It is already two weeks that I"m stuck with this message and can’t update my system.
:: installing nvidia-utils (535.54.03-1) breaks dependency 'nvidia-utils=530.41.03' required by linux62-nvidia
Kernel: 6.3.5-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.3-x86_64
root=UUID=0c95387f-2997-4fa3-9e8a-d7cd6e5bd932 rw quiet apparmor=1
security=apparmor resume=UUID=9aed5cbc-9060-442a-a8d3-51bfccf72790
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASRock model: Z68 Pro3 serial: <superuser required>
UEFI: American Megatrends v: P1.60 date: 07/13/2011
Info: model: Intel Core i7-2600K bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 64 MiB
desc: 8x8 MiB
Speed (MHz): avg: 1886 high: 3800 min/max: 1600/3800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1596 2: 1604 3: 1694
4: 1600 5: 3800 6: 1600 7: 1600 8: 1596 bogomips: 54296
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: ASRock driver: i915 v: kernel arch: Gen-6 code: Sandybridge
process: Intel 32nm built: 2011 ports: active: none empty: DP-1, DP-2,
DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0122 class-ID: 0380
Device-2: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: PNY driver: nvidia
v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: i915,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 92 s-size: 707x393mm (27.83x15.47")
s-diag: 809mm (31.85")
Monitor-1: HDMI-0 res: 2560x1440 hz: 60 dpi: 93
size: 698x393mm (27.48x15.47") diag: 801mm (31.54") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2 direct-render: Yes
vendor: ASRock 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: PNY
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-3: JMTek LLC. TKGOU PnP USB Microphone
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 2-1.3:3 chip-ID: 0c76:1467 class-ID: 0300
serial: <filter>
API: ALSA v: k6.3.5-2-MANJARO status: kernel-api with: 1: aoss
type: oss-emulator 2: apulse type: pulse-emulator
Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
Local Storage: total: 1.83 TiB used: 596.12 GiB (31.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 40WD
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Transcend model: TS512GSSD230S
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: <unknown>
tech: SSD serial: <filter> fw-rev: TBD1 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD10EZEX-00WN4A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
used: 596.12 GiB (65.7%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34
used: 280 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-1: swap-1 type: partition size: 8.8 GiB used: 268 KiB (0.0%)
priority: -2 dev: /dev/sdc3 maj-min: 8:35
System Temperatures: cpu: 36.0 C mobo: N/A
Processes: 291 Uptime: 22h 16m wakeups: 16 Memory: available: 15.54 GiB
used: 10.5 GiB (67.6%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 2183
pm: pacman pkgs: 2100 libs: 540 tools: pamac pm: flatpak pkgs: 83 Shell: Zsh
v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
