Hi
I have an error after change from stable to testing and run this update.
Fail to load kernel modules
Kernel: 5.8.1-3-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=ac99531c-fb80-4e21-943e-dffb8acccce4 rw quiet acpi_osi=linux
acpi_backlight=vendor udev.log_priority=3
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: TUF Gaming FX505DD_FX505DD v: 1.0
serial: <filter>
Mobo: ASUSTeK model: FX505DD v: 1.0 serial: <filter>
UEFI: American Megatrends v: FX505DD.310 date: 12/24/2019
ID-1: BAT0 charge: 25.1 Wh condition: 43.4/48.2 Wh (90%) volts: 11.4/11.9
model: FX50442 type: Li-ion serial: N/A status: Discharging
Topology: Quad Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 18 (24)
stepping: 1 microcode: 8108102 L2 cache: 2048 KiB
bogomips: 33548
Speed: 1300 MHz max: 1400 MHz boost: disabled Core speeds (MHz): 1: 1282
2: 1327 3: 1222 4: 1239 5: 1223 6: 1323 7: 1223 8: 1223
disabled, RSB filling
Device-1: NVIDIA GP107M [GeForce GTX 1050 3 GB Max-Q] driver: N/A
alternate: nouveau, nvidia_drm, nvidia bus ID: 01:00.0 chip ID: 10de:1c91
Device-2: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus ID: 05:00.0 chip ID: 1002:15d8
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus ID: 3-1:2 chip ID: 13d3:56a2 serial: <filter>
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: amdgpu
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD RAVEN (DRM 3.38.0 5.8.1-3-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.5 direct render: Yes
Device-1: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 05:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.8.1-3-MANJARO
vendor: ASUSTeK driver: r8168 v: 8.048.03-NAPI modules: r8169 port: e000
bus ID: 02:00.0 chip ID: 10ec:8168
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtl8821ce v: N/A modules: 8821ce port: d000
bus ID: 04:00.0 chip ID: 10ec:c821
IF: wlp4s0 state: down mac: <filter>
Local Storage: total: 1.14 TiB used: 280.77 GiB (24.0%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN520 SDAPNUW-256G-1002
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 serial: <filter> rev: 20110000 scheme: GPT
ID-2: /dev/sda vendor: Western Digital model: WD10SPZX-00Z10T0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 1A01 scheme: MBR
ID-1: / raw size: 49.26 GiB size: 48.24 GiB (97.92%) used: 14.95 GiB (31.0%)
fs: ext4 dev: /dev/nvme0n1p5
ID-2: /home raw size: 62.50 GiB size: 61.27 GiB (98.03%)
used: 1.23 GiB (2.0%) fs: ext4 dev: /dev/nvme0n1p6
ID-1: swap-1 type: partition size: 8.49 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2
System Temperatures: cpu: 40.0 C mobo: N/A gpu: amdgpu temp: 40 C
Fan Speeds (RPM): cpu: 2300
Processes: 238 Uptime: 29m Memory: 15.14 GiB used: 3.48 GiB (23.0%)
Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: pacman: 1106 lib: 298
Shell: Bash v: 5.0.18 running in: yakuake inxi: 3.1.05
