Failed to start Load Kernel Modules after a wrong shutdown
Hello,
yesterday I was using Manjaro KDE on my pc when the system turned off because the battery was low.
Since these moment, at every boot I see the string like if it isn't in quite boot mode (I don't now the correcto name:joy:).
It say me to run command systemctl status systemd-modules-load.service, and this is what does it says...
[realsaaw@Samuele-PC ~]$ systemctl status systemd-modules-load.service
● systemd-modules-load.service - Load Kernel Modules
   Loaded: loaded (/usr/lib/systemd/system/systemd-modules-load.service; static; vendor preset: disabled)
   Active: failed (Result: exit-code) since Mon 2019-09-23 21:43:43 CEST; 6min ago
     Docs: man:systemd-modules-load.service(8)
           man:modules-load.d(5)
  Process: 444 ExecStart=/usr/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
 Main PID: 444 (code=exited, status=1/FAILURE)
set 23 21:43:43 Samuele-PC systemd[1]: Starting Load Kernel Modules...
set 23 21:43:43 Samuele-PC systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
set 23 21:43:43 Samuele-PC systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
set 23 21:43:43 Samuele-PC systemd[1]: Failed to start Load Kernel Modules.
What can I do?
I tried:
pacman -Syyu
mhwd-kernel -i linux51
mhwd-kernel -i linux52
mhwd-kernel -i linux414
Thank youuu
Plenty of existing threads. Please search first.
If none of these existing threads help then feel free to post about what you're having difficulty with.
https://forum.manjaro.org/search?q=failed%20to%20start%20load%20kernel%20module
Try
sudo mkinitcpio -P
sudo update-grub
Don't avoid reading the posted topics though.
Solve with the following commands
sudo pacman-mirrors -f5
wait for that command to finish. Then
sudo pacman -Syyu
The I installed package for kernel.
sudo pacman -S linux419
After install:
sudo update-grub
Then reboot and the kernel works best
Thank you for who spend their time for me<3
I hope this can help someother!
