Failed - Starting Remount Root and Kernel File Systems
Dopo una nuova installazione su un SDD e il ripristino tramite il software TimeShift mi restiusce il seguente errore durante l'avvio:
  Process: 746 ExecStart=/usr/lib/systemd/systemd-remount-fs (code=exited, status=1/FAILURE)
 Main PID: 746 (code=exited, status=1/FAILURE)
feb 22 16:53:51 sergii-pc systemd[1]: Starting Remount Root and Kernel File Systems...
feb 22 16:53:51 sergii-pc systemd-remount-fs[746]: mount: /: can't find UUID=8776be011-9759-4590-aa41-7c61a23bbe72.
feb 22 16:53:51 sergii-pc systemd-remount-fs[746]: /usr/bin/mount for / exited with exit status 1.
feb 22 16:53:51 sergii-pc systemd[1]: systemd-remount-fs.service: Main process exited, code=exited, status=1/FAILURE
feb 22 16:53:51 sergii-pc systemd[1]: systemd-remount-fs.service: Failed with result 'exit-code'.
feb 22 16:53:51 sergii-pc systemd[1]: Failed to start Remount Root and Kernel File Systems.
di seguito vi riporto qualche info:
Ecco il fstab:
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=E72E-4A48                            /boot/efi      vfat    umask=0077 0 2
UUID=8776be011-9759-4590-aa41-7c61a23bbe72 /              ext4    defaults,noatime 0 1
lsblk -f
loop0       squashfs 4.0                                                       0   100% /var/lib/snapd/snap/core/8592
loop1       squashfs 4.0                                                       0   100% /var/lib/snapd/snap/gtk2-common-themes/9
loop2       squashfs 4.0                                                       0   100% /var/lib/snapd/snap/snapd/6434
loop3       squashfs 4.0                                                       0   100% /var/lib/snapd/snap/gtk-common-themes/1440
loop4       squashfs 4.0                                                       0   100% /var/lib/snapd/snap/core/8689
loop5       squashfs 4.0                                                       0   100% /var/lib/snapd/snap/core18/1668
loop6       squashfs 4.0                                                       0   100% /var/lib/snapd/snap/snapd/6240
loop7       squashfs 4.0                                                       0   100% /var/lib/snapd/snap/cherrytree/5
sda
├─sda1      vfat     FAT32          E72E-4A48                             299,1M     0% /boot/efi
└─sda2      ext4     1.0            8ff4f1b0-7105-413d-85d8-5ab6b58bc849  409,3G     5% /run/media/sergii/8ff4f1b0-7105-413d-85d8-5ab6b58bc849
sdb
├─sdb1      ntfs           Recovery 72B451FFB451C66F
├─sdb2      vfat     FAT32          4853-3F97
├─sdb3
└─sdb4      ntfs                    B4F256F7F256BCF4                       61,8G    48% /run/media/sergii/B4F256F7F256BCF4
nvme0n1
├─nvme0n1p1 vfat     FAT32          8BBC-0916
└─nvme0n1p2 ext4     1.0            776be011-9759-4590-aa41-7c61a23bbe72   90,1G    12% /
Spero che qualcuno abbia un'idea per risolvere il mio problema :disappointed_relieved:
Remove the 8 in /etc/fstab
UUID=776be011-9759-4590-aa41-7c61a23bbe72 / ext4 defaults,noatime 0 1
Thx you!!!
