Failed set up
Hello dear Manjaro community.
I have a problem which I wasn't able to find in the forum through the search function.
I am using a RPi 4 with 4GB RAM and used the Manjaro-ARM-minimal-rpi4-19.12 image.
After the set up with user, root pwd and everything it reboots for the first time and gets stuck at following point
I tried it with a older image (I think it was 19.10), with another RPi4 and it always ends the same. Only difference is that the Kernel in the picture with the older image is another.
What could be the reason, if it was discussed in another thread I would be satisfied with a link to the thread, there is no need to have 2 seperate threads.
Thank you guys for your time.
That is the login screen of the minimal edition. It just has some kernel messages running over it.
Press Enter to get a clean line with login prompt.
Ok, that is now embarrassing.
Thank you very much.
