my first post here and I apologise if I’m posting a duplicate but I am confused how to fix it.
I’m still fairly new to Linux and after the last big update using the stable branch of Bspwm with kernel 5.4.89 i think ( I originally installed awesome wm community edition - then installed Bspwm that ive been using) on reboot i had several lines of the error [Failed] Failed to load kernel modules
I’ve done alot of searching and reading posts etc
I tried to manjaro-chroot -a (for the first time) and installed a new kernel 5.10 and then the Nvidia drivers but that didnt help.
I’d prefer to fix the original 5.4 kernel to keep with the stable branch.
I have the manjaro grub screen and luckily I still have an i3 manjaro that I can boot into but I’d like to go back to my main system.
Now I’m confused and at a loss and would be grateful if someone could help to fix it as I’d like to use this as an opportunity to learn instead of just reinstalling.
While I don’t really have an idea what can cause it, I’m just going to leave a comment and a suggestion.
I don’t know if you know this, but Kernel 5.10 is in the stable branch now. I’m running it myself. 5.10 is also set to become the next LTS (Long Term Support) version. So there’s no real reason not to use it.
When you startup your computer, just after the BIOS logo, press the ESC a couple of times. You should receive the GRUB boot menu. Use keys and navigate to the Advanced options menu. There you can check if any specific kernel works correctly.
Thanks, if you mean the Manjaro grub menu which shows all the installs on my SSD? then I’ve tried all kernels in the Advanced menu 4.19, 5.4 and 5.10 and none work, including the fallbacks
I’ll try to get the output I assume I do this by dropping to tty on the failed install?
here is the output requested - this is from my i3 install that works as I don’t know how to save it from the failed install as I said I’m new to linux terminal
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2020.11.30 false PCI
