BOINC Mananager 7.16.11-1
Manjaro up to date 11/29/2020
$ boincmgr
11:25:10: Warning: Mismatch between the program and library build versions detected.
The library used 3.0 (wchar_t,compiler with C++ ABI 1013,wx containers,compatible with 2.8),
and your program used 3.0 (wchar_t,compiler with C++ ABI 1014,wx containers,compatible with 2.8).
Fabby
1 December 2020 15:42
2
Welcome to Manjaro!
Please read this:
When asking questions in the forum, it would be most helpful to all members if you provide some basic information. When you provide info from the terminal, usually from your logs, you have to format it so the content is easy to read. First copy and...
Reading time: 6 mins 🕑
Likes: 133 ❤
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width
would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
What you’re expecting is just a warning. Does the BOINC work normally?
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU you have, …
inxi output below
Boinc Manager is not coming up. But, I can see the boinc processes are still running unmanaged.
I’m running a pretty vanilla Manjaro install with the Xfce desktop, bits and pieces of other desktop environments have been installed as dependencies for software I have installed. It’s up to date.
Most everything else you asked about is included in the inxi output.
A graphics device is on the motherboard. I don’t believe it includes a GPU.
Kernel: 5.9.11-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=a84a336f-d510-4806-99ac-f0ed1dba5e4d rw quiet apparmor=1
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Mini-pc System: Intel Client Systems product: NUC8i7BEH v: J72992-308
serial: <filter> Chassis: Intel Corporation type: 35 v: 2.0 serial: <filter>
Mobo: Intel model: NUC8BEB v: J72688-308 serial: <filter>
UEFI [Legacy]: Intel v: BECFL357.86A.0077.2019.1127.1452 date: 11/27/2019
RAM: total: 31.23 GiB used: 7.18 GiB (23.0%)
Info: Quad Core model: Intel Core i7-8559U bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 8E (142) stepping: A (10) microcode: E0
L2 cache: 8192 KiB bogomips: 43214
Speed: 3200 MHz min/max: 400/4500 MHz Core speeds (MHz): 1: 3200 2: 3200
3: 3200 4: 3200 5: 3200 6: 3200 7: 3200 8: 3200
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel Iris Plus Graphics 655 driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3ea5
Display: x11 server: X.Org 1.20.9 driver: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.0x22.5")
s-diag: 1165mm (45.9")
Monitor-1: DP1 res: 3840x2160 dpi: 88 size: 1110x620mm (43.7x24.4")
diag: 1271mm (50.1")
OpenGL: renderer: Mesa Intel Iris Plus Graphics 655 (CFL GT3)
v: 4.6 Mesa 20.2.3 direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:9dc8
Sound Server: ALSA v: k5.9.11-2-MANJARO
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
port: 4000 bus ID: 00:14.3 chip ID: 8086:9df0
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Intel Ethernet I219-V driver: e1000e v: kernel port: efa0
bus ID: 00:1f.6 chip ID: 8086:15be
Local Storage: total: 465.76 GiB used: 181.37 GiB (38.9%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS500G3X0C-00SJG0
size: 465.76 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 111110WD scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GP50NB40 rev: RB00
dev-links: cdrom
ID-1: / raw size: 465.76 GiB size: 457.45 GiB (98.22%)
used: 158.55 GiB (34.7%) fs: ext4 dev: /dev/nvme0n1p1 label: N/A
uuid: a84a336f-d510-4806-99ac-f0ed1dba5e4d
ID-2: /home/<filter>/google_drive raw size: N/A size: 100.00 GiB
used: 22.82 GiB (22.8%) fs: fuse.rclone source: ERR-102 label: N/A uuid: N/A
Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 1-2:14 info: MediaTek Slim Portable DVD Writer type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip ID: 0e8d:1887 serial: <filter>
Hub: 1-3:11 info: ASIX AX68002 KVM Switch SoC ports: 7 rev: 1.0
speed: 12 Mb/s chip ID: 0b95:6802
Device-1: 1-3.1:12 info: Pixart Imaging Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
chip ID: 093a:2510
Device-2: 1-3.2:13 info: SiGma Micro Keyboard TRACER Gamma Ivory
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s chip ID: 1c4f:0002
Device-3: 1-10:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
chip ID: 8087:0aaa
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 71.0 C mobo: 27.8 C
Processes: 277 Uptime: 4d 1h 22m Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1371 lib: 395 flatpak: 0 Shell: Bash v: 5.0.18
running in: xfce4-terminal inxi: 3.1.08
