Hi so I am using the manjaro kde for quit a while. Recently I found out that there is like 15+ okular apps. I found out this when I clicked the open with other application>view all applications.
Do anyone know why is this happening?
software and hardware info
Kernel: 5.10.36-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Laptop 15-db1xxx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: HP model: 85EA v: 51.24 serial: <filter> UEFI: Insyde v: F.33
date: 08/17/2020
ID-1: BAT1 charge: 27.3 Wh (69.5%) condition: 39.3/40.9 Wh (96.2%)
volts: 12.6 min: 11.3 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: Charging
RAM: total: 3.36 GiB used: 2.24 GiB (66.9%)
RAM Report:
Info: Quad Core model: AMD Ryzen 3 3300U with Radeon Vega Mobile Gfx
bits: 64 type: MCP arch: Zen/Zen+ note: check rev: 1 cache: L2: 2 MiB
bogomips: 16775
Speed: 1671 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 1671 2: 1187 3: 1211 4: 1211
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rdrand rdseed rdtscp rep_good sep sev
sev_es sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a
ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Device-1: AMD Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel
bus-ID: 03:00.0 chip-ID: 1002:15d8 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP TrueVision HD Camera
type: USB driver: uvcvideo bus-ID: 3-2.1:3 chip-ID: 05c8:03d2
class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
resolution: 1366x768~60Hz s-dpi: 96
OpenGL: renderer: AMD Radeon Vega 6 Graphics (RAVEN DRM 3.40.0
5.10.36-2-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.3 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 1002:15de
class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: N/A bus-ID: 03:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.10.36-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 01:00.0
Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter
vendor: Hewlett-Packard driver: rtw_8723de v: N/A port: 2000
bus-ID: 02:00.0 chip-ID: 10ec:d723 class-ID: 0280
Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb
v: 0.8 bus-ID: 3-2.3:4 chip-ID: 0bda:b009 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 5 state: down bt-service: enabled,running
Local Storage: total: 931.51 GiB used: 56.99 GiB (6.1%)
ID-1: /dev/sda vendor: Western Digital model: WD10SPZX-60Z10T0
size: 931.51 GiB speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter>
rev: 1A04 scheme: GPT
ID-1: / size: 78.24 GiB used: 56.92 GiB (72.8%) fs: ext4 dev: /dev/sda7
label: N/A uuid: fab71c4a-7edd-4e21-b190-f188edd14318
ID-2: /boot/efi size: 256 MiB used: 64.7 MiB (25.3%) fs: vfat
dev: /dev/sda1 label: SYSTEM uuid: 74B7-F0D4
ID-1: /dev/sda2 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
ID-2: /dev/sda3 size: 383.84 GiB fs: ntfs label: Windows
uuid: B27C9B9D7C9B5B45
ID-3: /dev/sda4 size: 233.45 GiB fs: ntfs label: N/A
uuid: C20E3C520E3C4229
ID-4: /dev/sda5 size: 42.11 GiB fs: ntfs label: N/A uuid: C81E46751E465D16
ID-5: /dev/sda6 size: 191.34 GiB fs: ntfs label: New Volume
uuid: DA968F19968EF573
ID-6: /dev/sda8 size: 511 MiB fs: ntfs label: Windows RE tools
uuid: D6B6A5C4B6A5A609
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-1:2 info: Shenzhen Rapoo Rapoo 2.4G Wireless Device
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 24ae:2010 class-ID: 0301
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 3-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 3-2.1:3
info: Cheng Uei Precision Industry (Foxlink) HP TrueVision HD Camera
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 05c8:03d2 class-ID: 0e02
Device-2: 3-2.3:4 info: Realtek Realtek Bluetooth 4.2 Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 0bda:b009 class-ID: e001 serial: <filter>
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1
System Temperatures: cpu: 61.0 C mobo: 20.0 C gpu: amdgpu temp: 61.0 C
Processes: 241 Uptime: 4h 54m wakeups: 11 Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.1.0 Packages: 1499 pacman: 1477 flatpak: 14 snap: 8
Shell: Bash v: 5.1.8 running-in: gnome-terminal inxi: 3.3.04
