File not found during Plymouth mkinitcpio build hook
Yesterday, 2023-12-20, I launched an update at night here in Europe of packages from the unstable branch. In the middle of the process they started giving errors and then I couldn’t start Linux.
I just formated the hard drive, I reinstalled Manjaro with the latest version available, and when updating the system to the unstable branch the same thing happens again and the system can no longer boot once you reboot.
I’ll give you the log that shows in Konsole when the errors start to occur:
( 1/21) Creating system user accounts...
( 2/21) Updating journal message catalog...
( 3/21) Reloading system manager configuration...
( 4/21) Reloading user manager configuration...
( 5/21) Updating udev hardware database...
( 6/21) Applying kernel sysctl settings...
( 7/21) Creating temporary files...
( 8/21) Reloading device manager configuration...
( 9/21) Arming ConditionNeedsUpdate...
(10/21) Updating the MIME type database...
(11/21) Updating module dependencies...
(12/21) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
  -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img --microcode /boot/amd-ucode.img
==> Starting build: '6.6.7-5-MANJARO'
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [kms]
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
  -> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
  -> Running build hook: [plymouth]
==> ERROR: file not found: '/usr/share/plymouth/manjaro-logo.png'
==> ERROR: file not found: '/usr/lib/plymouth//label.so'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
==> WARNING: errors were encountered during the build. The image may not be complete.
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'fallback'
  -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64-fallback.img -S autodetect --microcode /boot/amd-ucode.img
==> WARNING: Possibly missing firmware for module: 'ast'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.6-x86_64-fallback.img'
error: command failed to execute correctly
I think it has to do with either the filesystem-2023.12.20-1-any package or with plymouth-23.51.283-1-x86_64, since they are the only ones that were installed last night that had to do with the start of loading the system. Looking at the errors above, everything seems to indicate that the plymouth-23.51.283-1-x86_64 package is causing this.
Please, can someone tell me how I can restore a btrfs snapshot to temporarily solve this problem? I manage to boot Linux by selecting the snapshot in the Grub menu, but once I have booted, I cannot launch any type of update with pamac, pacman or yay since it blocks the system and when I restart I no longer have the option to boot with the snapshot because it tells me that it can no longer find the Linux kernel, therefore what I need to know is how to restore the snapshot to the current system.
Sounds like a partial upgrade state. Make sure your mirror(s) are up to date and see if you missed any packages. Either way, run mkinitcpio -P to regenerate your initramfs. It looks like the hook ran before the appropriate packages were updated.
plymouth 23.51.283-1 depends on filesystem 2023.12.20-1 as the Manjaro logos were moved to the latter package:
❯ pacman -Ql filesystem | grep logo
filesystem /usr/share/pixmaps/manjaro-logo-text-dark.png
filesystem /usr/share/pixmaps/manjaro-logo.png
Please create a Support thread for further troubleshooting.
The only thing I have done after installing Manjaro is:
sudo pacman-mirrors --api --set-branch unstable
And then:
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syu
I haven’t done anything else, and this has already caused the failure to start the package update process.
I just made a few edits to my post, please refresh the page if necessary and review it again.
Result of mkinitcpio -P:
Result of pacman -Ql filesystem | grep logo:
Based on those errors some is off. @Yochanan can you check again on your system if you see similar errors?
@Alden20 can you confirm if you stay on testing branch that you don’t have those issues?
I confirm that the testing branch does not give the error:
rondo-um580% sudo manjaro-downgrade plymouth
:: Retrieving packages...
 plymouth-22.02.122-15-x86_64          1056,7 KiB  1360 KiB/s 00:01 [######################################] 100%
loading packages...
warning: downgrading package plymouth (23.51.283-1 => 22.02.122-15)
resolving dependencies...
Packages (1) plymouth-22.02.122-15
Total Installed Size:   1,89 MiB
Net Upgrade Size:      -0,25 MiB
(1/1) checking keys in keyring                                      [######################################] 100%
(1/1) checking package integrity                                    [######################################] 100%
(1/1) loading package files                                         [######################################] 100%
(1/1) checking for file conflicts                                   [######################################] 100%
(1/1) checking available disk space                                 [######################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
First run mode (config file not found)
Selected default snapshot type: BTRFS
Using system disk as snapshot device for creating snapshots in BTRFS mode
Mounted '/dev/nvme0n1p2' at '/run/timeshift/37497/backup'
btrfs: Quotas are not enabled
Creating new backup...(BTRFS)
Saving to device: /dev/nvme0n1p2, mounted at path: /run/timeshift/37497/backup
Created directory: /run/timeshift/37497/backup/timeshift-btrfs/snapshots/2023-12-21_01-11-35
Created subvolume snapshot: /run/timeshift/37497/backup/timeshift-btrfs/snapshots/2023-12-21_01-11-35/@
Created control file: /run/timeshift/37497/backup/timeshift-btrfs/snapshots/2023-12-21_01-11-35/info.json
BTRFS Snapshot saved successfully (0s)
Tagged snapshot '2023-12-21_01-11-35': ondemand
Found linux image: /boot/vmlinuz-6.6-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.6-x86_64.img
Found initrd fallback image: /boot/initramfs-6.6-x86_64-fallback.img
Detecting snapshots ...
Found snapshot: 2023-12-21 01:11:35 | timeshift-btrfs/snapshots/2023-12-21_01-11-35/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2023-12-21 00:30:06 | timeshift-btrfs/snapshots/2023-12-21_00-30-06/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found 2 snapshot(s)
Unmount /tmp/grub-btrfs.ZjiHH8InBq .. Success
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
(1/1) downgrading plymouth                                          [######################################] 100%
(1/4) Reloading system manager configuration...
(2/4) Arming ConditionNeedsUpdate...
(3/4) Updating linux initcpios...
(4/4) Refreshing PackageKit...
I’ll do some further investigating…
EDIT: Eureka! I think I figured it out… Fix incoming…
EDIT @Alden20 plymouth 23.51.283-2 should fix the issue.
I’m sorry, but it continues failing:
rondo-um580% sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syu
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
  1.831 Taiwan         : https://mirror.archlinux.tw/Manjaro/
  1.249 Switzerland    : https://mirror.init7.net/manjaro/
  0.092 Global         : https://mirrors2.manjaro.org/
  0.371 United_Kingdom : http://manjaro.mirrors.uk2.net/
  0.444 Germany        : https://ftp.gwdg.de/pub/linux/manjaro/
::INFO Writing mirror list
::Global          : https://mirrors2.manjaro.org/unstable
::United_Kingdom  : http://manjaro.mirrors.uk2.net/unstable
::Germany         : https://ftp.gwdg.de/pub/linux/manjaro/unstable
::Switzerland     : https://mirror.init7.net/manjaro/unstable
::Taiwan          : https://mirror.archlinux.tw/Manjaro/unstable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
 core is up to date
 extra                                    8,6 MiB  22,3 MiB/s 00:00 [######################################] 100%
 multilib is up to date
Packages (2) libheif-1.17.6-1  plymouth-23.51.283-2
Total Download Size:   1,46 MiB
Total Installed Size:  3,36 MiB
Net Upgrade Size:      0,25 MiB
 plymouth-23.51.283-2-x86_64           1120,2 KiB  4,91 MiB/s 00:00 [######################################] 100%
 libheif-1.17.6-1-x86_64                371,8 KiB  8,44 MiB/s 00:00 [######################################] 100%
 Total (2/2)                           1492,1 KiB  3,80 MiB/s 00:00 [######################################] 100%
(2/2) checking keys in keyring                                      [######################################] 100%
(2/2) checking package integrity                                    [######################################] 100%
(2/2) loading package files                                         [######################################] 100%
(2/2) checking for file conflicts                                   [######################################] 100%
(2/2) checking available disk space                                 [######################################] 100%
Mounted '/dev/nvme0n1p2' at '/run/timeshift/55359/backup'
Saving to device: /dev/nvme0n1p2, mounted at path: /run/timeshift/55359/backup
Created directory: /run/timeshift/55359/backup/timeshift-btrfs/snapshots/2023-12-21_01-40-00
Created subvolume snapshot: /run/timeshift/55359/backup/timeshift-btrfs/snapshots/2023-12-21_01-40-00/@
Created control file: /run/timeshift/55359/backup/timeshift-btrfs/snapshots/2023-12-21_01-40-00/info.json
Tagged snapshot '2023-12-21_01-40-00': ondemand
Found snapshot: 2023-12-21 01:40:00 | timeshift-btrfs/snapshots/2023-12-21_01-40-00/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found 3 snapshot(s)
Unmount /tmp/grub-btrfs.IxcgxxBDe3 .. Success
done
(1/2) upgrading libheif                                             [######################################] 100%
(2/2) upgrading plymouth                                            [######################################] 100%
(1/5) Reloading system manager configuration...
(2/5) Arming ConditionNeedsUpdate...
(3/5) Updating linux initcpios...
==> ERROR: file not found: '/usr/share/plymouth/pixmaps/manjaro-logo.png'
(4/5) Refreshing PackageKit...
(5/5) Probing GDK-Pixbuf loader modules...
Er… sorry. How about 23.51.283-3? That fixes the logo location, anyway.
I still have no idea where that’s coming from.
OK, I confirm you the logo location is fixed, and as you say, the other error is pending of resolution:
  0.517 United_States  : https://coresite.mm.fcix.net/manjaro/
  0.077 Global         : https://mirrors2.manjaro.org/
  0.581 United_States  : https://uvermont.mm.fcix.net/manjaro/
  0.111 Global         : https://mirrors.manjaro.org/repo/
  ..... Japan          : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/
::Global          : https://mirrors.manjaro.org/repo/unstable
::United_States   : https://coresite.mm.fcix.net/manjaro/unstable
::United_States   : https://uvermont.mm.fcix.net/manjaro/unstable
::Japan           : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/unstable
 core is up to date
 extra                                    8,6 MiB  16,5 MiB/s 00:01 [######################################] 100%
Packages (1) plymouth-23.51.283-3
Total Download Size:   1,09 MiB
Total Installed Size:  2,14 MiB
Net Upgrade Size:      0,00 MiB
 plymouth-23.51.283-3-x86_64           1120,2 KiB  2,83 MiB/s 00:00 [######################################] 100%
Mounted '/dev/nvme0n1p2' at '/run/timeshift/73187/backup'
Saving to device: /dev/nvme0n1p2, mounted at path: /run/timeshift/73187/backup
Created directory: /run/timeshift/73187/backup/timeshift-btrfs/snapshots/2023-12-21_01-54-02
Created subvolume snapshot: /run/timeshift/73187/backup/timeshift-btrfs/snapshots/2023-12-21_01-54-02/@
Created control file: /run/timeshift/73187/backup/timeshift-btrfs/snapshots/2023-12-21_01-54-02/info.json
Tagged snapshot '2023-12-21_01-54-02': ondemand
Mounted '/dev/nvme0n1p2' at '/run/timeshift/73328/backup'
Selected default snapshot device: /dev/nvme0n1p2
Removing snapshot: 2023-12-21_00-30-06
Deleting subvolume: @ (Id:260)
Deleted subvolume: @ (Id:260)
Deleted directory: /run/timeshift/73328/backup/timeshift-btrfs/snapshots/2023-12-21_00-30-06
Removed snapshot: 2023-12-21_00-30-06
Found snapshot: 2023-12-21 01:54:02 | timeshift-btrfs/snapshots/2023-12-21_01-54-02/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found 3 snapshot(s)
Unmount /tmp/grub-btrfs.hdDfEGVKly .. Success
done
(1/1) upgrading plymouth                                            [######################################] 100%
Theres a typo or some other error in parsing the data … double slashes.
That’s a fair guess, however /usr/lib/plymouth/label.so is no longer part of plymouth as of 23.51.283. It was there in the previous version.
True, no package currently provides anything *plymouth/label.so
But right now it wouldnt matter if there were, because its looking for /usr/lib/plymouth//label.so.
Turns out label.so was replaced by label-freetype.so & label-pango.so. Fixing now…
Update: The issue is with /usr/lib/initcpio/install/plymouth and /usr/lib/initcpio/install/sd-plymouth. I’ve tried replacing label.so with both label-freetype.so & label-pango.so in those files and the initramfs builds fine. However, the Plymouth logo is not displayed on boot with either. More investigation is required.
@Alden20 For now, either remove the plymouth hook from your /etc/mkinitcpio.conf or downgrade filesystem and plymouth.
OK, I have commented the plymouth hook from my /etc/mkinitcpio.conf as you have indicated and has done it correctly. I restarted the machine and logged in again to see that Linux was indeed booting correctly.
The only thing is that I understand that we cannot leave the current version of the package (23.51.283-3) in the repository, since anyone who updates the packages in the unstable branch will experience the same thing as me, and if that user does not pay attention to the error message, he or she will not be able to boot Linux afterwards. It would have to be replaced with the version that now exists in the testing branch (22.02.122-15).
I was able to fix the issue with the missing label.so on my end, but then I realized there’s other things that need to be changed as well. I was not able to get it working properly after the changes, so I’ve just reverted filesystem and plymouth to their previous versions for now.
@Alden20
<snip>
Moderator edit: Removed screenshot of terminal output
Post preformatted text, not images. How many times does this need to be said?
