You wanted to uninstall Qt while the system was updating ?
Please don’t do random stuff in regard with update and uninstall if you want to keep your system functional!
From a chrooted system might still use outdated mirrors. Try with: sudo pacman-mirrors -f5 && sudo pacman -Syyu
try to reinstall the video driver from TTY: sudo mhwd -f -i pci video-nvidia
and since you did not share on what kernel version you tried to boot and got the errors, i would suggest to also install another kernel: sudo mhwd-kernel -i linux510 sudo mhwd-kernel -i linux54
apa-pc login: rpirela
Password:
Last login: Tue Jan 19 21:51:03 on tty2
[rpirela@papa-pc 1$ sudo mhud -f -i pci video-nvidia
[sudol password for rpirela:
Installing video-nuidia…
Using default
Has lib32 support: true
Sourcing rvar/lib/mhud/db/pci/graphic_drivers/nvidia MHUDCONFIG
Processing classid: 0300
Sourcing Muar/lib/mhud/scripts/include/0300
Processing classid: 0302
core is up to date
downloading extra.db…
warning: lib32-nuidia-utils-460.32.03-1 is up to date – skipping
Community is up to date
multilib is up to date
resolving dependencies…
:: nuidia-utils and nu idia-430xx-utils are in conflict (nuidia-libg!). Renove
age conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: nuidia-utils and nuidia-430xx-utils are in conflict
Error: pacman failed!
Error: script failed!
Crpirela@papa-pc 1$
