After trying to solve a screen tearing problem with creating a 20-Intel.conf file and editing it. After rebooting I got the “failed to start simple desktop display manager”
Tried to remove it by sudo rm /etc/X11/xorg.conf.d/20-intel.conf
Nothing worked. Any ideas ?
Kernel: 5.7.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
root=UUID=c07ba933-150a-4940-a99f-727cf4261180 rw quiet apparmor=1
security=apparmor resume=UUID=20cad62b-128d-46e4-8620-42ac3fe30f0d
udev.log_priority=3
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20RW v: Lenovo ThinkBook 15-IML
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: LVA/LVAB v: NO DPK serial: <filter> UEFI: LENOVO
v: CJCN29WW date: 06/19/2020
ID-1: BAT1 charge: 44.9 Wh condition: 44.9/45.0 Wh (100%)
volts: 13.0/11.5 model: Celxpert L19C3PF1 type: Li-poly
serial: <filter> status: Full cycles: 22
RAM: total: 3.36 GiB used: 1.50 GiB (44.6%)
RAM Report:
Topology: Quad Core model: Intel Core i5-10210U bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 8E (142) stepping: C (12)
microcode: D6 L2 cache: 6144 KiB bogomips: 33615
Speed: 900 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 900 2: 900
3: 900 4: 900 5: 900 6: 900 7: 900 8: 901
clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d
fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb
ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca
mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: spectre_v2
mitigation: Enhanced IBRS, IBPB: conditional, RSB filling
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:9b41
Device-2: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo
bus ID: 1-6:4 chip ID: 5986:2113
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11
driver: modesetting alternate: fbdev,intel,vesa display ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.1.7
direct render: Yes
Device-1: Intel vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:02c8
Sound Server: ALSA v: k5.7.19-2-MANJARO
vendor: Lenovo driver: r8168 v: 8.048.03-NAPI modules: r8169
port: 3000 bus ID: 01:00.0 chip ID: 10ec:8168
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Realtek vendor: Lenovo driver: N/A port: 2000
bus ID: 02:00.0 chip ID: 10ec:c82f
Local Storage: total: 931.51 GiB used: 8.69 GiB (0.9%)
ID-1: /dev/sda vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 0E scheme: GPT
ID-1: / raw size: 923.83 GiB size: 908.32 GiB (98.32%)
used: 8.69 GiB (1.0%) fs: ext4 dev: /dev/sda2 label: N/A
uuid: c07ba933-150a-4940-a99f-727cf4261180
ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%)
used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 label: N/A
uuid: F09A-9364
ID-1: swap-1 type: partition size: 7.39 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3 label: N/A
uuid: 20cad62b-128d-46e4-8620-42ac3fe30f0d
Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-3:2 info: ASUSTek ROG STRIX IMPACT type: Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
chip ID: 0b05:1847
Device-2: 1-5:3 info: Shenzhen Goodix Goodix FingerPrint Device
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
speed: 480 Mb/s chip ID: 27c6:55a4
Device-3: 1-6:4 info: Acer SunplusIT Integrated Camera type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 5986:2113
Device-4: 1-10:5 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s chip ID: 0bda:c02f
serial: <filter>
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1
speed: 10 Gb/s chip ID: 1d6b:0003
System Temperatures: cpu: 41.0 C mobo: N/A
Processes: 208 Uptime: 2h 37m Init: systemd v: 246 Compilers:
gcc: 10.2.0 Packages: pacman: 1175 lib: 313 flatpak: 0 Shell: Bash
v: 5.0.18 running in: konsole inxi: 3.1.05
