Fail to turn on bluetooth, worked previously
Good day.
Somehow I’m unable to turn on bluetooth, worked just fine couple of days ago. Not quite sure what was the cause.
I already:
  • Timeshift’ed back to state before last update and two updates before, but it didn’t help.
  • Switched to older version of kernel, but had no luck.
Here is info about my system.
I’m not able to find a default controller, if I ran bluetoothctl and do “power on” command.
bluetoothctl         ✔
[bluetooth]# Agent registered
[bluetooth]# power on
No default controller available
[bluetooth]#
I’m unable to find device id.
sudo dmesg | grep -i bluetooth
[    7.671708] Bluetooth: Core ver 2.22
[    7.671739] NET: Registered PF_BLUETOOTH protocol family
[    7.671740] Bluetooth: HCI device and connection manager initialized
[    7.671744] Bluetooth: HCI socket layer initialized
[    7.671747] Bluetooth: L2CAP socket layer initialized
[    7.671751] Bluetooth: SCO socket layer initialized
[    7.692407] Bluetooth: hci0: Failed to claim iso interface
[    7.717169] Bluetooth: hci0: Failed to get device id (-108)
[    7.717178] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
[    7.786101] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    7.786104] Bluetooth: BNEP filters: protocol multicast
[    7.786108] Bluetooth: BNEP socket layer initialized
Bluetooth is not blocked as it seems.
rfkill list         ✔
0: ideapad_wlan: Wireless LAN
        Soft blocked: no
        Hard blocked: no
1: ideapad_bluetooth: Bluetooth
        Soft blocked: no
        Hard blocked: no
2: phy0: Wireless LAN
        Soft blocked: no
        Hard blocked: no
3: hci0: Bluetooth
        Soft blocked: no
        Hard blocked: no
lsub | grep -i bluetooth
lsusb | grep -i bluetooth         ✔
Bus 001 Device 003: ID 0489:e0d8 Foxconn / Hon Hai Bluetooth 5.2 Adapter [MediaTek MT7922]
inxi -Fazy
  Kernel: 6.11.10-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: hpet avail: acpi_pm
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.11-x86_64
    root=UUID=683a8752-1b08-4f6c-9169-2a64c4a6c097 rw rootflags=subvol=@ quiet
    splash apparmor=1 security=apparmor
    resume=UUID=08e1c4f5-be58-4588-96af-118006cdff61 udev.log_priority=3
    rtc_cmos.use_acpi_alarm=1 mem_sleep_default=s2idle
  Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell with: albert
    tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 83AA v: Yoga Slim 7 14APU8
    serial: <superuser required> Chassis: type: 10 v: Yoga Slim 7 14APU8
  Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
    part-nu: LENOVO_MT_83AA_BU_idea_FM_Yoga Slim 7 14APU8
    uuid: <superuser required> UEFI: LENOVO v: M6CN38WW date: 11/16/2023
  ID-1: BAT0 charge: 53.5 Wh (76.5%) condition: 69.9/70.0 Wh (99.8%)
    volts: 16.4 min: 15.5 model: Celxpert L22C4PF7 type: Li-poly serial: <filter>
    status: not charging cycles: 112
  Info: model: AMD Ryzen 7 7840S with Radeon 780M Graphics bits: 64
    type: MT MCP arch: Zen 4 gen: 4 level: v4 note: check built: 2022+
    process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x74 (116) stepping: 1
    microcode: 0xA704101
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1099 min/max: 400/5132 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1099 2: 1099 3: 1099
    4: 1099 5: 1099 6: 1099 7: 1099 8: 1099 9: 1099 10: 1099 11: 1099 12: 1099
    13: 1099 14: 1099 15: 1099 16: 1099 bogomips: 105433
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Phoenix1 vendor: Lenovo
    driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
    built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
    empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, Writeback-1
    bus-ID: c3:00.0 chip-ID: 1002:15bf class-ID: 0300 temp: 36.0 C
  Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 13d3:5293
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: Samsung 0x4189 built: 2022 res: 2944x1840 dpi: 240
    gamma: 1.2 size: 312x195mm (12.28x7.68") diag: 368mm (14.5") ratio: 16:10
    modes: max: 2944x1840 min: 640x480
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M (radeonsi gfx1103_r1
    LLVM 18.1.8 DRM 3.59 6.11.10-2-MANJARO) device-ID: 1002:15bf
    memory: 3.91 GiB unified: no display-ID: :0.0
  API: Vulkan v: 1.3.295 layers: N/A device: 0 type: integrated-gpu name: AMD
    Radeon 780M (RADV GFX1103_R1) driver: mesa radv v: 24.2.8-arch1.1
    device-ID: 1002:15bf surfaces: xcb,xlib,wayland
  Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
    Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: c3:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: Lenovo driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x,
    snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
    snd_rpl_pci_acp6x, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
    snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: c3:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: c3:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.11.10-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 01:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
  IF-ID-2: vetha964a80 state: up speed: 10000 Mbps duplex: full mac: <filter>
  Device-1: Foxconn / Hon Hai Bluetooth 5.2 Adapter [MediaTek MT7922]
    driver: btusb v: 0.8 type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 1-5:3 chip-ID: 0489:e0d8 class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 3 state: down bt-service: disabled
    rfk-block: hardware: no software: no address: N/A
  Local Storage: total: 953.87 GiB used: 272.86 GiB (28.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL21T0HCLR-00BL2
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: EL1QGXA7 temp: 38.9 C
    scheme: GPT
  ID-1: / raw-size: 923.66 GiB size: 923.66 GiB (100.00%)
    used: 272.85 GiB (29.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 7.6 MiB (2.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 923.66 GiB size: 923.66 GiB (100.00%)
  ID-4: /var/log raw-size: 923.66 GiB size: 923.66 GiB (100.00%)
  ID-1: swap-1 type: partition size: 29.91 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 40.5 C mobo: N/A gpu: amdgpu temp: 36.0 C
  Fan Speeds (rpm): N/A
  Memory: total: 28 GiB available: 27.19 GiB used: 4.01 GiB (14.8%)
  Processes: 412 Power: uptime: 5m states: freeze,mem,disk suspend: s2idle
    image: 10.85 GiB services: gsd-power, power-profiles-daemon, upowerd
    Init: systemd v: 256 default: graphical tool: systemctl
  Packages: 1609 pm: pacman pkgs: 1594 libs: 357 tools: gnome-software,pamac
    pm: flatpak pkgs: 15 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9
    running-in: ghostty inxi: 3.3.36
systemctl status bluetooth.service
● bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
     Active: active (running) since Sat 2024-12-07 23:13:10 CET; 3min 46s ago
 Invocation: caac447b76be4d6cabded674a4efb1f6
       Docs: man:bluetoothd(8)
   Main PID: 2568 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 33283)
     Memory: 2M (peak: 2.3M)
        CPU: 24ms
     CGroup: /system.slice/bluetooth.service
             └─2568 /usr/lib/bluetooth/bluetoothd
Dec 07 23:13:10 the-beast bluetoothd[2568]: src/plugin.c:init_plugin() System does not support bap plugin
Dec 07 23:13:10 the-beast bluetoothd[2568]: src/plugin.c:init_plugin() System does not support bass plugin
Dec 07 23:13:10 the-beast bluetoothd[2568]: src/plugin.c:init_plugin() System does not support mcp plugin
Dec 07 23:13:10 the-beast bluetoothd[2568]: src/plugin.c:init_plugin() System does not support vcp plugin
Dec 07 23:13:10 the-beast bluetoothd[2568]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Dec 07 23:13:10 the-beast bluetoothd[2568]: src/plugin.c:init_plugin() System does not support micp plugin
Dec 07 23:13:10 the-beast bluetoothd[2568]: src/plugin.c:init_plugin() System does not support ccp plugin
Dec 07 23:13:10 the-beast bluetoothd[2568]: src/plugin.c:init_plugin() System does not support csip plugin
Dec 07 23:13:10 the-beast bluetoothd[2568]: src/plugin.c:init_plugin() System does not support asha plugin
Dec 07 23:13:10 the-beast bluetoothd[2568]: Bluetooth management interface 1.23 initialized
It’s working.
Reinstalling gnome-bluetooth package solved it for me.
