the /etc/modprobe.d/ folder no longer works, I always use this folder to configure a module parameter, now this parameter does not change despite being set in a file inside this folder.
this is my file: /etc/modprobe.d/alsa-base.conf
# Disable snd-hda-intel power saving
options snd-hda-intel power_save=0 power_save_controller=N
when restarting I look for if the parameter changed in /sys/module/snd_hda_intel/parameters/power_save , and indeed it did not
It should be clarified that this worked in previous versions of manjaro
