I installed Quake 4 using Add/Remove Software and have struck and issue with libgcc, when I run Quake 4 I get this message:
--------------- R_InitOpenGL ----------------
Initializing SDL subsystem
Loading GL driver ‘libGL.so.1’ through SDL
SDL_ListModes:
3840x1080 1920x1080 1680x1050 1440x900 1280x1024 1280x800 1280x720 1024x768 800x600 640x480
SDL_ListModes are currently ignored for resolution filtering. Set r_useSDLModes to 1 if you want it
libGL error: MESA-LOADER: failed to open radeonsi: libgcc_s.so.1: version GCC_7.0.0' not found (required by /usr/lib32/dri/radeonsi_dri.so) (search paths /usr/lib32/dri, suffix _dri) libGL error: failed to load driver: radeonsi libGL error: MESA-LOADER: failed to open radeonsi: libgcc_s.so.1: version
GCC_7.0.0’ not found (required by /usr/lib32/dri/radeonsi_dri.so) (search paths /usr/lib32/dri, suffix _dri)
libGL error: MESA-LOADER: failed to open swrast: libgcc_s.so.1: version `GCC_7.0.0’ not found (required by /usr/lib32/dri/swrast_dri.so) (search paths /usr/lib32/dri, suffix _dri)
libGL error: failed to load driver: swrast
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 3 (X_GLXCreateContext)
Value in failed request: 0x0
Serial number of failed request: 42
Current serial number in output stream: 43
pure virtual method called
terminate called without an active exception
signal caught: Aborted
si_code -6
Trying to exit gracefully…
terminate called recursively
double fault Aborted, bailing out
Anyone have any ideas on how to get past this?
