I have created the following PKGBUILD for WebFontKitGenerator. I have checked that it builds successfully. I would be glad to have some feedback before I submit it to the AUR.
# Maintainer: Archisman Panigrahi <apandada1 at gmail dot com>
pkgname=webfontkitgenerator-git
_pkgname=webfontkitgenerator
pkgver=v0.3.0.r36.gc8b41a1
pkgrel=1
pkgdesc="Webfont Kit Generator is a simple utility that allows you to generate woff, woff2 and the necessary CSS boilerplate from non-web font formats (otf & ttf)."
arch=('any')
url="https://github.com/rafaelmardojai/webfontkitgenerator"
provides=('webfontkitgenerator')
conflicts=('webfontkitgenerator')
license=('GPL3')
depends=('gtk3' 'gtksourceview4' 'gst-python' 'libhandy-git' 'python-fonttools' 'python-brotli')
makedepends=('meson')
source=("git+https://github.com/rafaelmardojai/webfontkitgenerator.git")
sha256sums=('SKIP')
pkgver() {
cd $_pkgname
git describe --long --tags | sed 's/\([^-]*-g\)/r\1/;s/-/./g'
build() {
arch-meson $_pkgname build
meson compile -C build
package() {
DESTDIR="$pkgdir" meson install -C build
When I run namcap I get the following warning. Is this normal?
$ namcap webfontkitgenerator-git-v0.3.0.r36.gc8b41a1-1-any.pkg.tar.zst
webfontkitgenerator-git W: Dependency included and not needed ('gtk3')
webfontkitgenerator-git W: Dependency included and not needed ('gtksourceview4')
webfontkitgenerator-git W: Dependency included and not needed ('gst-python')
webfontkitgenerator-git W: Dependency included and not needed ('python-fonttools')
webfontkitgenerator-git W: Dependency included and not needed ('libhandy-git')
webfontkitgenerator-git W: Dependency included and not needed ('python-brotli')
Try and keep each line no more than 80 - 100 characters and do not include the package name in the description. Use the About header which is also the Debian package description.
