Hello people,
System: Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=e367bb09-f515-46b1-bfc0-e8a98949314e rw
quiet resume=/dev/nvme0n1p1
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: 20NBCTO1WW v: ThinkPad E590 serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: LENOVO model: 20NBCTO1WW v: SDK0J40709 WIN serial: <filter> UEFI: LENOVO v: R0YET25W (1.08 )
date: 11/28/2018
Battery: ID-1: BAT0 charge: 35.7 Wh condition: 36.0/45.0 Wh (80%) volts: 12.3/11.1 model: LGC 01AV445
type: Li-poly serial: <filter> status: Unknown cycles: 417
Device-1: hidpp_battery_0 model: Logitech G305 Lightspeed Wireless Gaming Mouse serial: <filter>
charge: 100% (should be ignored) rechargeable: yes status: Discharging
Memory: RAM: total: 15.36 GiB used: 2.68 GiB (17.4%)
CPU: Topology: Quad Core model: Intel Core i7-8565U bits: 64 type: MT MCP arch: Kaby Lake family: 6
model-id: 8E (142) stepping: B (11) microcode: D6 L2 cache: 8192 KiB bogomips: 32012
Speed: 600 MHz min/max: 400/4600 MHz Core speeds (MHz): 1: 600 2: 600 3: 600 4: 600 5: 600 6: 601
7: 600 8: 600
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art avx
avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp
hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb
pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:3ea0
Device-2: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X] vendor: Lenovo driver: amdgpu
v: kernel bus ID: 03:00.0 chip ID: 1002:699f
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo bus ID: 1-6:5 chip ID: 13d3:56a6
serial: <filter>
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: amdgpu,intel FAILED: ati
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: HDMI1 res: 1920x1080 dpi: 90 size: 540x300mm (21.3x11.8") diag: 618mm (24.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.1.7 direct render: Yes
Audio: Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:9dc8
Sound Server: ALSA v: k5.8.6-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169
v: kernel port: 2000 bus ID: 04:00.0 chip ID: 10ec:8168
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: 2000 bus ID: 05:00.0
chip ID: 8086:2526
IF: wlp5s0 state: up mac: <filter>
Device-3: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb bus ID: 1-5:4
chip ID: 8087:0025
Drives: Local Storage: total: 238.47 GiB used: 149.14 GiB (62.5%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: N/A size: 238.47 GiB block size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 serial: <filter> rev: 0106ADLA scheme: GPT
RAID: Message: No RAID data was found.
Partition: ID-1: / raw size: 221.27 GiB size: 216.80 GiB (97.98%) used: 149.14 GiB (68.8%) fs: ext4
dev: /dev/nvme0n1p2 label: N/A uuid: e367bb09-f515-46b1-bfc0-e8a98949314e
ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%) used: 280 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1 label: N/A uuid: 57DF-1A6C
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 16.90 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
label: N/A uuid: 6e1ce6a6-f4dd-4438-8183-bc1ad18ebe36
Unmounted: Message: No unmounted partitions found.
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-1:2 info: Logitech USB Receiver type: Keyboard,Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s chip ID: 046d:c53f
Device-2: 1-3:3 info: China Resource Semico USB Keyboard type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s chip ID: 1a2c:4c5e
Device-3: 1-5:4 info: Intel Wireless-AC 9260 Bluetooth Adapter type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0025
Device-4: 1-6:5 info: IMC Networks Integrated Camera type: Video driver: uvcvideo interfaces: 2
rev: 2.0 speed: 480 Mb/s chip ID: 13d3:56a6 serial: <filter>
Device-5: 1-8:6 info: Synaptics Metallica MOH Touch Fingerprint Reader type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s chip ID: 06cb:00a2 serial: <filter>
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 46.0 C mobo: 0.0 C gpu: amdgpu temp: 46 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 265 Uptime: 1h 01m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: apt: 0
pacman: 1373 lib: 394 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
I have been trying to run a system update but failed because of the libutil-linux
package.
Here is my sudo pacman -Syu
Output
core is up to date
extra is up to date
community is up to date
multilib is up to date
:: Replace libutil-linux with core/util-linux-libs? [Y/n] y
resolving dependencies...
:: removing libutil-linux breaks dependency 'libutil-linux>=2.16' required by skypeforlinux
I tried removing libutil-linux
first and then do the update but failed because removing it breaks some dependencies
Thanks in advance!
