@cfinnberg
[manjaro@manjaro ~]$ sudo efibootmgr -v
sudo lsblk -f
sudo fdisk -l
BootCurrent: 0017
Timeout: 0 seconds
BootOrder: 0000,0001,0014,0015,0016,0018,0017,0019,001A,001B,001C
Boot0000* ubuntu HD(1,GPT,62a03796-e5c0-4e5d-8f76-ff653805bffb,0x800,0x82000)/File(\EFI\ubuntu\shimx64.efi)
Boot0001* Windows Boot Manager HD(1,GPT,62a03796-e5c0-4e5d-8f76-ff653805bffb,0x800,0x82000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}...t................
Boot0010 Setup FvFile(721c8b66-426c-4e86-8e99-3457c46ab0b9)
Boot0011 Boot Menu FvFile(86488440-41bb-42c7-93ac-450fbf7766bf)
Boot0012 Diagnostic Splash FvFile(a7d8d9a6-6ab0-4aeb-ad9d-163e59a7a380)
Boot0013 OilDiagApp FvFile(f8397897-e203-4a62-b977-9e7e5d94d91b)
Boot0014* ATA HDD: ST1000LM035-1RK172 PciRoot(0x0)/Pci(0x11,0x0)/Sata(0,0,0)..bYVD.A...O.*..
Boot0015* ATA HDD1: VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f601)
Boot0016* ATAPI CD: VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,aea2090adfde214e8b3a5e471856a354)
Boot0017* USB HDD: SanDisk Ultra PciRoot(0x0)/Pci(0x10,0x0)/USB(0,0)3.!..3.G..A.....
Boot0018* PCI LAN: EFI Network (IPv6) PciRoot(0x0)/Pci(0x2,0x4)/Pci(0x0,0x0)/MAC(8c16459be77b,0)/IPv6([::]:<->[::]:,0,0)x.J.+*.N.....=8.
Boot0019* USB FDD: VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,6ff015a28830b543a8b8641009461e49)
Boot001A* USB CD: VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,86701296aa5a7848b66cd49dd3ba6a55)
Boot001B* NVMe: VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,001c199932d94c4eae9aa0b6e98eb8a4)
Boot001C* PCI LAN: EFI Network (IPv4) PciRoot(0x0)/Pci(0x2,0x4)/Pci(0x0,0x0)/MAC(8c16459be77b,0)/IPv4(0.0.0.00.0.0.0,0,0)x.J.+*.N.....=8.
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
loop0
squash 4.0 0 100% /run/miso/
loop1
loop2
loop3
sda
├─sda1
│ vfat FAT32 SYSTEM_DRV
│ 6C8C-D247
├─sda2
├─sda3
│ ntfs Windows
│ 02A48FFDA48FF209
├─sda4
├─sda5
│ vfat FAT32 20B1-57C7
├─sda6
│ vfat FAT32 2B21-BEC5
├─sda7
│ vfat FAT32 BF5D-7B16
├─sda8
│ vfat FAT32 2D1E-B69F
├─sda9
│ vfat FAT32 361C-712A
├─sda10
│ swap 1 b6b04b23-0477-4459-a870-9c714febfac2
├─sda11
│ swap 1 2601aca4-1e34-432b-96f5-6846e160a9d7
├─sda12
│ ext4 1.0 8985e188-243d-496d-843c-ba0e0e5f5b98
├─sda13
│ ntfs New Volume
│ EEFE8A31FE89F25F
├─sda14
│ ntfs New Volume
│ 00AC900EAC8FFC7A
├─sda15
│ swap 1 d491e39d-bb42-43fe-82ab-39fa21701fe8
├─sda16
│ ntfs LENOVO
│ 4244764544763C2B
└─sda17
vfat FAT32 9604-07C2
sdb iso966 Jolie MANJARO_KDE_2021
│ 2021-01-03-09-07-36-00 0 100% /run/miso/
├─sdb1
│ iso966 Jolie MANJARO_KDE_2021
└─sdb2
vfat FAT12 MISO_EFI
7B2D-7571
Disk /dev/sda: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: ST1000LM035-1RK1
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 2C773E97-1982-4F1B-A58D-62A426CA1936
Device Start End Sectors Size Type
/dev/sda1 2048 534527 532480 260M EFI System
/dev/sda2 534528 567295 32768 16M Microsoft reserved
/dev/sda3 567296 363046911 362479616 172.8G Microsoft basic data
/dev/sda4 363046912 363048959 2048 1M Linux filesystem
/dev/sda5 363048960 364099583 1050624 513M Microsoft basic data
/dev/sda6 364099584 365150207 1050624 513M Microsoft basic data
/dev/sda7 365150208 366200831 1050624 513M Microsoft basic data
/dev/sda8 366200832 368154623 1953792 954M EFI System
/dev/sda9 369203200 370227199 1024000 500M Microsoft basic data
/dev/sda10 370227200 376371199 6144000 2.9G Linux swap
/dev/sda11 412989440 419133437 6143998 2.9G Linux swap
/dev/sda12 419133438 1079846911 660713474 315.1G Linux filesystem
/dev/sda13 1079846912 1489444863 409597952 195.3G Microsoft basic data
/dev/sda14 1489444864 1529903103 40458240 19.3G Microsoft basic data
/dev/sda15 1892902912 1899046911 6144000 2.9G Linux swap
/dev/sda16 1899046912 1951475711 52428800 25G Microsoft basic data
/dev/sda17 1951475712 1953523709 2047998 1000M EFI System
Partition 12 does not start on physical sector boundary.
Disk /dev/loop0: 27.49 MiB, 28823552 bytes, 56296 sectors
Disk /dev/loop1: 620.53 MiB, 650674176 bytes, 1270848 sectors
Disk /dev/loop2: 1.65 GiB, 1775550464 bytes, 3467872 sectors
Disk /dev/loop3: 667.84 MiB, 700276736 bytes, 1367728 sectors
Disk /dev/sdb: 28.64 GiB, 30752636928 bytes, 60063744 sectors
Disk model: Ultra
Disklabel type: dos
Disk identifier: 0x00000000
Device Boot Start End Sectors Size Id Type
/dev/sdb1 * 64 6300795 6300732 3G 0 Empty
/dev/sdb2 6300796 6308987 8192 4M ef EFI (FAT-12/16/32)
i think ’ Partition 12 does not start on physical sector boundary ’ there is a error in manjaro directory coz partition 12 is my system partition of manjaro
