Hello everyone!
After updating Manjaro on my pinebook pro the boot process shows the manjaro logo but eventually this shows up:
Give root password for maintenance
(or press Control-D to continue):
Login with root password does not work: It won’t accept my password.
From pacman.log:
[2022-06-16T11:02:07+0200] [ALPM] upgraded manjaro-system (20220404-1 → 20220528-1)
I am wondering if the boot issue is related to:
[2022-06-16T11:56:27+0200] [ALPM] running ‘90-linux-pinebookpro.hook’…
[2022-06-16T11:56:27+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux-pinebookpro.preset: ‘default’
[2022-06-16T11:56:27+0200] [ALPM-SCRIPTLET] → -k 5.7.19-1-MANJARO-ARM -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img
[2022-06-16T11:56:27+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.7.19-1-MANJARO-ARM
[2022-06-16T11:56:27+0200] [ALPM-SCRIPTLET] → Running build hook: [base]
[2022-06-16T11:56:29+0200] [ALPM-SCRIPTLET] → Running build hook: [udev]
[2022-06-16T11:56:30+0200] [ALPM-SCRIPTLET] ==> ERROR: Hook ‘plymouth’ cannot be found
[2022-06-16T11:56:30+0200] [ALPM-SCRIPTLET] → Running build hook: [autodetect]
[2022-06-16T11:56:31+0200] [ALPM-SCRIPTLET] → Running build hook: [modconf]
[2022-06-16T11:56:31+0200] [ALPM-SCRIPTLET] → Running build hook: [block]
[2022-06-16T11:56:36+0200] [ALPM-SCRIPTLET] → Running build hook: [filesystems]
[2022-06-16T11:56:36+0200] [ALPM-SCRIPTLET] → Running build hook: [keyboard]
[2022-06-16T11:56:37+0200] [ALPM-SCRIPTLET] → Running build hook: [fsck]
[2022-06-16T11:56:37+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-06-16T11:56:38+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-linux.img
[2022-06-16T11:56:40+0200] [ALPM-SCRIPTLET] ==> WARNING: errors were encountered during the build. The image may not be complete.
[2022-06-16T11:56:41+0200] [ALPM] running ‘90-mkinitcpio-install.hook’…
[2022-06-16T11:56:41+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux-pinebookpro.preset: ‘default’
[2022-06-16T11:56:41+0200] [ALPM-SCRIPTLET] → -k 5.7.19-1-MANJARO-ARM -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img
[2022-06-16T11:56:41+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.7.19-1-MANJARO-ARM
[2022-06-16T11:56:41+0200] [ALPM-SCRIPTLET] → Running build hook: [base]
[2022-06-16T11:56:42+0200] [ALPM-SCRIPTLET] → Running build hook: [udev]
[2022-06-16T11:56:44+0200] [ALPM-SCRIPTLET] ==> ERROR: Hook ‘plymouth’ cannot be found
[2022-06-16T11:56:44+0200] [ALPM-SCRIPTLET] → Running build hook: [autodetect]
[2022-06-16T11:56:44+0200] [ALPM-SCRIPTLET] → Running build hook: [modconf]
[2022-06-16T11:56:44+0200] [ALPM-SCRIPTLET] → Running build hook: [block]
[2022-06-16T11:56:46+0200] [ALPM-SCRIPTLET] → Running build hook: [filesystems]
[2022-06-16T11:56:47+0200] [ALPM-SCRIPTLET] → Running build hook: [keyboard]
[2022-06-16T11:56:47+0200] [ALPM-SCRIPTLET] → Running build hook: [fsck]
[2022-06-16T11:56:48+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-06-16T11:56:48+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-linux.img
[2022-06-16T11:56:51+0200] [ALPM-SCRIPTLET] ==> WARNING: errors were encountered during the build. The image may not be complete.
Can I fix my boot problems by creating a Manjaro-KDE live-usbstick, update Manjaro on it and replace the initramfs-linux.img on my SD-Card with the one from the live-usbstick? Or are the troubles during booting unrelated to that ERROR from pacman.log?
Thank you =)
