Hello I have recently installed Manjaro gnome on my 2012 iMac. And it is running extremely slow on firefox.
Things I have done:
- Updated Manjaro
- tried out different performance settings in Firefox
- Started Firefox in safe mode
Things to note:
- Win10 didn’t have this issue with Firefox
- Chromium is much faster then Firefox
System info:
> System:
> Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
> parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
> root=UUID=8fe8066e-dad6-4093-aea3-a659f6e0cbaf rw quiet splash apparmor=1
> security=apparmor resume=UUID=8e0689ff-7304-457c-8ff4-c38e121cc59a
> udev.log_priority=3
> Desktop: GNOME 41.2 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 41.0
> Distro: Manjaro Linux base: Arch Linux
> Machine:
> Type: Desktop System: Apple product: iMac13,2 v: 1.0
> serial: <superuser required> Chassis: type: 13 v: Mac-FC02E91DDD3FA6A4
> Mobo: Apple model: Mac-FC02E91DDD3FA6A4 v: iMac13,2
> serial: <superuser required> UEFI: Apple v: 287.0.0.0.0 date: 06/13/2019
> Battery:
> Message: No system battery data found. Is one present?
> Memory:
> RAM: total: 15.57 GiB used: 10.7 GiB (68.7%)
> RAM Report:
> permissions: Unable to run dmidecode. Root privileges required.
> CPU:
> Info: model: Intel Core i5-3470S bits: 64 type: MCP arch: Ivy Bridge
> family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
> Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
> desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
> desc: 1x6 MiB
> Speed (MHz): avg: 1596 high: 1597 min/max: 1600/3600 scaling:
> driver: intel_cpufreq governor: schedutil cores: 1: 1596 2: 1597 3: 1597
> 4: 1597 bogomips: 23159
> Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
> constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept erms
> est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida lahf_lm
> lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe
> pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand
> rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
> syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
> xsave xsaveopt xtopology xtpr
> Vulnerabilities:
> Type: itlb_multihit status: KVM: VMX disabled
> Type: l1tf
> mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
> Type: mds mitigation: Clear CPU buffers; SMT disabled
> Type: meltdown mitigation: PTI
> Type: spec_store_bypass
> mitigation: Speculative Store Bypass disabled via prctl and seccomp
> Type: spectre_v1
> mitigation: usercopy/swapgs barriers and __user pointer sanitization
> Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional,
> IBRS_FW, STIBP: disabled, RSB filling
> Type: srbds status: Vulnerable: No microcode
> Type: tsx_async_abort status: Not affected
> Graphics:
> Device-1: NVIDIA GK107M [GeForce GTX 660M Mac Edition] vendor: Apple
> driver: nvidia v: 390.144 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
> chip-ID: 10de:0fe0 class-ID: 0300
> Device-2: Apple FaceTime HD Camera (Built-in) type: USB driver: uvcvideo
> bus-ID: 1-1.1:3 chip-ID: 05ac:8511 class-ID: 0e02 serial: <filter>
> Display: x11 server: Xorg 1.21.1.2 compositor: gnome-shell driver:
> loaded: nvidia resolution: <missing: xdpyinfo>
> Message: Unable to show advanced data. Required tool glxinfo missing.
> Audio:
> Device-1: Intel 7 Series/C216 Family High Definition Audio
> driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
> class-ID: 0403
> Device-2: NVIDIA GK107 HDMI Audio driver: snd_hda_intel v: kernel
> bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
> Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
> Sound Server-2: JACK v: 1.9.19 running: no
> Sound Server-3: PulseAudio v: 15.0 running: yes
> Sound Server-4: PipeWire v: 0.3.40 running: no
> Network:
> Device-1: Broadcom NetXtreme BCM57766 Gigabit Ethernet PCIe vendor: Apple
> driver: tg3 v: kernel port: N/A bus-ID: 03:00.0 chip-ID: 14e4:1686
> class-ID: 0200
> IF: enp3s0f0 state: up speed: 100 Mbps duplex: full mac: <filter>
> IP v4: <filter> type: dynamic noprefixroute scope: global
> broadcast: <filter>
> IP v6: <filter> type: dynamic noprefixroute scope: global
> IP v6: <filter> type: noprefixroute scope: link
> Device-2: Broadcom BCM4331 802.11a/b/g/n driver: bcma-pci-bridge v: N/A
> modules: bcma bus-ID: 04:00.0 chip-ID: 14e4:4331 class-ID: 0280
> IF-ID-1: wlp4s0b1 state: down mac: <filter>
> WAN IP: <filter>
> Bluetooth:
> Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb v: 0.8
> bus-ID: 2-1.8.1.3:7 chip-ID: 05ac:828b class-ID: fe01
> Report: rfkill ID: hci0 rfk-id: 1 state: up address: see --recommends
> Logical:
> Message: No logical block device data found.
> RAID:
> Message: No RAID data found.
> Drives:
> Local Storage: total: 1.82 TiB used: 180.86 GiB (9.7%)
> SMART Message: Required tool smartctl not installed. Check --recommends
> ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 2TB
> size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
> type: SSD serial: <filter> rev: 3B6Q scheme: GPT
> Message: No optical or floppy data found.
> Partition:
> ID-1: / raw-size: 1.8 TiB size: 1.77 TiB (98.37%) used: 180.56 GiB (9.9%)
> fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
> uuid: 8fe8066e-dad6-4093-aea3-a659f6e0cbaf
> ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
> used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
> uuid: FC1C-8134
> Swap:
> Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
> ID-1: swap-1 type: partition size: 17.12 GiB used: 307.3 MiB (1.8%)
> priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
> uuid: 8e0689ff-7304-457c-8ff4-c38e121cc59a
> Unmounted:
> Message: No unmounted partitions found.
> USB:
> Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
> chip-ID: 1d6b:0002 class-ID: 0900
> Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
> speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
> Device-1: 1-1.1:3 info: Apple FaceTime HD Camera (Built-in) type: Video
> driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
> Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
> speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
> Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
> Hub-5: 2-1.8:3 info: Microchip (formerly SMSC) ports: 1 rev: 2.0
> speed: 480 Mb/s power: 2mA chip-ID: 0424:2412 class-ID: 0900
> Hub-6: 2-1.8.1:4
> info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth) ports: 3
> rev: 2.0 speed: 12 Mb/s power: 94mA chip-ID: 0a5c:4500 class-ID: 0900
> Device-1: 2-1.8.1.3:7 info: Apple Bluetooth USB Host Controller
> type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s
> Hub-7: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
> Device-1: 3-1:2 info: Logitech G203 Gaming Mouse type: Mouse,HID
> driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
> power: 300mA chip-ID: 046d:c084 class-ID: 0300 serial: <filter>
> Device-2: 3-2:3 info: Logitech Illuminated Keyboard type: Keyboard,Mouse
> power: 300mA chip-ID: 046d:c318 class-ID: 0300
> Hub-8: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
> chip-ID: 1d6b:0003 class-ID: 0900
> Sensors:
> System Temperatures: cpu: 55.0 C mobo: N/A gpu: nvidia temp: 49 C
> Fan Speeds (RPM): N/A
> Info:
> Processes: 224 Uptime: 22d 13h 13m wakeups: 31985 Init: systemd v: 249
> tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1202 lib: 327
> flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.11
