Hello everyone!
After the last stable update, I have a problem loading to the system - it says that sddm failed to start.
Here’s my inxi
output:
Kernel: 5.10.36-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/timeshift-btrfs/snapshots/2021-06-03_21-00-01/@/boot/vmlinuz-5.10-x86_64
root=UUID=4e87c48a-f30f-4e16-b859-92daed76eadd quiet apparmor=1
rootflags=defaults,noatime,space_cache,subvol=timeshift-btrfs/snapshots/2021-06-03_21-00-01/@
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Gigabyte model: B450 GAMING X v: x.x serial: <filter>
UEFI: American Megatrends LLC. v: F61a date: 03/29/2021
RAM: total: 15.64 GiB used: 3.99 GiB (25.5%)
Info: 6-Core model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L2: 3 MiB bogomips: 91056
Speed: 2043 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz):
1: 2043 2: 3815 3: 2018 4: 3323 5: 2379 6: 2201 7: 2178 8: 3454 9: 2208
10: 2114 11: 2217 12: 2290
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload
vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
conditional, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 07:00.0 chip-ID: 1002:67df
class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3280x1920 s-dpi: 96 s-size: 865x506mm (34.1x19.9")
s-diag: 1002mm (39.5")
Monitor-1: HDMI-A-0 res: 1920x1080 dpi: 102 size: 476x268mm (18.7x10.6")
diag: 546mm (21.5")
Monitor-2: HDMI-A-1 res: 1080x1920 hz: 60
OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.40.0
5.10.36-2-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.3 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 07:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 09:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.10.36-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: yes
vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 04:00.0
Local Storage: total: 1.94 TiB used: 368.83 GiB (18.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Smartbuy
model: m.2 PS5013-2280T 128GB size: 119.24 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: EDFM00.5 temp: 23.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPSX-00A6WT0
rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-08WN4A0
rotation: 7200 rpm serial: <filter> rev: 1A02 scheme: GPT
ID-1: / raw-size: 39.24 GiB size: 39.24 GiB (100.00%) used: 24.1 GiB (61.4%)
fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 4e87c48a-f30f-4e16-b859-92daed76eadd
used: 25.8 MiB (26.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: A05E-CA45
ID-3: /home raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 344.7 GiB (37.0%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: ec60da22-506d-4595-9155-dfc59d5f6c77
ID-4: /run/timeshift/backup raw-size: 39.24 GiB size: 39.24 GiB (100.00%)
used: 24.1 GiB (61.4%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 4e87c48a-f30f-4e16-b859-92daed76eadd
ID-5: /var/cache raw-size: 39.24 GiB size: 39.24 GiB (100.00%)
ID-6: /var/log raw-size: 39.24 GiB size: 39.24 GiB (100.00%)
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 79.38 GiB fs: ntfs label: N/A
uuid: 540865B108659332
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 516 MiB fs: ntfs label: N/A
uuid: 2E00C77300C74117
ID-4: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-5: /dev/sda2 maj-min: 8:2 size: 931.5 GiB fs: ntfs label: Games
uuid: 9A4C52934C5269D1
Device-1: 1-5:2 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
Device-2: 1-6:3 info: Microdia Redragon Mitra RGB Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 400mA chip-ID: 0c45:5004 class-ID: 0301
Device-3: 1-8:4 info: Integrated Express IT8297 RGB LED Controller
type: Keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 048d:8297 class-ID: 0301
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 44.4 C mobo: 16.8 C gpu: amdgpu temp: 39.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1177
Processes: 370 Uptime: 19m wakeups: 0 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1524 pacman: 1515 lib: 459
flatpak: 9 Shell: fish v: 3.2.2 running-in: konsole inxi: 3.3.04
I’ve found some previous post about that problem, but I have only 1 GPU and CPU without an integrated GPU.
For now, I’m able to use my system by loading a snapshot.
