Size Used Priority
/dev/zram0 partition 29682684 25976 100
Here’s mine output (something wrong?), I forgot and used sudo where’s no need:
swapon --show
/swapfile file 8G 0B -2
cat /proc/swaps
/swapfile file 8388604 0 -2
