Hi guys,
I installed timeshift and pacman updates bunch of stuffs. After the updating, my VLC and qv2ray cant run.
I tried to reinstall VLC and qv2ray, but still can’t run them.
Here is the gdb result of VLC
[zgldh@zgldh-manjaro ~]$ gdb vlc
GNU gdb (GDB) 10.1
Copyright (C) 2020 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "x86_64-pc-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<https://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from vlc...
(No debugging symbols found in vlc)
(gdb) run
Starting program: /usr/bin/vlc
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/usr/lib/libthread_db.so.1".
VLC media player 3.0.12 Vetinari (revision 3.0.12-1-0-gd147bb5e7e)
[New Thread 0x7ffff46fe640 (LWP 3724)]
[New Thread 0x7fffef8d8640 (LWP 3725)]
[New Thread 0x7fffef7d7640 (LWP 3726)]
[000055555555b680] main libvlc: 正在以默认界面运行 vlc。使用“cvlc”可以无界面模式使用 vlc。
[New Thread 0x7fffeda44640 (LWP 3727)]
[New Thread 0x7fffed58d640 (LWP 3728)]
[New Thread 0x7fffecac3640 (LWP 3729)]
Thread 5 "vlc" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fffeda44640 (LWP 3727)]
0x00007fffee388e52 in ?? () from /usr/lib/libQt5Core.so.5
(gdb) bt
#0 0x00007fffee388e52 in ?? () from /usr/lib/libQt5Core.so.5
#1 0x00007fffee389716 in ?? () from /usr/lib/libQt5Core.so.5
#2 0x00007fffee3b6e9c in ?? () from /usr/lib/libQt5Core.so.5
#3 0x00007fffee3ba779 in QTextStream::readLineInto(QString*, long long) () from /usr/lib/libQt5Core.so.5
#4 0x00007fffee3baa11 in QTextStream::readLine(long long) () from /usr/lib/libQt5Core.so.5
#5 0x00007fffecc719f2 in DPluginLoader::resolveFromPSM(QString const&) () from /usr/lib/qt/plugins/imageformats/libdsvg.so
#6 0x00007fffecc724ca in QImageIOPlugin* DPluginLoader::load<QImageIOPlugin>(QString const&) () from /usr/lib/qt/plugins/imageformats/libdsvg.so
#7 0x00007fffecc713aa in QSvgPlugin::QSvgPlugin(QObject*) () from /usr/lib/qt/plugins/imageformats/libdsvg.so
#8 0x00007fffecc71499 in qt_plugin_instance () from /usr/lib/qt/plugins/imageformats/libdsvg.so
#9 0x00007fffee322590 in ?? () from /usr/lib/libQt5Core.so.5
#10 0x00007fffecc71f90 in QImageIOPlugin* DPluginLoader::load<QImageIOPlugin>(QString const&) () from /usr/lib/qt/plugins/imageformats/libdsvg.so
#11 0x00007fffecc713aa in QSvgPlugin::QSvgPlugin(QObject*) () from /usr/lib/qt/plugins/imageformats/libdsvg.so
#12 0x00007fffecc71499 in qt_plugin_instance () from /usr/lib/qt/plugins/imageformats/libdsvg.so
#13 0x00007fffee322590 in ?? () from /usr/lib/libQt5Core.so.5
(thousands of same lines from #10 to #13)
#9498 0x00007fffecc71f90 in QImageIOPlugin* DPluginLoader::load<QImageIOPlugin>(QString const&) () from /usr/lib/qt/plugins/imageformats/libdsvg.so
#9499 0x00007fffecc713aa in QSvgPlugin::QSvgPlugin(QObject*) () from /usr/lib/qt/plugins/imageformats/libdsvg.so
#9500 0x00007fffecc71499 in qt_plugin_instance () from /usr/lib/qt/plugins/imageformats/libdsvg.so
#9501 0x00007fffee322590 in ?? () from /usr/lib/libQt5Core.so.5
#9502 0x00007fffee315a5e in QFactoryLoader::instance(int) const () from /usr/lib/libQt5Core.so.5
#9503 0x00007fffee774a73 in ?? () from /usr/lib/libQt5Gui.so.5
#9504 0x00007fffee775be4 in ?? () from /usr/lib/libQt5Gui.so.5
#9505 0x00007fffee77606f in QImageReader::format() const () from /usr/lib/libQt5Gui.so.5
#9506 0x00007fffee798912 in QPixmapIconEngine::addFile(QString const&, QSize const&, QIcon::Mode, QIcon::State) () from /usr/lib/libQt5Gui.so.5
#9507 0x00007fffee79b6fb in QIcon::addFile(QString const&, QSize const&, QIcon::Mode, QIcon::State) () from /usr/lib/libQt5Gui.so.5
#9508 0x00007fffee79bbe7 in QIcon::QIcon(QString const&) () from /usr/lib/libQt5Gui.so.5
#9509 0x00007fffef417a33 in ?? () from /usr/lib/vlc/plugins/gui/libqt_plugin.so
#9510 0x00007fffef418846 in ?? () from /usr/lib/vlc/plugins/gui/libqt_plugin.so
#9511 0x00007ffff7f50299 in start_thread () from /usr/lib/libpthread.so.0
#9512 0x00007ffff7e72053 in clone () from /usr/lib/libc.so.6
(gdb) exit
Undefined command: "exit". Try "help".
(gdb) quit
A debugging session is active.
Inferior 1 [process 3720] will be killed.
Quit anyway? (y or n) y
Then I reinstalled qt5-base and qt5-svg, but the issue still happen.
I tried the pacman -Syyu
, not working.
Anybody could give me some advise? Many thanks!
Here is the list of pacman updating
[2021-05-01T20:16:45+0800] [ALPM] installed timeshift (20.11.1.r3.g08d0e59-2)
[2021-05-01T20:16:45+0800] [ALPM] installed xapp (2.0.7-1)
[2021-05-01T20:16:45+0800] [ALPM] installed libgee (0.20.4-1)
[2021-05-01T20:16:45+0800] [ALPM] upgraded youtube-dl (2021.04.07-1 -> 2021.04.26-1)
[2021-05-01T20:16:44+0800] [ALPM] upgraded xerces-c (3.2.3-2 -> 3.2.3-3)
[2021-05-01T20:16:44+0800] [ALPM] upgraded wireguard-tools (1.0.20210315-1 -> 1.0.20210424-1)
[2021-05-01T20:16:44+0800] [ALPM] upgraded wine (6.6-1 -> 6.7-1)
[2021-05-01T20:16:36+0800] [ALPM] upgraded wildmidi (0.4.3-3 -> 0.4.4-1)
[2021-05-01T20:16:36+0800] [ALPM] upgraded widelands (21-4 -> 21-5)
[2021-05-01T20:16:27+0800] [ALPM] upgraded vulkan-radeon (21.0.1-1.0 -> 21.0.3-2)
[2021-05-01T20:16:27+0800] [ALPM] upgraded vulkan-intel (21.0.1-1.0 -> 21.0.3-2)
[2021-05-01T20:16:27+0800] [ALPM] upgraded vim (8.2.2653-1 -> 8.2.2814-1)
[2021-05-01T20:16:27+0800] [ALPM] upgraded vim-runtime (8.2.2653-1 -> 8.2.2814-1)
[2021-05-01T20:16:26+0800] [ALPM] upgraded ventoy (1.0.40-1 -> 1.0.41-1)
[2021-05-01T20:16:26+0800] [ALPM] upgraded v2ray-geoip (202104150006-1 -> 202104251437-1)
[2021-05-01T20:16:26+0800] [ALPM] upgraded v2ray-domain-list-community (20210415054336-1 -> 20210424190407-1)
[2021-05-01T20:16:26+0800] [ALPM] upgraded unarchiver (1.10.7-2 -> 1.10.7-3)
[2021-05-01T20:16:26+0800] [ALPM] upgraded tracker3 (3.1.1-1 -> 3.1.1-2)
[2021-05-01T20:16:26+0800] [ALPM] upgraded texlive-bin (2020.54586-12 -> 2020.54586-13)
[2021-05-01T20:16:25+0800] [ALPM] upgraded squashfs-tools (4.4-2 -> 4.4_git.1-1)
[2021-05-01T20:16:25+0800] [ALPM] upgraded spamassassin (3.4.5-1 -> 3.4.6-1)
[2021-05-01T20:16:25+0800] [ALPM] upgraded samba (4.14.2-1 -> 4.14.3-1)
[2021-05-01T20:16:24+0800] [ALPM] upgraded retroarch-assets-xmb (1:372-1 -> 1:376-1)
[2021-05-01T20:16:23+0800] [ALPM] upgraded qv2ray (2.6.3-23 -> 2.6.3-24)
[2021-05-01T20:16:23+0800] [ALPM] upgraded qt5ct (1.1-1 -> 1.2-1)
[2021-05-01T20:16:23+0800] [ALPM] upgraded qt5-webkit (5.212.0alpha4-9 -> 5.212.0alpha4-10)
[2021-05-01T20:16:22+0800] [ALPM] upgraded python2-zope-interface (5.3.0-1 -> 5.4.0-1)
[2021-05-01T20:16:22+0800] [ALPM] upgraded python2-yaml (5.4.1.1-1 -> 5.4.1.1-2)
[2021-05-01T20:16:22+0800] [ALPM] upgraded python-yaml (5.4.1.1-1 -> 5.4.1.1-2)
[2021-05-01T20:16:22+0800] [ALPM] upgraded python-twisted (21.2.0-2 -> 21.2.0-3)
[2021-05-01T20:16:22+0800] [ALPM] upgraded python-zope-interface (5.3.0-1 -> 5.4.0-1)
[2021-05-01T20:16:22+0800] [ALPM] upgraded python-pytools (2021.2.3-1 -> 2021.2.6-1)
[2021-05-01T20:16:22+0800] [ALPM] upgraded python-pillow (8.1.2-1 -> 8.2.0-1)
[2021-05-01T20:16:22+0800] [ALPM] upgraded python-pickleshare (0.7.5-5 -> 0.7.5-6)
[2021-05-01T20:16:21+0800] [ALPM] upgraded python-more-itertools (8.6.0-3 -> 8.7.0-1)
[2021-05-01T20:16:21+0800] [ALPM] upgraded python-importlib-metadata (3.7.3-1 -> 4.0.1-1)
[2021-05-01T20:16:21+0800] [ALPM] upgraded python-decorator (4.4.2-3 -> 4.4.2-4)
[2021-05-01T20:16:21+0800] [ALPM] upgraded python-dateutil (2.8.1-5 -> 2.8.1-6)
[2021-05-01T20:16:21+0800] [ALPM] upgraded pycharm-community-edition (2021.1-1 -> 2021.1.1-1)
[2021-05-01T20:16:16+0800] [ALPM] upgraded postman (8.2.3-1 -> 8.3.0-1)
[2021-05-01T20:16:10+0800] [ALPM] upgraded postgresql-libs (13.2-1 -> 13.2-2)
[2021-05-01T20:16:10+0800] [ALPM] upgraded php (8.0.3-1 -> 8.0.3-2)
[2021-05-01T20:16:09+0800] [ALPM] upgraded perl-xml-libxml (2.0206-1 -> 2.0207-1)
[2021-05-01T20:16:09+0800] [ALPM] upgraded perl-net-ssleay (1.88-2 -> 1.90-1)
[2021-05-01T20:16:09+0800] [ALPM] upgraded pamac-gtk (10.0.5-1 -> 10.0.6-2)
[2021-05-01T20:16:09+0800] [ALPM] upgraded pamac-cli (10.0.5-1 -> 10.0.6-2)
[2021-05-01T20:16:09+0800] [ALPM] upgraded pamac-common (10.0.5-1 -> 10.0.6-2)
[2021-05-01T20:16:09+0800] [ALPM] upgraded vte3 (0.64.0-1 -> 0.64.0-2)
[2021-05-01T20:16:09+0800] [ALPM] upgraded vte-common (0.64.0-1 -> 0.64.0-2)
[2021-05-01T20:16:09+0800] [ALPM] upgraded pacman (5.2.2-4 -> 5.2.2-5)
[2021-05-01T20:16:09+0800] [ALPM] upgraded pacman-mirrors (4.21.0-1 -> 4.21.3-2)
[2021-05-01T20:16:09+0800] [ALPM] upgraded ostree (2021.1-1 -> 2021.2-1)
[2021-05-01T20:16:08+0800] [ALPM] upgraded opera-ffmpeg-codecs (89.0.4389.114-1 -> 89.0.4389.128-1)
[2021-05-01T20:16:07+0800] [ALPM] upgraded openvpn (2.5.1-1 -> 2.5.2-1)
[2021-05-01T20:16:07+0800] [ALPM] upgraded openttd (1.11.0-1 -> 1.11.1-1)
[2021-05-01T20:16:07+0800] [ALPM] upgraded oath-toolkit (2.6.6-1 -> 2.6.6-2)
[2021-05-01T20:16:07+0800] [ALPM] upgraded npm (7.9.0-1 -> 7.11.1-1)
[2021-05-01T20:16:07+0800] [ALPM] upgraded nodejs (15.14.0-1 -> 16.0.0-1)
[2021-05-01T20:16:07+0800] [ALPM] upgraded networkmanager (1.30.2-1 -> 1.30.4-1)
[2021-05-01T20:16:06+0800] [ALPM] upgraded mypaint (2.0.0-2 -> 2.0.1-1)
[2021-05-01T20:16:06+0800] [ALPM] upgraded moreutils (0.65-1 -> 0.65-2)
[2021-05-01T20:16:06+0800] [ALPM] upgraded modemmanager (1.16.2-1 -> 1.16.4-1)
[2021-05-01T20:16:06+0800] [ALPM] upgraded mlocate (0.26.git.20170220-6 -> 0.26.git.20170220-7)
[2021-05-01T20:16:05+0800] [ALPM] upgraded mhwd-nvidia-390xx (390.141-1 -> 390.143-1)
[2021-05-01T20:16:05+0800] [ALPM] upgraded mhwd-nvidia (460.67-1 -> 460.73.01-1)
[2021-05-01T20:16:05+0800] [ALPM] upgraded mesa-vdpau (21.0.1-1.0 -> 21.0.3-2)
[2021-05-01T20:16:05+0800] [ALPM] upgraded matcha-gtk-theme (20210409-2 -> 20210424-1)
[2021-05-01T20:16:04+0800] [ALPM] upgraded manjaro-settings-manager-notifier (0.5.6-12 -> 0.5.6-13)
[2021-05-01T20:16:04+0800] [ALPM] upgraded manjaro-settings-manager (0.5.6-12 -> 0.5.6-13)
[2021-05-01T20:16:04+0800] [ALPM] upgraded manjaro-release (21.0.2-1 -> 21.0.3-1)
[2021-05-01T20:16:04+0800] [ALPM] upgraded mailimporter (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:15:53+0800] [ALPM] upgraded linux54-virtualbox-host-modules (6.1.18-22 -> 6.1.20-2)
[2021-05-01T20:15:53+0800] [ALPM] upgraded linux54-headers (5.4.112-1 -> 5.4.114-1)
[2021-05-01T20:15:48+0800] [ALPM] upgraded linux54 (5.4.112-1 -> 5.4.114-1)
[2021-05-01T20:15:42+0800] [ALPM] upgraded linux-firmware (20210405.r1866.af1ca28-1 -> 20210426.r1905.fa0efef-1)
[2021-05-01T20:15:29+0800] [ALPM] upgraded libva-mesa-driver (21.0.1-1.0 -> 21.0.3-2)
[2021-05-01T20:15:29+0800] [ALPM] upgraded libupnp (1.14.5-1 -> 1.14.6-1)
[2021-05-01T20:15:29+0800] [ALPM] upgraded libteam (1.31-2 -> 1.31-3)
[2021-05-01T20:15:29+0800] [ALPM] upgraded libsynctex (2020.54586-12 -> 2020.54586-13)
[2021-05-01T20:15:29+0800] [ALPM] upgraded libreoffice-fresh (7.1.2-2 -> 7.1.2-3)
[2021-05-01T20:15:17+0800] [ALPM] upgraded raptor (2.0.15-15 -> 2.0.15-16)
[2021-05-01T20:15:16+0800] [ALPM] upgraded xmlsec (1.2.31-1 -> 1.2.32-1)
[2021-05-01T20:15:16+0800] [ALPM] upgraded libzmf (0.0.2-9 -> 0.0.2-10)
[2021-05-01T20:15:16+0800] [ALPM] upgraded libvisio (0.1.7-4 -> 0.1.7-5)
[2021-05-01T20:15:16+0800] [ALPM] upgraded libqxp (0.0.2-5 -> 0.0.2-6)
[2021-05-01T20:15:16+0800] [ALPM] upgraded libqtshadowsocks (2.1.0-12 -> 2.1.0-13)
[2021-05-01T20:15:16+0800] [ALPM] upgraded libnm (1.30.2-1 -> 1.30.4-1)
[2021-05-01T20:15:16+0800] [ALPM] upgraded libmspub (0.1.4-9 -> 0.1.4-10)
[2021-05-01T20:15:16+0800] [ALPM] upgraded libmm-glib (1.16.2-1 -> 1.16.4-1)
[2021-05-01T20:15:16+0800] [ALPM] upgraded libksane (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:15:16+0800] [ALPM] upgraded libkgapi (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:15:16+0800] [ALPM] upgraded libkexiv2 (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:15:16+0800] [ALPM] upgraded libkdegames (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:15:16+0800] [ALPM] upgraded libgravatar (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:15:16+0800] [ALPM] upgraded pimcommon (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:15:16+0800] [ALPM] upgraded libkdepim (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:15:16+0800] [ALPM] upgraded libgdm (40.0-5 -> 40.0-6)
[2021-05-01T20:15:16+0800] [ALPM] upgraded libe-book (0.1.3-8 -> 0.1.3-9)
[2021-05-01T20:15:16+0800] [ALPM] upgraded libdvdnav (6.1.0-2 -> 6.1.1-1)
[2021-05-01T20:15:15+0800] [ALPM] upgraded libdvdread (6.1.1-1 -> 6.1.2-1)
[2021-05-01T20:15:15+0800] [ALPM] upgraded libdvdcss (1.4.2-2 -> 1.4.3-1)
[2021-05-01T20:15:15+0800] [ALPM] upgraded libcdr (0.1.7-1 -> 0.1.7-2)
[2021-05-01T20:15:15+0800] [ALPM] upgraded lib32-vulkan-radeon (21.0.2-1 -> 21.0.3-2)
[2021-05-01T20:15:15+0800] [ALPM] upgraded lib32-vulkan-intel (21.0.2-1 -> 21.0.3-2)
[2021-05-01T20:15:15+0800] [ALPM] upgraded lib32-nss (3.63-1 -> 3.64-1)
[2021-05-01T20:15:15+0800] [ALPM] upgraded lib32-mesa-vdpau (21.0.2-1 -> 21.0.3-2)
[2021-05-01T20:15:15+0800] [ALPM] upgraded lib32-mesa (21.0.2-1 -> 21.0.3-2)
[2021-05-01T20:15:15+0800] [ALPM] upgraded lib32-vulkan-icd-loader (1.2.172-1 -> 1.2.174-1)
[2021-05-01T20:15:15+0800] [ALPM] upgraded lib32-libva-mesa-driver (21.0.2-1 -> 21.0.3-2)
[2021-05-01T20:15:15+0800] [ALPM] upgraded lib32-libxml2 (2.9.10-3 -> 2.9.10-4)
[2021-05-01T20:15:15+0800] [ALPM] upgraded lib32-libjpeg-turbo (2.0.6-1 -> 2.1.0-1)
[2021-05-01T20:15:15+0800] [ALPM] upgraded lib32-libgcrypt (1.9.2-1 -> 1.9.3-1)
[2021-05-01T20:15:15+0800] [ALPM] upgraded lib32-libgpg-error (1.41-1 -> 1.42-1)
[2021-05-01T20:15:15+0800] [ALPM] upgraded lib32-icu (68.2-1 -> 69.1-1)
[2021-05-01T20:15:14+0800] [ALPM] upgraded lib32-harfbuzz (2.8.0-1 -> 2.8.0-3)
[2021-05-01T20:15:14+0800] [ALPM] upgraded ktnef (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:15:14+0800] [ALPM] upgraded ksmtp (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:15:14+0800] [ALPM] upgraded kontactinterface (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:15:14+0800] [ALPM] upgraded kmbox (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:15:14+0800] [ALPM] upgraded kleopatra (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:15:14+0800] [ALPM] upgraded kldap (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:15:14+0800] [ALPM] installed qtkeychain-qt5 (0.12.0-1)
[2021-05-01T20:15:14+0800] [ALPM] upgraded kitinerary (20.12.3-2 -> 21.04.0-1)
[2021-05-01T20:15:14+0800] [ALPM] upgraded kpkpass (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:15:14+0800] [ALPM] upgraded kimap (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:15:14+0800] [ALPM] upgraded kdialog (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:15:14+0800] [ALPM] upgraded kdegraphics-mobipocket (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:15:14+0800] [ALPM] upgraded kalarmcal (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:15:14+0800] [ALPM] upgraded kcalutils (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:15:14+0800] [ALPM] upgraded kidentitymanagement (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:15:14+0800] [ALPM] upgraded jitterentropy (3.0.1-1 -> 3.0.2-1)
[2021-05-01T20:15:14+0800] [ALPM] upgraded inetutils (1.9.4-8 -> 1.9.4-9)
[2021-05-01T20:15:14+0800] [ALPM] upgraded hwinfo (21.72-1 -> 21.73-1)
[2021-05-01T20:15:14+0800] [ALPM] upgraded guile (2.2.6-2 -> 2.2.7-1)
[2021-05-01T20:15:14+0800] [ALPM] upgraded gst-plugin-pipewire (1:0.3.25-1 -> 1:0.3.26-1)
[2021-05-01T20:15:14+0800] [ALPM] upgraded pipewire-media-session (1:0.3.25-1 -> 1:0.3.26-1)
[2021-05-01T20:15:14+0800] [ALPM] warning: /etc/pipewire/media-session.d/media-session.conf installed as /etc/pipewire/media-session.d/media-session.conf.pacnew
[2021-05-01T20:15:14+0800] [ALPM] warning: /etc/pipewire/media-session.d/alsa-monitor.conf installed as /etc/pipewire/media-session.d/alsa-monitor.conf.pacnew
[2021-05-01T20:15:14+0800] [ALPM] upgraded pipewire (1:0.3.25-1 -> 1:0.3.26-1)
[2021-05-01T20:15:13+0800] [ALPM] upgraded graphicsmagick (1.3.36-1 -> 1.3.36-2)
[2021-05-01T20:15:13+0800] [ALPM] upgraded gradle (6.8.3-1 -> 7.0-1)
[2021-05-01T20:15:13+0800] [ALPM] upgraded jdk8-openjdk (8.u282-1 -> 8.u292-1)
[2021-05-01T20:15:13+0800] [ALPM] upgraded jre8-openjdk (8.u282-1 -> 8.u292-1)
[2021-05-01T20:15:13+0800] [ALPM] upgraded jre8-openjdk-headless (8.u282-1 -> 8.u292-1)
[2021-05-01T20:15:12+0800] [ALPM] upgraded jdk11-openjdk (11.0.10.u9-1 -> 11.0.11.u9-1)
[2021-05-01T20:15:12+0800] [ALPM] upgraded jre11-openjdk (11.0.10.u9-1 -> 11.0.11.u9-1)
[2021-05-01T20:15:12+0800] [ALPM] upgraded jre11-openjdk-headless (11.0.10.u9-1 -> 11.0.11.u9-1)
[2021-05-01T20:15:11+0800] [ALPM] upgraded gparted (1.2.0-2 -> 1.2.0-3)
[2021-05-01T20:15:11+0800] [ALPM] installed xorg-xhost (1.0.8-2)
[2021-05-01T20:15:11+0800] [ALPM] upgraded google-chrome (90.0.4430.72-2 -> 90.0.4430.93-1)
[2021-05-01T20:15:10+0800] [ALPM] upgraded gnustep-base (1.27.0-2 -> 1.27.0-3)
[2021-05-01T20:15:10+0800] [ALPM] upgraded gnome-session (40.0-1 -> 40.1.1-0)
[2021-05-01T20:15:10+0800] [ALPM] upgraded gjs (2:1.68.0-2 -> 2:1.68.0-3)
[2021-05-01T20:15:10+0800] [ALPM] upgraded gimp (2.10.24-1 -> 2.10.24-2)
[2021-05-01T20:15:08+0800] [ALPM] upgraded graphviz (2.47.0-1 -> 2.47.1-1)
[2021-05-01T20:15:08+0800] [ALPM] upgraded libmypaint (1.5.1-2 -> 1.6.1-1)
[2021-05-01T20:15:08+0800] [ALPM] upgraded firefox-i18n-zh-cn (87.0-1 -> 88.0-1)
[2021-05-01T20:15:08+0800] [ALPM] upgraded firefox-i18n-en-us (87.0-1 -> 88.0-1)
[2021-05-01T20:15:08+0800] [ALPM] upgraded firefox (87.0-2 -> 88.0-1)
[2021-05-01T20:15:07+0800] [ALPM] upgraded fcitx-qt5 (1.2.5-3 -> 1.2.6-1)
[2021-05-01T20:15:07+0800] [ALPM] upgraded evolution-data-server (3.40.0-1 -> 3.40.0-2)
[2021-05-01T20:15:07+0800] [ALPM] upgraded libphonenumber (8.12.20-1 -> 8.12.21-1)
[2021-05-01T20:15:07+0800] [ALPM] upgraded protobuf (3.15.7-1 -> 3.15.8-1)
[2021-05-01T20:15:07+0800] [ALPM] upgraded gnome-online-accounts (3.39.92-1 -> 3.40.0-1)
[2021-05-01T20:15:07+0800] [ALPM] upgraded webkit2gtk (2.32.0-1 -> 2.32.0-2)
[2021-05-01T20:15:06+0800] [ALPM] upgraded harfbuzz-icu (2.8.0-1 -> 2.8.0-3)
[2021-05-01T20:15:06+0800] [ALPM] upgraded engrampa (1.24.1-1 -> 1.24.2-1)
[2021-05-01T20:15:06+0800] [ALPM] upgraded less (1:563-1 -> 1:581-1)
[2021-05-01T20:15:06+0800] [ALPM] upgraded enchant (2.2.15-1 -> 2.2.15-2)
[2021-05-01T20:15:06+0800] [ALPM] upgraded electron9 (9.4.3-1 -> 9.4.4-1)
[2021-05-01T20:15:06+0800] [ALPM] upgraded electron6 (6.1.12-5 -> 6.1.12-6)
[2021-05-01T20:15:05+0800] [ALPM] upgraded electron (12.0.4-1 -> 12.0.5-1)
[2021-05-01T20:15:05+0800] [ALPM] upgraded gtk3 (1:3.24.28-4 -> 1:3.24.29-1)
[2021-05-01T20:15:05+0800] [ALPM] upgraded glib-networking (1:2.68.0-1 -> 1:2.68.1-1)
[2021-05-01T20:15:05+0800] [ALPM] upgraded docker-machine (0.16.2-4 -> 0.16.2-5)
[2021-05-01T20:15:05+0800] [ALPM] upgraded deepin-qt5integration-git (5.1.5.r20.gc8049be-2 -> 5.1.11.r9.g12edc12-2)
[2021-05-01T20:15:05+0800] [ALPM] upgraded deepin-qt5platform-plugins-git (5.0.21.r24.g5b86657-1 -> 5.0.21.r27.g1f8f189-1)
[2021-05-01T20:15:05+0800] [ALPM] upgraded dtkwidget-git (5.4.1.r32.g1c4e7886-2 -> 5.4.1.r42.g2ab80273-2)
[2021-05-01T20:15:04+0800] [ALPM] upgraded dtkgui-git (5.4.0.r34.gc9c2941-2 -> 5.4.0.r38.g5fcda3f-1)
[2021-05-01T20:15:04+0800] [ALPM] upgraded dtkcore-git (5.4.0.r33.gb96b877-1 -> 5.4.0.r35.g511d1dd-2)
[2021-05-01T20:15:04+0800] [ALPM] upgraded deepin-qt-dbus-factory-git (5.4.4.r3.g9ce6e51-2 -> 5.4.5.r4.g2180144-2)
[2021-05-01T20:15:04+0800] [ALPM] upgraded cups (1:2.3.3op2-2 -> 1:2.3.3op2-3)
[2021-05-01T20:15:04+0800] [ALPM] upgraded imagemagick (7.0.11.7-1 -> 7.0.11.9-1)
[2021-05-01T20:15:01+0800] [ALPM] upgraded cuda (11.2.2-2 -> 11.3.0-1)
[2021-05-01T20:14:55+0800] [ALPM] upgraded opencl-nvidia (460.67-1 -> 460.73.01-1)
[2021-05-01T20:14:55+0800] [ALPM] upgraded crda (4.14-3 -> 4.14-4)
[2021-05-01T20:14:55+0800] [ALPM] upgraded cpupower (5.11-1 -> 5.12-1)
[2021-05-01T20:14:55+0800] [ALPM] upgraded cifs-utils (6.13-1 -> 6.13-2)
[2021-05-01T20:14:55+0800] [ALPM] upgraded smbclient (4.14.2-1 -> 4.14.3-1)
[2021-05-01T20:14:55+0800] [ALPM] upgraded botan (2.17.3-1 -> 2.18.0-1)
[2021-05-01T20:14:55+0800] [ALPM] upgraded boost (1.75.0-2 -> 1.75.0-3)
[2021-05-01T20:14:54+0800] [ALPM] upgraded blender (17:2.92.0-2 -> 17:2.92.0-4)
[2021-05-01T20:14:53+0800] [ALPM] upgraded python-setuptools (1:54.2.0-1 -> 1:56.0.0-1)
[2021-05-01T20:14:53+0800] [ALPM] upgraded openssh (8.5p1-1 -> 8.6p1-1)
[2021-05-01T20:14:53+0800] [ALPM] upgraded hwloc (2.4.0-1 -> 2.4.1-1)
[2021-05-01T20:14:53+0800] [ALPM] upgraded openshadinglanguage (1.11.13.0-1 -> 1.11.13.0-2)
[2021-05-01T20:14:53+0800] [ALPM] upgraded jasper (2.0.27-1 -> 2.0.28-1)
[2021-05-01T20:14:53+0800] [ALPM] upgraded pybind11 (2.6.2-1 -> 2.6.2-2)
[2021-05-01T20:14:53+0800] [ALPM] upgraded python-numpy (1.20.1-1 -> 1.20.2-1)
[2021-05-01T20:14:53+0800] [ALPM] upgraded archlinux-appstream-data (20210321-1 -> 20210423-1)
[2021-05-01T20:14:53+0800] [ALPM] upgraded alsa-card-profiles (1:0.3.25-1 -> 1:0.3.26-1)
[2021-05-01T20:14:53+0800] [ALPM] upgraded alembic (1.7.16-1 -> 1.8.0-1)
[2021-05-01T20:14:53+0800] [ALPM] upgraded boost-libs (1.75.0-2 -> 1.75.0-3)
[2021-05-01T20:14:53+0800] [ALPM] upgraded akonadi-search (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:14:53+0800] [ALPM] upgraded libical (3.0.9-1 -> 3.0.10-1)
[2021-05-01T20:14:53+0800] [ALPM] upgraded akonadi-notes (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:14:53+0800] [ALPM] upgraded akonadi-mime (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:14:53+0800] [ALPM] upgraded akonadi-contacts (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:14:53+0800] [ALPM] upgraded libkleo (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:14:53+0800] [ALPM] upgraded kpimtextedit (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:14:53+0800] [ALPM] upgraded grantleetheme (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:14:53+0800] [ALPM] upgraded kmime (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:14:53+0800] [ALPM] upgraded akonadi (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:14:53+0800] [ALPM] upgraded libakonadi (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:14:53+0800] [ALPM] upgraded kaccounts-integration (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:14:53+0800] [ALPM] upgraded dbus-glib (0.110-2 -> 0.112-1)
[2021-05-01T20:14:53+0800] [ALPM] upgraded qt5-webengine (5.15.3-3 -> 5.15.3-4)
[2021-05-01T20:14:52+0800] [ALPM] upgraded qt5-location (5.15.2-2 -> 5.15.2-3)
[2021-05-01T20:14:52+0800] [ALPM] upgraded nss (3.63-1 -> 3.64-1)
[2021-05-01T20:14:52+0800] [ALPM] upgraded xfsprogs (5.11.0-1 -> 5.11.0-2)
[2021-05-01T20:14:52+0800] [ALPM] upgraded signon-kwallet-extension (20.12.3-1 -> 21.04.0-1)
[2021-05-01T20:14:52+0800] [ALPM] upgraded python (3.9.3-1 -> 3.9.4-1)
[2021-05-01T20:14:52+0800] [ALPM] upgraded js78 (78.9.0-1 -> 78.10.0-1)
[2021-05-01T20:14:52+0800] [ALPM] upgraded qt5-svg (5.15.2+kde+r5-1 -> 5.15.2+kde+r7-1)
[2021-05-01T20:14:52+0800] [ALPM] upgraded qt5-base (5.15.2+kde+r172-0 -> 5.15.2+kde+r177-1)
[2021-05-01T20:14:52+0800] [ALPM] upgraded libglvnd (1.3.2-1 -> 1.3.2-2)
[2021-05-01T20:14:52+0800] [ALPM] upgraded xf86-input-libinput (1.0.0-1 -> 1.0.1-1)
[2021-05-01T20:14:52+0800] [ALPM] upgraded mesa (21.0.1-1.0 -> 21.0.3-2)
[2021-05-01T20:14:51+0800] [ALPM] upgraded libedit (20210216_3.1-1 -> 20210419_3.1-1)
[2021-05-01T20:14:51+0800] [ALPM] upgraded ca-certificates-mozilla (3.63-1 -> 3.64-1)
[2021-05-01T20:14:51+0800] [ALPM] upgraded vulkan-icd-loader (1.2.172-1 -> 1.2.174-2)
[2021-05-01T20:14:51+0800] [ALPM] upgraded libcups (1:2.3.3op2-2 -> 1:2.3.3op2-3)
[2021-05-01T20:14:51+0800] [ALPM] upgraded avahi (0.8+15+ge8a3dd0-3 -> 0.8+20+gd1e71b3-1)
[2021-05-01T20:14:51+0800] [ALPM] upgraded libgcrypt (1.9.2-1 -> 1.9.3-1)
[2021-05-01T20:14:51+0800] [ALPM] upgraded sqlite (3.35.4-1 -> 3.35.5-1)
[2021-05-01T20:14:51+0800] [ALPM] upgraded adwaita-icon-theme (40rc-1 -> 40.0-1)
[2021-05-01T20:14:51+0800] [ALPM] upgraded harfbuzz (2.8.0-1 -> 2.8.0-3)
[2021-05-01T20:14:51+0800] [ALPM] upgraded libxml2 (2.9.10-8 -> 2.9.10-9)
[2021-05-01T20:14:51+0800] [ALPM] upgraded icu (68.2-1 -> 69.1-1)
[2021-05-01T20:14:50+0800] [ALPM] upgraded libtiff (4.2.0-1 -> 4.3.0-1)
[2021-05-01T20:14:50+0800] [ALPM] upgraded libjpeg-turbo (2.0.6-1 -> 2.1.0-1)
My laptop
Kernel: 5.4.114-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=35d01226-9477-42ee-a9d3-1e7ea4f7f707 rw quiet apparmor=1
security=apparmor resume=UUID=e85ddf9e-2a79-4756-902a-63427e5dea8c
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
Type: Laptop System: Dell product: Latitude 5401 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0D2RTT v: A00 serial: <filter> UEFI: Dell v: 1.2.11
date: 06/11/2019
ID-1: BAT0 charge: 60.2 Wh (100.0%) condition: 60.2/68.0 Wh (88.5%)
volts: 17.1 min: 15.2 model: LGC-LGC4.47 DELL 10X1J97 type: Li-ion
serial: <filter> status: Full
Device-1: hidpp_battery_0 model: Logitech M585/M590 Multi-Device Mouse
status: Discharging
RAM: total: 31.15 GiB used: 4.61 GiB (14.8%)
Info: 6-Core model: Intel Core i7-9850H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: D (13)
microcode: DE cache: L2: 12 MiB bogomips: 62431
Speed: 900 MHz min/max: 800/4600 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 900 7: 900 8: 900 9: 900 10: 900 11: 900 12: 900
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-11:3 chip-ID: 0bda:5539 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting
unloaded: intel alternate: fbdev,vesa display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.0.3
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.4.114-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: no
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: 3.2.6-k
port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel port: efa0 bus-ID: 3b:00.0
chip-ID: 168c:003e class-ID: 0280
IF: wlp59s0 state: up mac: <filter>
IF-ID-1: br-2b1054a18f0b state: down mac: <filter>
IF-ID-2: br-3d9fb6b91fe7 state: down mac: <filter>
IF-ID-3: br-50722326babf state: down mac: <filter>
IF-ID-4: br-5bcc4bf21040 state: down mac: <filter>
IF-ID-5: br-8e3afdcd6b4d state: down mac: <filter>
IF-ID-6: br-99bf1bec7f78 state: down mac: <filter>
IF-ID-7: br-be1a5be52393 state: down mac: <filter>
IF-ID-8: br-d1ee87aaf940 state: down mac: <filter>
IF-ID-9: br-e0ecdb6ea494 state: down mac: <filter>
IF-ID-10: br-ef37b446c909 state: down mac: <filter>
IF-ID-11: docker0 state: down mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-14:4
chip-ID: 0cf3:e007 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 188.58 GiB (39.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
lanes: 4 rotation: SSD serial: <filter> rev: 002C scheme: GPT
ID-1: / raw-size: 442.32 GiB size: 434.38 GiB (98.20%)
used: 188.58 GiB (43.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 35d01226-9477-42ee-a9d3-1e7ea4f7f707
used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 820C-F37C
ID-1: swap-1 type: partition size: 34.32 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: e85ddf9e-2a79-4756-902a-63427e5dea8c
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-3:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-11:3 info: Realtek Integrated_Webcam_HD type: Video
Device-3: 1-14:4 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e007
class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 72.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2387
Processes: 335 Uptime: 2h 00m wakeups: 5753 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 alt: 8/9 clang: 11.1.0 Packages: 2027
pacman: 2020 lib: 521 flatpak: 0 snap: 7 Shell: Bash v: 5.1.0
running-in: xfce4-terminal inxi: 3.3.04
