I am getting the following error when trying to open the ffado-mixer:
[username@hostname ~]$ sudo pacman -S libffado
resolving dependencies...
Packages (1) libffado-2.4.4-4
Total Installed Size: 5.37 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [######################] 100%
(1/1) checking package integrity [######################] 100%
(1/1) loading package files [######################] 100%
(1/1) checking for file conflicts [######################] 100%
(1/1) checking available disk space [######################] 100%
(1/1) installing libffado [######################] 100%
Optional dependencies for libffado
python-pyqt5: ffado-mixer [installed]
(1/4) Reloading device manager configuration...
(2/4) Arming ConditionNeedsUpdate...
(3/4) Updating icon theme caches...
(4/4) Updating the desktop file MIME type cache...
[username@hostname ~]$ ffado-mixer
File "/usr/lib/python3.10/site-packages/ffado/panelmanager.py", line 460, in updatePanels
self.addPanel(idx)
File "/usr/lib/python3.10/site-packages/ffado/panelmanager.py", line 339, in addPanel
mixerwidget.initValues()
File "/usr/lib/python3.10/site-packages/ffado/mixer/rme.py", line 441, in initValues
self.inputmatrix = MatrixMixer(self.hw.servername, self.hw.basepath+"/Mixer/InputFaders", self, "Columns_are_inputs", 0x8000, self.hw.basepath+"/Mixer/InputMutes", self.hw.basepath+"/Mixer/InputInverts", True)
File "/usr/lib/python3.10/site-packages/ffado/widgets/matrixmixer.py", line 1256, in __init__
self.matrix = MatrixControlView(servername, basepath, self, sliderMaxValue, mutespath, invertspath, smallFont, self.short_names_bool, "In", "Out", self.transpose)
File "/usr/lib/python3.10/site-packages/ffado/widgets/matrixmixer.py", line 381, in __init__
ch = MixerChannel(i, self, self.getColName(i, self.shortname), smallFont)
File "/usr/lib/python3.10/site-packages/ffado/widgets/matrixmixer.py", line 303, in __init__
font.setPointSize(font.pointSize()/1.5)
TypeError: setPointSize(self, int): argument 1 has unexpected type 'float'
Aborted (core dumped)
If I fix that issue by editing line 303 of matrixmixer.py to be:
font.setPointSize(int(font.pointSize()/1.5))
then I get the error:
self.addPanel(idx)
File "/usr/lib/python3.10/site-packages/ffado/widgets/matrixmixer.py", line 421, in __init__
node = MixerNode(j, i, val, sliderMaxValue, mute_value, inv_value, self, self)
File "/usr/lib/python3.10/site-packages/ffado/widgets/matrixmixer.py", line 130, in __init__
self.setValue(value)
TypeError: setValue(self, int): argument 1 has unexpected type 'dbus.Double'
For which the fix is less obvious. I get a similar error (different line) if I then do:
[username@hostname ~]$ sudo pacman -R libffado
checking dependencies...
:: jack2 optionally requires libffado: for firewire support using FFADO
Total Removed Size: 5.37 MiB
:: Do you want to remove these packages? [Y/n] y
(1/1) removing libffado [######################] 100%
[username@hostname ~]$ yay -S libffado-svn
:: Checking for conflicts...
:: Checking for inner conflicts...
[Repo Make:6] scons-4.3.0-3 libutf8proc-2.7.0-1 apr-1.7.0-3 apr-util-1.6.1-9 serf-1.3.9-5 subversion-1.14.1-5
[Aur:1] libffado-svn-r2776-1
==> Remove make dependencies after install? [y/N] y
1 libffado-svn (Build Files Exist)
==> Packages to cleanBuild?
==> [N]one [A]ll [Ab]ort [I]nstalled [No]tInstalled or (1 2 3, 1-3, ^4)
:: PKGBUILD up to date, Skipping (1/0): libffado-svn
==> Diffs to show?
:: (1/1) Parsing SRCINFO: libffado-svn
Packages (6) apr-1.7.0-3 apr-util-1.6.1-9 libutf8proc-2.7.0-1 scons-4.3.0-3
Total Installed Size: 60.16 MiB
(6/6) checking keys in keyring [######################] 100%
(6/6) checking package integrity [######################] 100%
(6/6) loading package files [######################] 100%
(6/6) checking for file conflicts [######################] 100%
(6/6) checking available disk space [######################] 100%
(1/6) installing scons [######################] 100%
(2/6) installing libutf8proc [######################] 100%
(3/6) installing apr [######################] 100%
(4/6) installing apr-util [######################] 100%
Optional dependencies for apr-util
gdbm: enable gdbm support [installed]
libldap: enable ldap support [installed]
unixodbc: enable odbc support
mariadb-libs: enable mysql/mariadb support
postgresql-libs: enable postgres support [installed]
db: enable berkley db support [installed]
sqlite: enable sqlite support [installed]
nss: enable nss crypto support [installed]
openssl: enable openssl crypto support [installed]
(5/6) installing serf [######################] 100%
(6/6) installing subversion [######################] 100%
Optional dependencies for subversion
libgnome-keyring: for GNOME Keyring for auth credentials
kwallet: for KWallet for auth credentials
bash-completion: for svn bash completion
python: for some hook scripts [installed]
java-environment: for Java support
ruby: for some hook scripts
(1/4) Reloading system manager configuration...
(2/4) Creating temporary files...
(3/4) Arming ConditionNeedsUpdate...
(4/4) Warn about old perl modules
==> Making package: libffado-svn r2776-1 (Fri 18 Feb 2022 08:51:46 PM EST)
==> Retrieving sources...
-> Updating libffado svn repo...
Updating '.':
At revision 2821.
==> Validating source files with sha512sums...
libffado ... Skipped
-> scons not satisfied, flushing install queue
==> Making package: libffado-svn r2776-1 (Fri 18 Feb 2022 08:51:52 PM EST)
Updating '.':
At revision 2821.
==> Extracting sources...
-> Creating working copy of libffado svn repo...
==> Starting prepare()...
==> Starting pkgver()...
==> Updated version: libffado-svn r2821-1
==> Sources are ready.
==> Making package: libffado-svn r2821-1 (Fri 18 Feb 2022 08:51:59 PM EST)
==> WARNING: Using existing $srcdir/ tree
-> libffado-svn-r2821-1 already made -- skipping build
loading packages...
Packages (1) libffado-svn-r2821-1
Total Installed Size: 5.51 MiB
(1/1) installing libffado-svn [######################] 100%
Optional dependencies for libffado-svn
alsa-lib: for test-scs [installed]
python-pyqt5: for ffado-mixer [installed]
:: git optionally requires subversion: git svn
Total Removed Size: 60.16 MiB
(1/6) removing subversion [######################] 100%
(2/6) removing serf [######################] 100%
(3/6) removing apr-util [######################] 100%
(4/6) removing apr [######################] 100%
(5/6) removing libutf8proc [######################] 100%
(6/6) removing scons [######################] 100%
(1/2) Reloading system manager configuration...
(2/2) Arming ConditionNeedsUpdate...
File "/usr/lib/python3.7/site-packages/ffado/panelmanager.py", line 460, in updatePanels
self.addPanel(idx)
File "/usr/lib/python3.7/site-packages/ffado/panelmanager.py", line 339, in addPanel
File "/usr/lib/python3.7/site-packages/ffado/mixer/rme.py", line 441, in initValues
File "/usr/lib/python3.7/site-packages/ffado/widgets/matrixmixer.py", line 1256, in __init__
File "/usr/lib/python3.7/site-packages/ffado/widgets/matrixmixer.py", line 421, in __init__
File "/usr/lib/python3.7/site-packages/ffado/widgets/matrixmixer.py", line 166, in __init__
self.mute_action.setChecked(muted)
TypeError: setChecked(self, bool): argument 1 has unexpected type 'dbus.Double'
As things stand I now have no way of controlling my firewire soundcards and am thus pretty desperate. Any suggestions?
