Building from mullvad-vpn-bin 2025.1-2
Fails at
ln: target '/var/tmp/pamac-build-tracy/mullvad-vpn-bin/pkg/mullvad-vpn-bin/etc/apparmor.d/mullvad': No such file or directory
Looks like this point in the script
# Symlink apparmor profile to allow Electron sandbox to work
install -d "$pkgdir/etc/apparmor.d"
ln -s /opt/Mullvad VPN/resources/apparmor_mullvad "$pkgdir/etc/apparmor.d/mullvad"
Full build results
[tracy@daphne ~]$ pamac update
Preparing...
Authenticating as: tracy
Password:
Refreshing AUR...
Cloning mullvad-vpn-bin build files...
Generating mullvad-vpn-bin information...
Checking mullvad-vpn-bin dependencies...
Resolving dependencies...
Checking inter-conflicts...
To build (1):
mullvad-vpn-bin 2025.1-2 (2024.8-1) AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Building mullvad-vpn-bin...
==> Making package: mullvad-vpn-bin 2025.1-2 (Sat 04 Jan 2025 11:28:17)
==> Retrieving sources...
-> Found mullvad-vpn.sh
-> Found MullvadVPN-2025.1_amd64.deb
-> Found MullvadVPN-2025.1_amd64.deb.asc
mullvad-vpn.sh ... Passed
==> Validating source_x86_64 files with sha256sums...
MullvadVPN-2025.1_amd64.deb ... Passed
MullvadVPN-2025.1_amd64.deb.asc ... Skipped
==> Verifying source file signatures with gpg...
==> Extracting sources...
-> Extracting MullvadVPN-2025.1_amd64.deb with bsdtar
==> Removing existing $pkgdir/ directory...
==> Entering fakeroot environment...
==> Starting package()...
x ./
x ./usr/
x ./usr/lib/
x ./usr/lib/systemd/
x ./usr/lib/systemd/system/
x ./usr/lib/systemd/system/mullvad-daemon.service
x ./usr/lib/systemd/system/mullvad-early-boot-blocking.service
x ./usr/bin/
x ./usr/bin/mullvad
x ./usr/bin/mullvad-daemon
x ./usr/bin/mullvad-exclude
x ./usr/bin/mullvad-problem-report
x ./usr/share/
x ./usr/share/bash-completion/
x ./usr/share/bash-completion/completions/
x ./usr/share/bash-completion/completions/mullvad
x ./usr/share/fish/
x ./usr/share/fish/vendor_completions.d/
x ./usr/share/fish/vendor_completions.d/mullvad.fish
x ./usr/share/icons/
x ./usr/share/icons/hicolor/
x ./usr/share/icons/hicolor/16x16/
x ./usr/share/icons/hicolor/16x16/apps/
x ./usr/share/icons/hicolor/16x16/apps/mullvad-vpn.png
x ./usr/share/icons/hicolor/32x32/
x ./usr/share/icons/hicolor/32x32/apps/
x ./usr/share/icons/hicolor/32x32/apps/mullvad-vpn.png
x ./usr/share/icons/hicolor/48x48/
x ./usr/share/icons/hicolor/48x48/apps/
x ./usr/share/icons/hicolor/48x48/apps/mullvad-vpn.png
x ./usr/share/icons/hicolor/64x64/
x ./usr/share/icons/hicolor/64x64/apps/
x ./usr/share/icons/hicolor/64x64/apps/mullvad-vpn.png
x ./usr/share/icons/hicolor/128x128/
x ./usr/share/icons/hicolor/128x128/apps/
x ./usr/share/icons/hicolor/128x128/apps/mullvad-vpn.png
x ./usr/share/icons/hicolor/256x256/
x ./usr/share/icons/hicolor/256x256/apps/
x ./usr/share/icons/hicolor/256x256/apps/mullvad-vpn.png
x ./usr/share/icons/hicolor/512x512/
x ./usr/share/icons/hicolor/512x512/apps/
x ./usr/share/icons/hicolor/512x512/apps/mullvad-vpn.png
x ./usr/share/icons/hicolor/1024x1024/
x ./usr/share/icons/hicolor/1024x1024/apps/
x ./usr/share/icons/hicolor/1024x1024/apps/mullvad-vpn.png
x ./usr/share/applications/
x ./usr/share/applications/mullvad-vpn.desktop
x ./usr/share/doc/
x ./usr/share/doc/mullvad-vpn/
x ./usr/share/doc/mullvad-vpn/changelog.gz
x ./usr/local/
x ./usr/local/share/
x ./usr/local/share/zsh/
x ./usr/local/share/zsh/site-functions/
x ./usr/local/share/zsh/site-functions/_mullvad
x ./opt/
x ./opt/Mullvad VPN/
x ./opt/Mullvad VPN/LICENSE.electron.txt
x ./opt/Mullvad VPN/LICENSES.chromium.html
x ./opt/Mullvad VPN/chrome-sandbox
x ./opt/Mullvad VPN/chrome_100_percent.pak
x ./opt/Mullvad VPN/chrome_200_percent.pak
x ./opt/Mullvad VPN/chrome_crashpad_handler
x ./opt/Mullvad VPN/icudtl.dat
x ./opt/Mullvad VPN/libEGL.so
x ./opt/Mullvad VPN/libGLESv2.so
x ./opt/Mullvad VPN/libffmpeg.so
x ./opt/Mullvad VPN/libvk_swiftshader.so
x ./opt/Mullvad VPN/libvulkan.so.1
x ./opt/Mullvad VPN/locales/
x ./opt/Mullvad VPN/locales/af.pak
x ./opt/Mullvad VPN/locales/am.pak
x ./opt/Mullvad VPN/locales/ar.pak
x ./opt/Mullvad VPN/locales/bg.pak
x ./opt/Mullvad VPN/locales/bn.pak
x ./opt/Mullvad VPN/locales/ca.pak
x ./opt/Mullvad VPN/locales/cs.pak
x ./opt/Mullvad VPN/locales/da.pak
x ./opt/Mullvad VPN/locales/de.pak
x ./opt/Mullvad VPN/locales/el.pak
x ./opt/Mullvad VPN/locales/en-GB.pak
x ./opt/Mullvad VPN/locales/en-US.pak
x ./opt/Mullvad VPN/locales/es-419.pak
x ./opt/Mullvad VPN/locales/es.pak
x ./opt/Mullvad VPN/locales/et.pak
x ./opt/Mullvad VPN/locales/fa.pak
x ./opt/Mullvad VPN/locales/fi.pak
x ./opt/Mullvad VPN/locales/fil.pak
x ./opt/Mullvad VPN/locales/fr.pak
x ./opt/Mullvad VPN/locales/gu.pak
x ./opt/Mullvad VPN/locales/he.pak
x ./opt/Mullvad VPN/locales/hi.pak
x ./opt/Mullvad VPN/locales/hr.pak
x ./opt/Mullvad VPN/locales/hu.pak
x ./opt/Mullvad VPN/locales/id.pak
x ./opt/Mullvad VPN/locales/it.pak
x ./opt/Mullvad VPN/locales/ja.pak
x ./opt/Mullvad VPN/locales/kn.pak
x ./opt/Mullvad VPN/locales/ko.pak
x ./opt/Mullvad VPN/locales/lt.pak
x ./opt/Mullvad VPN/locales/lv.pak
x ./opt/Mullvad VPN/locales/ml.pak
x ./opt/Mullvad VPN/locales/mr.pak
x ./opt/Mullvad VPN/locales/ms.pak
x ./opt/Mullvad VPN/locales/nb.pak
x ./opt/Mullvad VPN/locales/nl.pak
x ./opt/Mullvad VPN/locales/pl.pak
x ./opt/Mullvad VPN/locales/pt-BR.pak
x ./opt/Mullvad VPN/locales/pt-PT.pak
x ./opt/Mullvad VPN/locales/ro.pak
x ./opt/Mullvad VPN/locales/ru.pak
x ./opt/Mullvad VPN/locales/sk.pak
x ./opt/Mullvad VPN/locales/sl.pak
x ./opt/Mullvad VPN/locales/sr.pak
x ./opt/Mullvad VPN/locales/sv.pak
x ./opt/Mullvad VPN/locales/sw.pak
x ./opt/Mullvad VPN/locales/ta.pak
x ./opt/Mullvad VPN/locales/te.pak
x ./opt/Mullvad VPN/locales/th.pak
x ./opt/Mullvad VPN/locales/tr.pak
x ./opt/Mullvad VPN/locales/uk.pak
x ./opt/Mullvad VPN/locales/ur.pak
x ./opt/Mullvad VPN/locales/vi.pak
x ./opt/Mullvad VPN/locales/zh-CN.pak
x ./opt/Mullvad VPN/locales/zh-TW.pak
x ./opt/Mullvad VPN/mullvad-gui
x ./opt/Mullvad VPN/mullvad-vpn
x ./opt/Mullvad VPN/resources/
x ./opt/Mullvad VPN/resources/CHANGELOG.md
x ./opt/Mullvad VPN/resources/apisocks5
x ./opt/Mullvad VPN/resources/app.asar
x ./opt/Mullvad VPN/resources/apparmor_mullvad
x ./opt/Mullvad VPN/resources/ca.crt
x ./opt/Mullvad VPN/resources/libtalpid_openvpn_plugin.so
x ./opt/Mullvad VPN/resources/maybenot_machines
x ./opt/Mullvad VPN/resources/mullvad-problem-report
x ./opt/Mullvad VPN/resources/mullvad-setup
x ./opt/Mullvad VPN/resources/openvpn
x ./opt/Mullvad VPN/resources/relays.json
x ./opt/Mullvad VPN/resources.pak
x ./opt/Mullvad VPN/snapshot_blob.bin
x ./opt/Mullvad VPN/v8_context_snapshot.bin
x ./opt/Mullvad VPN/vk_swiftshader_icd.json
==> ERROR: A failure occurred in package().
Aborting...
