File /boot/vmlinuz-5.10-x86_64 not found
then can you
return
inxi -Fza
lsblk -fs
parted -l
cat /etc/fstab
from the chrooted from live or in grub Shell?
How could this happen? You most likely screwed your system with this setting. Manjaro is not Arch, mixing repos from different distros is a pretty safe way to irrevocable corrupt your filesystem. Even if you get your current issues fixed there might be hidden deficiencies. Better safe your data and reinstall.
from live
lsblk -fs
and in chroot
inxi -Fza
parted -l
cat /etc/fstab
I am totally not sure how this ended up here, as far as I am aware, I did not add it in on purpose in the last year.
It’s not getting there from alone, please be honest.
I am honest, as far as I can remember I never touched said file. But I know what you mean :wink:
    ~  lsblk -fs                                                        ✔
NAME FSTYPE FSVER LABEL UUID                                 FSAVAIL FSUSE% MOUNTPOINT
sda1 vfat   FAT32       1ABC-8020
└─sda
sda2 crypto 1           xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
└─sda
sda3 crypto 1           xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
└─sda
It’s not a problem to make a huge mistake (we all do from time to time :wink:) but you should not hide it when you are looking for help. This would not be fair to the people trying to fix your issues.
Anyway, using a Arch core repo is most likely toxic. I would not say impossible to fix but risky as you never know if you covered all deficiencies. Better safe your valuable data and reinstall. Take it as lesson.
I understand you, and I did not try to hide it. As soon as @stephane told me to look at the file, I saw the line and pointed it out :slight_smile: so I think I tried to be as helpful as possible
are you using sda2 & sda 3 as raid 1 disk
According to the infos I got in grub, sda3 seems to be labeld as a swap partition
Do you need anything special from inxi -Fza?
line boot kernel , and info about partition installed
[manjaro-gnome /]# inxi -Fza
12System:
  12Kernel 5.9.16-1-MANJARO x86_64 12bits 64 12compiler gcc 12v 10.2.0
    12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=de tz=UTC misobasedir=manjaro
    misolabel=MANJARO_GNOME_2021 quiet systemd.show_status=1 driver=free nouveau.modeset=1
    i915.modeset=1 radeon.modeset=1
  12Desktop GNOME 41.2 12tk GTK 3.24.30 12wm gnome-shell 12dm N/A 12Distro Manjaro Linux 12base Arch Linux
12Partition:
  12ID-1 / 12raw-size 878.98 GiB 12size 864.19 GiB (98.32%) 12used 313.17 GiB (36.2%) 12fs ext4
    12block-size 4096 B 12dev /dev/dm-0 12maj-min 254:0 12mapped sda2
  12ID-2 /boot 12raw-size 300 MiB 12size 299.4 MiB (99.80%) 12used 73.6 MiB (24.6%) 12fs vfat
    12block-size 512 B 12dev /dev/sda1 12maj-min 8:1
[manjaro-gnome /]# parted -l
Model: ATA CT960BX500SSD1 (scsi)
Disk /dev/sda: 960GB
Partition Table: gpt
Disk Flags:
Number  Start   End    Size    File system  Name  Flags
 1      2097kB  317MB  315MB   fat32              boot, esp
 2      317MB   944GB  944GB
 3      944GB   960GB  16.1GB
[manjaro-gnome /]# cat /etc/fstab
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=1ABC-8020                            /boot/efi      vfat    umask=0077 0 2
/dev/mapper/luks-9e5cb524-9427-4a0a-b016-a428e44cdd8b /              ext4    defaults,noatime,discard 0 1
/dev/mapper/luks-399a5a8e-b6e2-4897-8a1c-ef88c1dd101c swap           swap    defaults,noatime,discard 0 2
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
have applied this on chroot mount ?
mount boot to /mnt/boot/efi? As I see in mine I should be in folder efi right?
Following at the end:
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck --verbose
grub-install: info: executing efibootmgr --version </dev/null >/dev/null.
grub-install: info: executing modprobe -q efivars.
EFI variables are not supported on this system.
grub-install: info: executing efibootmgr -c -d /dev/sda -p 1 -w -L manjaro -l \EFI\manjaro\grubx64.efi.
grub-install: error: efibootmgr failed to register the boot entry: No such file or directory.
Looks like no efi then?
only if you need to re install grub and re create entry EFI
inxi -Mxa will tells you UEFI or something else
inxi -Mxa gives me only info about my machine and there stands 12UEFI
I do not need to reinstall grub as far as I am aware.
I am still at the errors:
error: file '/boot/vmlinuz-5.10-x86_64' not found
error: you need to load the kernel first
But grub itself appears
