I’m trying to use Grub Customizer to update my List Configuration and Appearance settings.
However, I’m getting an error that’s basically unknown.
Here’s the error:
failed running 'grub-mkconfig -o “/boot/grub/grub.cfg” output:
. a bunch of stuff about successfully loading resources here .
/usr/bin/grub-probe: warning: unknown device type nvem0n1
error: syntax error
error: incorrect command
ensure there are no errors in /etc/default/grub
I then go to /etc/default/grub and this is the config:
GRUB_DEFAULT=“saved”
GRUB_TIMEOUT=“10”
GRUB_TIMEOUT_STYLE=“hidden”
GRUB_DISTRIBUTOR=“Manjaro”
GRUB_CMDLINE_LINUX_DEFAULT=“quiet apparmor=1 security=apparmor udev.log_priority=3”
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT="true"
#GRUB_ENABLE_CRYPTODISK="y"
GRUB_TERMINAL_INPUT="console"
#GRUB_TERMINAL_OUTPUT="console"
GRUB_GFXMODE="auto"
GRUB_GFXPAYLOAD_LINUX="keep"
#GRUB_DISABLE_LINUX_UUID="true"
GRUB_DISABLE_RECOVERY="true"
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/boot/grub/themes/starfield/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
