But that line isn’t even needed, see the discussion I linked to.
Without checking the link, I presume it was @Aragorn’s post; which I tend to agree with. which doesn’t detract from my comment, regardless of whether its needed. However, I still don’t understand the OP’s apparent need for the mask.
On the possibility of delay mounting: This could be a job for @scotty65 who seems to enjoy a scripting challenge.
It’s a default, created by some utilities — possibly some partition manager, or calamares.
If the drive is removable, then I would certainly also add nofail. Saves the system from stalling if polling the drive times out. ![]()
Opening another avenue of investigation, I just found this:
… which might possibly be related, given the timeframe.
I’m afraid that I have no experience at all in mounting disks - my PC has 1 internal HDD & 1 external HDD that is mounted by Plasma upon login. And I am still quite inexperienced with systemd - I can write a timer to run a job as a user, but I’ve never written anything to do with the system.
These links may help (if you haven’t already had a look at them):
For clarity’s sake: the disks do get mounted. I can access all data on them, and mount -a confirms this by not making any changes.
The problem is that Manjaro seems to think that my internal disks are removables, like USB sticks or something, and that the mount service doesn’t start.
As a result, accessing the disks consumes several seconds.
Since the possibility is that there is simply a timeout,
Scroll up even further. ![]()
Nope. That’s why I added the quote. Makes scrolling unnecessary. ![]()
I’d need to find out why the media-mount service doesn’t start, or why Manjaro thinks that my hard disks are external. That is the actual culprit, I think.
What’s the output of:
systemctl list-units | grep --ignore-case sda
systemctl list-units | grep --ignore-case sda gives:
sys-devices-pci0000:00-0000:00:02.1-0000:02:00.1-ata1-host0-target0:0:0-0:0:0:0-block-sda-sda1.device loaded active plugged TOSHIBA_MG09ACA18TE 1
sys-devices-pci0000:00-0000:00:02.1-0000:02:00.1-ata1-host0-target0:0:0-0:0:0:0-block-sda-sda2.device loaded active plugged TOSHIBA_MG09ACA18TE 2
sys-devices-pci0000:00-0000:00:02.1-0000:02:00.1-ata1-host0-target0:0:0-0:0:0:0-block-sda-sda3.device loaded active plugged TOSHIBA_MG09ACA18TE 3
sys-devices-pci0000:00-0000:00:02.1-0000:02:00.1-ata1-host0-target0:0:0-0:0:0:0-block-sda-sda4.device loaded active plugged TOSHIBA_MG09ACA18TE 4
sys-devices-pci0000:00-0000:00:02.1-0000:02:00.1-ata1-host0-target0:0:0-0:0:0:0-block-sda.device loaded active plugged TOSHIBA_MG09ACA18TE
● media-mount@sda1.service loaded failed failed Mount removable media on sda1
● media-mount@sda2.service loaded failed failed Mount removable media on sda2
● media-mount@sda3.service loaded failed failed Mount removable media on sda3
● media-mount@sda4.service loaded failed failed Mount removable media on sda4
I re-installed the system, and the problem is over now.
Another rather minor issue popped up, but I’ll start a new thread about it later, since it’s totally not related to this one.
The drives are now showing as internal; is that right?
