Hello,
I’ve updated my system yesterday and after turning it on today I got “greeted” with a “Failed to start Light Display Manager.” message.
Running sudo lightdm
manually does work and other than there’s no output sound device detected, everything else works normally.
The lightdm
service is not running and if I try starting it I get the following:
journalctl -xeu lightdm.service
░░ A start job for unit lightdm.service has begun execution.
░░ The job identifier is 2677.
ago 31 08:33:16 fermin-e590 lightdm[2492]: Failed to use bus name org.freedesktop.DisplayManager, do you have appropriate permissions?
ago 31 08:33:16 fermin-e590 systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
░░ Subject: Unit process exited
░░ Defined-By: systemd
░░ An ExecStart= process belonging to unit lightdm.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
ago 31 08:33:16 fermin-e590 systemd[1]: lightdm.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ The unit lightdm.service has entered the 'failed' state with result 'exit-code'.
ago 31 08:33:16 fermin-e590 systemd[1]: Failed to start Light Display Manager.
░░ Subject: A start job for unit lightdm.service has failed
░░ A start job for unit lightdm.service has finished with a failure.
░░ The job identifier is 2677 and the job result is failed.
ago 31 08:33:17 fermin-e590 systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 5.
░░ Subject: Automatic restarting of a unit has been scheduled
░░ Automatic restarting of the unit lightdm.service has been scheduled, as the result for
░░ the configured Restart= setting for the unit.
ago 31 08:33:17 fermin-e590 systemd[1]: Stopped Light Display Manager.
░░ Subject: A stop job for unit lightdm.service has finished
░░ A stop job for unit lightdm.service has finished.
░░ The job identifier is 2764 and the job result is done.
ago 31 08:33:17 fermin-e590 systemd[1]: lightdm.service: Start request repeated too quickly.
ago 31 08:33:17 fermin-e590 systemd[1]: lightdm.service: Failed with result 'exit-code'.
ago 31 08:33:17 fermin-e590 systemd[1]: Failed to start Light Display Manager.
░░ The job identifier is 2764 and the job result is failed.
inxi
Kernel: 5.10.60-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=df7a105e-6ebc-4a94-bb06-ba9156e9161c rw quiet apparmor=1
security=apparmor resume=UUID=bd9d7dac-f62e-4ec5-bc1d-7a6957726858
udev.log_priority=3
Desktop: Cinnamon 5.0.5 tk: GTK 3.24.30 vt: 7 dm: LightDM 1.30.0
Type: Laptop System: LENOVO product: 20NB001SUS v: ThinkPad E590
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20NB001SUS v: SDK0J40697 WIN serial: <filter>
UEFI: LENOVO v: R0YET36W (1.19 ) date: 10/21/2019
ID-1: BAT0 charge: 31.1 Wh (81.0%) condition: 38.4/45.7 Wh (83.9%)
volts: 11.5 min: 11.1 model: Celxpert 01AV448 type: Li-poly serial: <filter>
status: Discharging cycles: 272
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K330
status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse M560
serial: <filter> charge: 5% (should be ignored) rechargeable: yes
status: Discharging
RAM: total: 15.35 GiB used: 3.91 GiB (25.5%)
Info: Quad Core model: Intel Core i7-8565U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
microcode: EA cache: L2: 8 MiB bogomips: 32012
Speed: 700 MHz min/max: 400/4600 MHz Core speeds (MHz): 1: 700 2: 700 3: 700
4: 700 5: 700 6: 701 7: 700 8: 700
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-6:4 chip-ID: 5986:2113 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 driver: loaded: modesetting
alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.7x15.0")
s-diag: 1245mm (49")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
Monitor-2: HDMI-1 res: 2560x1440 hz: 60 dpi: 124
size: 526x296mm (20.7x11.7") diag: 604mm (23.8")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.10.60-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.33 running: no
vendor: Lenovo driver: r8168 v: 8.049.02-NAPI modules: r8169 port: 2000
bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: 2000
bus-ID: 05:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Local Storage: total: 476.94 GiB used: 278.07 GiB (58.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: 0108ADLA temp: 30.9 C scheme: GPT
ID-1: / raw-size: 459.75 GiB size: 451.53 GiB (98.21%)
used: 278.07 GiB (61.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: df7a105e-6ebc-4a94-bb06-ba9156e9161c
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 4879-6B7A
ID-1: swap-1 type: partition size: 16.89 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: bd9d7dac-f62e-4ec5-bc1d-7a6957726858
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-6:4 info: Acer SunplusIT Integrated Camera type: Video
Device-3: 1-8:5 info: Synaptics Metallica MOH Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 06cb:00a2 class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 44.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 0
Processes: 279 Uptime: 17m wakeups: 10 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1519 lib: 481 flatpak: 0
Shell: Bash v: 5.1.8 running-in: gnome-terminal inxi: 3.3.06
