Ok So my problem is every time I start or shut off my PC it says this message “Failed to Load Kernel or File Systems”
It started after I got a new Hard drive, the System was installed on an SSD, then I loaded a time shift backup for installing it on a different (m2 SSD) after I finished the time shift backup restore on my new SSD I used KDE Partition manager to Repartition the old system drive, as a normal ext4, then this problem started, is there a way to fix this? Not sure if this is a boot or kernel issue.
Addition: my Computer still starts and works normally.
you have to check all UUID
sudo lsblk -fs
cat /etc/fstab
sda1 ext4 1.0 SSD Small 4d5486c0-af2b-424d-9b03-4d9cafbe3689 55,4G 0% /run/media/tipips/SSD Small
└─sda
sdb1 ext4 1.0 Downloads de615a39-0fe2-4632-86d7-6da34341dd97 49,3G 84% /run/media/tipips/Downloads
└─sdb
sdc1 ext4 1.0 Backups 367a2d53-013e-4396-819f-041de204427c 248,8G 41% /run/timeshift/backup
└─sdc
sdd1 ext4 1.0 SSD Games 70fa7015-f7c0-4e27-86ca-758c9f4b0e16 68,2G 33% /run/media/tipips/SSD Games
└─sdd
nvme0n1p1 vfat FAT32 42CB-FE79
└─nvme0n1
nvme0n1p2 ext4 1.0 c5e64856-38dc-47fa-bf42-3e0c3219fbc3 221,8G 46% /
└─nvme0n1
/etc/fstab: static file system information.
Use ‘blkid’ to print the universally unique identifier for a device; this may
be used with UUID= as a more robust way to name devices that works even if
disks are added and removed. See fstab(5).
UUID=4b9f9e25-e57c-42f3-8041-92e05db38e0a / ext4 defaults,noatime,discard 0 1
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
that is the other output
i Dont see anything wrong with this.
If this is your / partition then your fstab entry for / is wrong as the UUID differ:
nvme0n1p2: c5e64856-38dc-47fa-bf42-3e0c3219fbc3
fstab: 4b9f9e25-e57c-42f3-8041-92e05db38e0a
Also, the /boot/efi partition entry with UUID 42CB-FE79
is mssing in your fstab.
It’s amazing that you still can boot.
you have to boot with USB iso manjaro ( live )
and update /etc/fstab by chroot
open a terminal
sudo manjaro-chroot -a ( type 1 if only one line appears )
nano /etc/fstab ( update and save Ctrl+X )
exit ( quit chroot )
your /etc/fstab should be
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=42CB-FE79 /boot/efi vfat defaults,noatime,discard 0 2
UUID=c5e64856-38dc-47fa-bf42-3e0c3219fbc3 / ext4 defaults,noatime,discard 0 1
So if i copy what you wrote it should be right? and work again?
Thank you its Fixed now
