Failed to start Live-System on Ryzen/RX550
amd
kde
#1
I have a new pc and want to install the latest KDE-Release of Manjaro. But the start of the Live-System end with the message
Started TLP system startup/shutdown
Here are the specifications of my pc:
Mainboard: MSI X370 SLI Plus
CPU: AMD Ryzen 7 1700
GPU: Sapphire Pulse Radeon RX 550 4GD5
SSD: Crucial MX300
Here is the link to my inxi-output: Dump your inxi -Fxzc0 here and bookmark it
I tried the KDE versions 17.0.3, 17.0.4 and 17.0.5 after burning on DVD. I also tried KDE version 17.0.5 on USB-Stick and XFCE version 17.0.3 on DVD. The behavior is the same.
I found on this forum similar issues and tried the following boot-parameter (one after the other, not all together):
radeon-drm.modeset=1
acpi_osi=! acpi_osi="Windows 2009"
xdriver=vesa
systemd.mask=mhwd-live.service radeon.modeset=0
All starts ends with the TLP-message or a blackscreen.
To my opinion the GPU should work with Manjaro. Can someone give me a hint, what I can try to solve the issue?
The installation of Windows 10 and Ubuntu Gnome 17.04 runs without issues. But I want to use Manjaro, as on my old PC.
Thanks in advance.
Matthias
Update running Manjaro 17.x with a Sapphire RX550
#2
Hello,
If you can please include this command in your post. It will help everyone in knowing exactly what type of equipment you have. I know you posted it, but this give a lot more information.
#3
@yawanthan, done.
Matthias
#4
the creation of the boot medium makes a huge difference. Tools like YUMI or others will not produce working boot sticks.
SuSe imagewriter is working without issues though.
#5
I use
dd bs=4M if=/mnt/DS/public/manjaro-kde-17.0.5-stable-x86_64.iso of=/dev/sdc status=progress
to create the USB-stick and K3B to create the DVDs.
I have no SuSe-installation and so cannot use SuSe imagewriter. Besides, the USB-stick and the DVDs boot without problems. Only the start of graphical system don’t work.
Matthias
#6
the imagewriter is available in a lot of distributions. It is not Suse-only
dd however should also work. not sure what the problem is in that case, then
#7
Have you tried both “free” and “nonfree” options from the boot screen?
#8
the nonfree driver is non-existent on all RX graphic cards :wink:
That could be a reason.
#9
Don’t own an RX card, so had no idea.
But the option might still be in the boot menu, så make sure it’s booting with “free” option.
#10
I tried both “free” and “nonfree”. It makes no difference.
Matthias
#11
Another information:
The cursor is blinking fast, when reach the message “Started TLP system startup/shutdown”. A reboot is possible with STRG+ALT+ENTF. Switch to another console is possible, but no interaction. I cannot login for example because the keyboard is not working correct.
Matthias
#12
I start the Live-system with parameter 3 and so have only a console. I create in this environment again the inxi-output: Dump your inxi -Fxzc0 here and bookmark it
And I try “startx”. It fails, but here is the Xorg.log.0:
[   627.627]
X.Org X Server 1.19.3
Release Date: 2017-03-15
[   627.634] X Protocol Version 11, Revision 0
[   627.636] Build Operating System: Linux 4.12.5-1-ARCH x86_64
[   627.638] Current Operating System: Linux manjaro 4.9.50-1-MANJARO #1 SMP PREEMPT Thu Sep 14 09:07:15 UTC 2017 x86_64
[   627.638] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 3 lang=de_DE keytable=de tz=Europe/Berlin driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 misobasedir=manjaro misolabel=MJRO1705 quiet systemd.show_status=1
[   627.646] Build Date: 13 August 2017  09:37:50PM
[   627.648]
[   627.650] Current version of pixman: 0.34.0
[   627.655] 	Before reporting problems, check http://wiki.x.org
[   627.655] Markers: (--) probed, (**) from config file, (==) default setting,
[   627.665] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Sep 20 15:18:53 2017
[   627.667] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   627.670] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   627.670] (==) No Layout section.  Using the first Screen section.
[   627.670] (==) No screen section available. Using defaults.
[   627.670] (**) |-->Screen "Default Screen Section" (0)
[   627.670] (**) |   |-->Monitor "<default monitor>"
[   627.670] (==) No monitor specified for screen "Default Screen Section".
[   627.670] (==) Automatically adding devices
[   627.670] (==) Automatically enabling devices
[   627.670] (==) Automatically adding GPU devices
[   627.670] (==) Automatically binding GPU devices
[   627.670] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   627.670] (WW) The directory "/usr/share/fonts/Type1/" does not exist.
[   627.670] 	Entry deleted from font path.
[   627.670] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[   627.670] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[   627.670] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[   627.670] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[   627.670] (==) FontPath set to:
	/usr/share/fonts/misc/,
	/usr/share/fonts/TTF/,
	/usr/share/fonts/OTF/
[   627.670] (==) ModulePath set to "/usr/lib/xorg/modules"
[   627.670] (II) The server relies on udev to provide the list of input devices.
[   627.670] (II) Loader magic: 0x562476c08d40
[   627.670] (II) Module ABI versions:
[   627.670] 	X.Org ANSI C Emulation: 0.4
[   627.670] 	X.Org Video Driver: 23.0
[   627.670] 	X.Org XInput driver : 24.1
[   627.670] 	X.Org Server Extension : 10.0
[   627.671] (++) using VT number 1
[   627.671] (--) controlling tty is VT number 1, auto-enabling KeepTty
[   627.673] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c1
[   627.678] (--) PCI:*(0:35:0:0) 1002:699f:1da2:e367 rev 199, Mem @ 0xe0000000/268435456, 0xf0000000/2097152, 0xfe900000/262144, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[   627.678] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[   627.678] (II) LoadModule: "glx"
[   627.678] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   627.679] (II) Module glx: vendor="X.Org Foundation"
[   627.679] 	compiled for 1.19.3, module version = 1.0.0
[   627.679] 	ABI class: X.Org Server Extension, version 10.0
[   627.679] (==) Matched ati as autoconfigured driver 0
[   627.679] (==) Matched modesetting as autoconfigured driver 1
[   627.679] (==) Matched fbdev as autoconfigured driver 2
[   627.679] (==) Matched vesa as autoconfigured driver 3
[   627.679] (==) Assigned the driver to the xf86ConfigLayout
[   627.679] (II) LoadModule: "ati"
[   627.679] (WW) Warning, couldn't open module ati
[   627.679] (II) UnloadModule: "ati"
[   627.679] (II) Unloading ati
[   627.679] (EE) Failed to load module "ati" (module does not exist, 0)
[   627.679] (II) LoadModule: "modesetting"
[   627.680] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[   627.680] (II) Module modesetting: vendor="X.Org Foundation"
[   627.680] 	compiled for 1.19.3, module version = 1.19.3
[   627.680] 	Module class: X.Org Video Driver
[   627.680] 	ABI class: X.Org Video Driver, version 23.0
[   627.680] (II) LoadModule: "fbdev"
[   627.680] (WW) Warning, couldn't open module fbdev
[   627.680] (II) UnloadModule: "fbdev"
[   627.680] (II) Unloading fbdev
[   627.680] (EE) Failed to load module "fbdev" (module does not exist, 0)
[   627.680] (II) LoadModule: "vesa"
[   627.680] (WW) Warning, couldn't open module vesa
[   627.680] (II) UnloadModule: "vesa"
[   627.680] (II) Unloading vesa
[   627.680] (EE) Failed to load module "vesa" (module does not exist, 0)
[   627.680] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[   627.680] (EE) open /dev/dri/card0: No such file or directory
[   627.680] (WW) Falling back to old probe method for modesetting
[   627.680] (EE) Screen 0 deleted because of no matching config section.
[   627.680] (II) UnloadModule: "modesetting"
[   627.680] (EE) Device(s) detected, but none match those in the config file.
[   627.680] (EE)
Fatal server error:
[   627.680] (EE) no screens found(EE)
[   627.680] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[   627.680] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[   627.680] (EE)
[   627.688] (EE) Server terminated with error (1). Closing log file.
Matthias
#13
it looks like your system does try to load the ati driver, which is not compatible with AMD RX cards and then decides to load no driver at all, not even modesetting.
You would need to force the system to use amdgpu driver, but I am not sure how one can do that.
@philm is that a general error in the install media?
#14
I try with parameter xdriver=amdgpu, but this ends too with the message “Started TLP system startup/shutdown”.
Matthias
#15
grep -i "amdgpu" /proc/modules
grep -i "radeon" /proc/modules
please. The kernel module is important and thats what xorg asks for, when deciding if ati or amdgpu. Also please the output of
mhwd
lspci -nnk | grep -i VGA -A2
#16
grep -i “amdgpu” /proc/modules
and
grep -i “radeon” /proc/modules
give both no output.
Output of mhwd:
e[1me[31m> e[m0000:1e:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2016.04.20                true            PCI
e[1me[31m> e[m0000:23:00.0 (0300:1002:699f) Display controller ATI Technologies Inc:
          video-amdgpu            2017.03.24                true            PCI
Output of lspci -nnk | grep -i VGA -A2:
23:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Lexa PRO [Radeon RX 550] [1002:699f] (rev c7)
	Subsystem: Sapphire Technology Limited Device [1da2:e367]
23:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:aae0]
I try to load module amdgpu with
modprobe amdgpu
and the try grep -i “amdgpu” /proc/modules. This is the output:
amdgpu 1495040 0 - Live 0xffffffffa0601000
ttm 86016 1 amdgpu, Live 0xffffffffa05e0000
drm_kms_helper 126976 1 amdgpu, Live 0xffffffffa05ae000
drm 294912 3 amdgpu,ttm,drm_kms_helper, Live 0xffffffffa0544000
i2c_algo_bit 16384 1 amdgpu, Live 0xffffffffa036b000
After that I try startx. It fails, but here is the log:
[  1558.441]
[  1558.445] X Protocol Version 11, Revision 0
[  1558.447] Build Operating System: Linux 4.12.5-1-ARCH x86_64
[  1558.449] Current Operating System: Linux manjaro 4.9.50-1-MANJARO #1 SMP PREEMPT Thu Sep 14 09:07:15 UTC 2017 x86_64
[  1558.449] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 3 lang=de_DE keytable=de tz=Europe/Berlin driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 misobasedir=manjaro misolabel=MJRO1705 quiet systemd.show_status=1
[  1558.454] Build Date: 13 August 2017  09:37:50PM
[  1558.455]
[  1558.457] Current version of pixman: 0.34.0
[  1558.460] 	Before reporting problems, check http://wiki.x.org
[  1558.460] Markers: (--) probed, (**) from config file, (==) default setting,
[  1558.467] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Sep 21 11:16:35 2017
[  1558.470] (==) Using config directory: "/etc/X11/xorg.conf.d"
[  1558.472] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[  1558.472] (==) No Layout section.  Using the first Screen section.
[  1558.472] (==) No screen section available. Using defaults.
[  1558.472] (**) |-->Screen "Default Screen Section" (0)
[  1558.472] (**) |   |-->Monitor "<default monitor>"
[  1558.472] (==) No monitor specified for screen "Default Screen Section".
[  1558.472] (==) Automatically adding devices
[  1558.472] (==) Automatically enabling devices
[  1558.472] (==) Automatically adding GPU devices
[  1558.472] (==) Automatically binding GPU devices
[  1558.472] (==) Max clients allowed: 256, resource mask: 0x1fffff
[  1558.472] (WW) The directory "/usr/share/fonts/Type1/" does not exist.
[  1558.472] 	Entry deleted from font path.
[  1558.472] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[  1558.472] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[  1558.472] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[  1558.472] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[  1558.472] (==) FontPath set to:
[  1558.472] (==) ModulePath set to "/usr/lib/xorg/modules"
[  1558.472] (II) The server relies on udev to provide the list of input devices.
[  1558.472] (II) Loader magic: 0x5564fef04d40
[  1558.472] (II) Module ABI versions:
[  1558.472] 	X.Org ANSI C Emulation: 0.4
[  1558.472] 	X.Org Video Driver: 23.0
[  1558.472] 	X.Org XInput driver : 24.1
[  1558.472] 	X.Org Server Extension : 10.0
[  1558.473] (++) using VT number 1
[  1558.473] (--) controlling tty is VT number 1, auto-enabling KeepTty
[  1558.475] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c1
[  1558.480] (--) PCI:*(0:35:0:0) 1002:699f:1da2:e367 rev 199, Mem @ 0xe0000000/268435456, 0xf0000000/2097152, 0xfe900000/262144, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[  1558.480] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[  1558.480] (II) LoadModule: "glx"
[  1558.481] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[  1558.482] (II) Module glx: vendor="X.Org Foundation"
[  1558.482] 	compiled for 1.19.3, module version = 1.0.0
[  1558.482] 	ABI class: X.Org Server Extension, version 10.0
[  1558.482] (==) Matched ati as autoconfigured driver 0
[  1558.482] (==) Matched modesetting as autoconfigured driver 1
[  1558.482] (==) Matched fbdev as autoconfigured driver 2
[  1558.482] (==) Matched vesa as autoconfigured driver 3
[  1558.482] (==) Assigned the driver to the xf86ConfigLayout
[  1558.482] (II) LoadModule: "ati"
[  1558.483] (WW) Warning, couldn't open module ati
[  1558.483] (II) UnloadModule: "ati"
[  1558.483] (II) Unloading ati
[  1558.483] (EE) Failed to load module "ati" (module does not exist, 0)
[  1558.483] (II) LoadModule: "modesetting"
[  1558.483] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[  1558.483] (II) Module modesetting: vendor="X.Org Foundation"
[  1558.483] 	compiled for 1.19.3, module version = 1.19.3
[  1558.483] 	Module class: X.Org Video Driver
[  1558.483] 	ABI class: X.Org Video Driver, version 23.0
[  1558.483] (II) LoadModule: "fbdev"
[  1558.483] (WW) Warning, couldn't open module fbdev
[  1558.483] (II) UnloadModule: "fbdev"
[  1558.483] (II) Unloading fbdev
[  1558.483] (EE) Failed to load module "fbdev" (module does not exist, 0)
[  1558.483] (II) LoadModule: "vesa"
[  1558.483] (WW) Warning, couldn't open module vesa
[  1558.483] (II) UnloadModule: "vesa"
[  1558.483] (II) Unloading vesa
[  1558.483] (EE) Failed to load module "vesa" (module does not exist, 0)
[  1558.483] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[  1558.483] (EE) open /dev/dri/card0: No such file or directory
[  1558.483] (WW) Falling back to old probe method for modesetting
[  1558.483] (EE) Screen 0 deleted because of no matching config section.
[  1558.483] (II) UnloadModule: "modesetting"
[  1558.483] (EE) Device(s) detected, but none match those in the config file.
[  1558.483] (EE)
Fatal server error:
[  1558.484] (EE) no screens found(EE)
[  1558.484] (EE)
 for help.
[  1558.484] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[  1558.484] (EE)
[  1558.490] (EE) Server terminated with error (1). Closing log file.
Matthias
#17
you cant do that, it needs to load itself at boottime to make KMS (kerne based modesettings) work.
journalctl -b -p err
would be interesting to see. Seems like you system just dont loads up any driver, but still shows that card
#18
Here is the output from journalctl -b -p err:
-- Logs begin at Thu 2017-09-21 11:43:38 CEST, end at Thu 2017-09-21 11:45:03 CEST. --
Sep 21 11:43:39 manjaro kernel: sp5100_tco: I/O address 0x0cd6 already in use
Sep 21 11:43:43 manjaro ntpd[986]: bind(21) AF_INET6 fe80::554a:5dd3:1831:57f8%2#123 flags 0x11 failed: Cannot assign requested address
Sep 21 11:43:43 manjaro ntpd[986]: unable to create socket on enp30s0 (5) for fe80::554a:5dd3:1831:57f8%2#123
Matthias
#19
also nothing related to amdgpu …
Is it the latest version of the manjaro live images 17.0.5?
Sapphire rx 550
#20
Yes, I create a bootable USB-stick from manjaro-kde-17.0.5-stable-x86_64.iso and make the lasts tests with this.
Matthias
