Failed to find module 'acpi_call' on start [SOLVED]
It's been a few months since I used my laptop. I updated via TTY and everything went fine. I decided to try the new 5.xx kernels and the system boots but I'm getting this "Failed to find module 'acpi_call' " error that I'm not sure how to fix. I tried some searches, but nothing that pointed me in the right direction.
Error log and system info below. Kernel 4.19 boots without errors.
[xxx@xxx ~]$ journalctl -b --no-hostname --no-pager -u systemd-modules-load.service
-- Logs begin at Sat 2019-04-13 03:41:55 AKDT, end at Mon 2019-08-19 13:14:44 AKDT. --
Aug 19 13:07:36 systemd[1]: Starting Load Kernel Modules...
Aug 19 13:07:36 systemd-modules-load[562]: Failed to find module 'acpi_call'
Aug 19 13:07:36 systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
Aug 19 13:07:36 systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
Aug 19 13:07:36 systemd[1]: Failed to start Load Kernel Modules.
Aug 19 13:07:36 systemd-modules-load[603]: Failed to find module 'acpi_call'
[xxx@xxx ~]$ inxi -Fxzc0
System:    Host: nSpectre Kernel: 5.1.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.1.0 Desktop: KDE Plasma 5.16.4
           Distro: Manjaro Linux
Machine:   Type: Convertible System: HP product: HP Spectre Convertible v: N/A serial: <filter>
           Mobo: HP model: 827F v: 95.11 serial: <filter> UEFI: American Megatrends v: F.40 date: 04/25/2019
Battery:   ID-1: BAT0 charge: 59.8 Wh condition: 73.9/73.9 Wh (100%) model: HP Primary status: Discharging
CPU:       Topology: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 8192 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 31880
           Speed: 800 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 801 5: 800 6: 800 7: 800 8: 800
Graphics:  Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0
           Device-2: NVIDIA GP108M [GeForce MX150] vendor: Hewlett-Packard driver: N/A bus ID: 01:00.0
           Display: x11 server: X.Org 1.20.5 driver: intel resolution: 3840x2160~60Hz
           OpenGL: renderer: Mesa DRI Intel UHD Graphics 620 (Kabylake GT2) v: 4.5 Mesa 19.1.4 direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           Sound Server: ALSA v: k5.1.21-1-MANJARO
Network:   Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: e000 bus ID: 3b:00.0
Drives:    Local Storage: total: 476.94 GiB used: 43.64 GiB (9.1%)
           ID-1: /dev/nvme0n1 vendor: Toshiba model: KXG50ZNV512G size: 476.94 GiB
Partition: ID-1: / size: 63.03 GiB used: 43.33 GiB (68.7%) fs: ext4 dev: /dev/nvme0n1p7
           ID-2: swap-1 size: 9.77 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/nvme0n1p6
Sensors:   System Temperatures: cpu: 47.0 C mobo: N/A
Info:      Processes: 198 Uptime: 13m Memory: 15.55 GiB used: 1.49 GiB (9.6%) Init: systemd Compilers: gcc: 9.1.0 Shell: bash
           v: 5.0.7 inxi: 3.0.35
try installing the package acpi_call-dkms.
then sudo depmod -a
followed by a reboot
Thanks!
I re-installed acpi_call-dkms and everything works fine =)
Hola I'm having same problems since last update, currently using gnome 5.2.21-1-MANJARO I tried to remove this package because it was already installed and install it again, then sudo depmod -a followed by a reboot and didn't work.
