Failed to start gnome display manager
System:    Kernel: 5.10.53-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: GNOME 40.3
Machine:   Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05 serial: <filter>
           Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <filter>
           UEFI-[Legacy]: LENOVO v: EUCN19WW date: 05/12/2020
Battery:   ID-1: BAT0 charge: 43.7 Wh (85.0%) condition: 51.4/60.0 Wh (85.6%) volts: 15.9
           min: 15.4 model: Celxpert L19C4PC0 status: Discharging
CPU:       Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
           arch: Zen 2 rev: 1 cache: L2: 4 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 92666
           Speed: 1614 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz): 1: 1614
           2: 1491 3: 1397 4: 1325 5: 1397 6: 1370 7: 1961 8: 2174 9: 2545 10: 2544 11: 1273
           12: 1284 13: 1272 14: 1271 15: 1396 16: 1401
Graphics:  Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo driver: nvidia
           v: 470.57.02 bus-ID: 01:00.0
           Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 05:00.0
           Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:2
           Display: server: X.org 1.20.11 driver: loaded: amdgpu,nvidia
           OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.53-1-MANJARO LLVM 12.0.1)
           v: 4.6 Mesa 21.1.5 direct render: Yes
Audio:     Device-1: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo driver: N/A
           bus-ID: 05:00.5
           Device-2: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
           bus-ID: 05:00.6
           Sound Server-1: ALSA v: k5.10.53-1-MANJARO running: yes
           Sound Server-4: PipeWire v: 0.3.32 running: no
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo
           driver: r8169 v: kernel port: 2000 bus-ID: 03:00.0
           Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000 bus-ID: 04:00.0
           IF: wlp4s0 state: down mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:3
           Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Drives:    Local Storage: total: 476.94 GiB used: 143.54 GiB (30.1%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2 size: 476.94 GiB
           temp: 40.9 C
Partition: ID-1: / size: 459.79 GiB used: 143.54 GiB (31.2%) fs: ext4 dev: /dev/nvme0n1p1
Swap:      ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p2
Sensors:   System Temperatures: cpu: 39.1 C mobo: N/A gpu: amdgpu temp: 37.0 C
Info:      Processes: 391 Uptime: 2m Memory: 15.07 GiB used: 3.3 GiB (21.9%) Init: systemd
           Compilers: gcc: 11.1.0 Packages: 1498 Client: shell wrapper v: 5.1.8-release
           inxi: 3.3.06
After the latest stable update, I boot up to a blank screen with a message that says “failed to start gnome display manager”. I’m able ALT+F2 and login from there. Is there a way to fix this?
Does reinstalling gdm help?
[* Never do any such thing without taking a backup first]
I’m was a little hesitant with your suggestion because I didn’t want to go through the hassle of restoring a backup. So I thought I’d try something that was in a help thread I had recently.
So, I’ve had a recurring issue with my system booting to a blank screen and had help on how to edit the gdm service. I tried reverting the edits with sudo systemctl revert gdm
So far it seems to be working. Will monitor if it happens again.
You should then mark your post as the solution. It would be helpful for others. :wink:
I wasn’t sure it would be a real fix. I no longer get the error message but my original problem of booting to a blank screen came back.
