So I made another step foward today. Now the program launches the game and it starts to loadin before promptly crashing
I did this by using
wine injector.exe Eden.xml
this bypassed the Launcher and the config file inputs my login details and I am greeted with loud blaring trumpts of nostalgia only to crash as soon as i Accept the terms and conditions.
This is where i believe it might go wrong then again it might not.
wine: Unhandled page fault on write access to 00000014 at address 7DFD7883 (thread 0258), starting debugger…
Unhandled exception: page fault on write access to 0x00000014 in 32-bit code (0x7dfd7883).
0284:err:dbghelp_msc:pe_load_debug_directory Got a page fault while loading symbols
Okay trying to start from a fresh prefix of wine and I type
winetricks dotnet35sp1
It runs and has an error
[05/19/22,17:21:20] Microsoft .NET Framework 2.0a x64: [2] Error: Installation failed for component Microsoft .NET Framework 2.0a x64. MSI returned error code 1627
So I couldnt install it this time weird wonder what happened.
The .NET Runtime Optimization Service is started and paused.
0190:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0190:err:winediag:gnutls_process_attach failed to load libgnutls, no support for encryption
0190:fixme:service:QueryServiceConfig2W Level 6 not implemented
Microsoft (R) CLR Native Image Generator - Version 2.0.50727.3053
Copyright (c) Microsoft Corporation. All rights reserved.
0150:fixme:heap:RtlSetHeapInformation 0000000000880000 0 000000000011F6B0 4 stub
0150:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0150:fixme:service:QueryServiceConfig2W Level 6 not implemented
01c0:fixme:richedit:editor_handle_message EM_SETMARGINS: stub
0204:fixme:imm:ImeSetActiveContext (0x25d5e8, 1): stub
0204:fixme:imm:ImmReleaseContext (00040162, 0025D5E8): stub
0204:fixme:ver:GetCurrentPackageId (0065FEA4 00000000): stub
01b8:err:ole:CoRevokeClassObject called from wrong apartment, should be called from 11400000118
0208:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0208:err:winediag:gnutls_process_attach failed to load libgnutls, no support for encryption
0208:fixme:service:QueryServiceConfig2W Level 6 not implemented
The .NET Runtime Optimization Service is running.
0238:fixme:heap:RtlSetHeapInformation 0000000000880000 0 000000000011F6B0 4 stub
0238:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0238:fixme:service:QueryServiceConfig2W Level 6 not implemented
0100:fixme:ver:GetCurrentPackageId (000000000021FD70 0000000000000000): stub
warning: Note: command wine dotnetfx35.exe /lang:ENU returned status 91. Aborting.
I need to be able to run Wine stable side by side with wine-staging , depending on the game I want to play. I know how to create a new 32bit prefix, so i know how to install two different games in two different prefix’s , but i dont know how to make sure wine-staging is being used when I want it too, and wine stable is being used the other times.
WINEARCH=win32 WINEPREFIX=~/.wine_32 winetricks
where and how to i put in the patch to tell it to use wine-staging
