I’ve been using Manjaro for maybe a year and everything has been smooth.
But, after I updated today (it seemed like a major update), my computer can’t restart after it goes into suspend.
Normally, I can click on a key to start my computer, but, it doesn’t respond anymore. I use my computer multiple times per day, daily. So, I’ve tried numerous times. I always have to shut down my computer and restart.
So, now I guess I just have to click on Shutdown instead of Suspend until this gets resolved. It’s super annoying since I do use my computer many times per day.
Not sure what kind of info you need. I’ve got an MSI X570-A Pro motherboard if that is of any use to know.
Anyone else come across this issue after the update?
Update 2022-05-14:
This probably isn’t needed, but, just in case and to be more precise with what happens when I click on suspend: It doesn’t really suspend. It blanks the screen, but, my computer doesn’t really suspend. Normally, my computer “turns off” (suspend) and I see my power light blink. But, now, the screen blanks, my monitor power turns off, but, the computer does not go to sleep. It just locks.
Here is the system info as suggested by Olli:
Kernel: 5.15.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=[deleted by me] rw quiet apparmor=1
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: X570-A PRO (MS-7C37) v: 3.0
serial: <superuser required> UEFI: American Megatrends LLC. v: H.E0
date: 06/22/2021
RAM: total: 31.33 GiB used: 2.33 GiB (7.4%)
RAM Report:
Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
family: 0x17 (23) model-id: 8 stepping: 2 microcode: 0x800820D
L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1642 high: 2785 min/max: 1550/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2753 2: 1557
3: 1359 4: 1380 5: 1378 6: 1440 7: 2785 8: 1271 9: 1473 10: 1380 11: 1382
12: 1555 bogomips: 81625
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap
smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M]
vendor: Micro-Star MSI driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-3 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 2f:00.0
chip-ID: 1002:7340 class-ID: 0300
Device-2: KYE Systems (Mouse Systems) USB 2.0 HD1080P PC Camera type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 5-1:2 chip-ID: 0458:6006
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
gpu: amdgpu display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: DP-3 mapped: DisplayPort-2 model: 24HC1QR serial: <filter>
built: 2020 res: 1920x1080 hz: 144 dpi: 94 gamma: 1.2
size: 519x293mm (20.43x11.54") diag: 600mm (23.6") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: AMD Navi 10 HDMI Audio vendor: Micro-Star MSI
bus-ID: 2f:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 31:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: KYE Systems (Mouse Systems) USB 2.0 HD1080P PC Camera type: USB
Device-4: Audio-Technica AT2020USB+ type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-4:4 chip-ID: 0909:001c
class-ID: 0300
Sound Server-1: ALSA v: k5.15.38-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 7.95 TiB used: 67.07 GiB (0.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 023 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SV300S37A120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: BBF0 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SV300S37A120G
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD20EZBX-00AYRA0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01
ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital
rev: 1A01
ID-6: /dev/sdf maj-min: 8:80 type: USB vendor: HGST (Hitachi)
model: Touro Desk Pro size: 3.64 TiB block-size: physical: 4096 B
logical: 4096 B type: N/A serial: <filter> rev: 0000 scheme: MBR
ID-7: /dev/sdg maj-min: 8:96 type: USB vendor: SanDisk
model: U3 Cruzer Micro size: 3.82 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 4.05 scheme: GPT
Optical-1: /dev/sr0 vendor: SanDisk model: U3 Cruzer Micro rev: 4.05
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: no rw: cd-r
state: running
ID-1: / raw-size: 40 GiB size: 39.08 GiB (97.69%) used: 24.13 GiB (61.7%)
fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 12cd7feb-65e7-48c9-ad71-9de3dcebe1b4
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb3 maj-min: 8:19 label: NO_LABEL
uuid: 78AD-E39C
ID-3: /home raw-size: 71.3 GiB size: 69.63 GiB (97.66%)
used: 42.95 GiB (61.7%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: b4e887dd-3148-402a-a77f-929f5b679a94
ID-1: /dev/sda1 maj-min: 8:1 size: 465.76 GiB fs: ntfs label: N/A
uuid: [deleted by me]
ID-2: /dev/sdc1 maj-min: 8:33 size: 111.79 GiB fs: ntfs label: GPT NTFS S1
ID-3: /dev/sdf1 maj-min: 8:81 size: 3.64 TiB fs: ext4 label: Touro_4TB
ID-4: /dev/sdg1 maj-min: 8:97 size: 3.82 GiB fs: ext4 label: Cruzer 4GB
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 1-1:2 info: Pixart Imaging Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 093a:2510 class-ID: 0301
Device-2: 1-2:3 info: Microdia Redragon Mitra RGB Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 400mA chip-ID: 0c45:5004 class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Hub-4: 3-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 3-1.1:4 info: SanDisk Cruzer Micro U3 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 0781:5406 class-ID: 0806 serial: <filter>
Device-2: 3-5:3 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7c37 class-ID: 0300 serial: <filter>
Hub-5: 3-6:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 3-6.3:6 info: SimpleTech Touro Desk Pro type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 8mA
chip-ID: 4971:1013 class-ID: 0806 serial: <filter>
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-7: 4-1:2 info: Genesys Logic hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 05e3:0616 class-ID: 0900
Hub-8: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2
info: KYE Systems (Mouse Systems) USB 2.0 HD1080P PC Camera
type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
speed: 480 Mb/s power: 256mA chip-ID: 0458:6006 class-ID: 0102
serial: <filter>
Device-2: 5-3:5 info: Samsung ML-2950 Series type: Printer driver: usblp
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 2mA chip-ID: 04e8:330e
class-ID: 0701 serial: <filter>
Device-3: 5-4:4 info: Audio-Technica AT2020USB+ type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0909:001c class-ID: 0300
Hub-9: 6-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 38.0 C mem: 0.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1308
Processes: 340 Uptime: 3m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1423 pacman: 1414 lib: 372
flatpak: 0 snap: 9 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.15
