File 'mgame.db' not found
mgame
pacmanconf
#1
hello every one i am new user of manjaro
i read every thing about refresh pacman and mirrors and i get this error every time i open terminal
warning: database file for ‘mgame’ does not exist
██████████████████ ████████ ahmed@ahmed-pc
██████████████████ ████████ OS: Manjaro 17.0 Gellivara
██████████████████ ████████ Kernel: x86_64 Linux 4.9.13-1-MANJARO
██████████████████ ████████ Uptime: 15m
████████ ████████ Packages: 1174
████████ ████████ ████████ Shell: bash 4.4.12
████████ ████████ ████████ Resolution: 1366x768
████████ ████████ ████████ DE: XFCE4
████████ ████████ ████████ WM: Xfwm4
████████ ████████ ████████ WM Theme: Vertex-Maia
████████ ████████ ████████ GTK Theme: Breath-Dark [GTK2]
████████ ████████ ████████ Icon Theme: gnome
████████ ████████ ████████ Font: Cantarell 10
████████ ████████ ████████ CPU: Intel Core i5-7200U @ 4x 3.1GHz [27.8°C]
GPU: Mesa DRI Intel® HD Graphics 620 (Kabylake GT2)
RAM: 602MiB / 3873MiB
[ahmed@ahmed-pc ~]$ sudo nano /etc/pacman.d/mirrorlist
[sudo] password for ahmed:
[ahmed@ahmed-pc ~]$ sudo nano /etc/pacman.conf
[ahmed@ahmed-pc ~]$ sudo pacman -Syy
core 149.4 KiB 98.7K/s 00:02 [-----------------------] 100%
extra 1833.4 KiB 113K/s 00:16 [-----------------------] 100%
community 4.8 MiB 89.5K/s 00:55 [-----------------------] 100%
multilib 178.6 KiB 98.7K/s 00:02 [-----------------------] 100%
error: failed retrieving file ‘mgame.db’ from ftp.hosteurope.de : Given file does not exist
error: failed to update mgame (download library error)
[ahmed@ahmed-pc ~]$ sudo pacman-mirrors -g
#2
mgame is not a repo manjaro - you’re the one who added it in /etc/pacman.conf. if you want change url or remove ? edit this file
#3
no i just repaire that file just like in wiki
#4
and thanks to replay can you explain more couse i am new user
#5
no manjaro wiki told you to add mgame? what is the url?
in pacman.conf you have add one section [mgame] , you remove or change with a good url.
[mgame]
Server = https://?????
“mgame” is not manjaro, I don’t know the right url, I don’t know why you added that.
#6
[mgame]
SigLevel = Optional TrustAll
Server = ftp://ftp.hosteurope.de/mirror/ftp.archlinux.org/core/os/$arch
#7
ok i understand the mistake what i can do to fix it
#8
Judging from the screenfetch output, I would say this is a very old ISO.
Correct me if I’m wrong, but I think you installed Manjaro Gaming Edition (mGAMe) 17.0.
#9
yes that is os manjaro 17.0 gellivara
#10
http://ftp.hosteurope.de/mirror/ftp.archlinux.org/core/os/x86_64/
is only for archlinux
why add this repository? you can only, at best, break your distribution - even, we can no longer say that you have a manjaro
for exemple: pacman for manjaro is different (SyncFirst not exists)
#11
@ABOhiccups is back to the forum and back to maintaining mGAMe.
He will happily support you. I’ll move your topic to #support-for-community-editions:unofficial-spins
#12
thank you every one
i just was confused i read so much articals about that error
so i must add the repo for that os only and it will work
i will try and reply here
thank
#13
Let’s wait for the reply of the maintainer when his repo will be active or if it is already active.
#14
#15
#16
Edit you /etc/pacman.conf and remove the reference to mgame repo.
Save with F2 and press Y when asked.
Then redo your update
sudo pacman -Syu
The only packages not in the official repo is
## AUR pkgs
kega-fusion
minecraft
minecraft-server
retroarch-autoconfig-udev-git
#17
finally it is work
thank you
now pacman update packages
:heart_eyes::heart_eyes:
closed #18
