There is a white-noise app called “Blanket” in the community repo. Since the latest Manjaro system update it doesn’t work. And neither does blanket-git from AUR. (But the flatpak version still works.)
It doesn’t display the sound options properly, and it doesn’t play.
This is what I get when I run it in terminal
blanket ✔
/usr/share/blanket/blanket/sound.py:86: Warning: g_object_setv: assertion 'G_IS_OBJECT (object)' failed
self.set_volume(0)
/usr/share/blanket/blanket/sound.py:89: Warning: g_object_setv: assertion 'G_IS_OBJECT (object)' failed
self.set_uri(self.sound.uri)
/usr/share/blanket/blanket/sound.py:94: Warning: g_object_get_property: assertion 'G_IS_OBJECT (object)' failed
self.pipeline = self.get_pipeline()
File "/usr/share/blanket/blanket/widgets.py", line 209, in _create_sound_widget
widget = SoundRow(sound, self.model)
File "/usr/share/blanket/blanket/widgets.py", line 70, in __init__
self.player = SoundPlayer(self.sound)
File "/usr/share/blanket/blanket/sound.py", line 95, in __init__
bus = self.pipeline.get_bus()
AttributeError: 'NoneType' object has no attribute 'get_bus'
/usr/share/blanket/blanket/widgets.py:206: Warning: g_object_is_floating: assertion 'G_IS_OBJECT (object)' failed
self.model.append(sound)
my system info
inxi -F ✔
Host: shmuel-manjaro Kernel: 5.16.11-2-MANJARO x86_64
bits: 64 Desktop: KDE Plasma 5.24.2 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B365M-A
v: Rev X.0x serial: <superuser required>
UEFI: American Megatrends v: 1203 date: 10/10/2019
Info: 8-core model: Intel Core i7-9700 bits: 64 type: MCP
cache: L2: 2 MiB
Speed (MHz): avg: 800 min/max: 800/4700 cores: 1: 800
2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630]
driver: i915 v: kernel
Device-2: Microdia USB Live camera type: USB
driver: snd-usb-audio,uvcvideo
Display: x11 server: X.Org v: 1.21.1.3 driver: X:
loaded: modesetting gpu: i915 resolution:
1: 1920x1080~120Hz 2: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
v: 4.6 Mesa 21.3.7
Device-1: Intel 200 Series PCH HD Audio
driver: snd_hda_intel
Sound Server-1: ALSA v: k5.16.11-2-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.47 running: yes
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit
Ethernet
driver: r8169
IF: enp3s0 state: up speed: 1000 Mbps duplex: full
mac: a8:5e:45:e2:87:3c
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI
mode)
type: USB driver: btusb
Report: rfkill ID: hci0 state: up
address: see --recommends
Local Storage: total: 2.26 TiB used: 694.47 GiB (30.1%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G
ID-2: /dev/sdb vendor: Toshiba model: HDWD120
ID-1: / size: 66.76 GiB used: 22.22 GiB (33.3%) fs: ext4
dev: /dev/sda8
ID-2: /boot/efi size: 96 MiB used: 36.9 MiB (38.5%)
fs: vfat dev: /dev/sda2
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 275 Uptime: 43m Memory: 15.49 GiB
used: 8.08 GiB (52.1%) Shell: Zsh inxi: 3.3.13
