Not sure if I should start my own thread or jump on similar topics, but I also struggle to connect to Eduroam after some config updates of late from my IT dep, similar to Cannot connect to eduroam
My dmesg looks similar, but I get instead the error
[ 8664.249192] wlp61s0: deauthenticated from xx:xx:xx:xx:xx:xx (Reason: 23=IEEE8021X_FAILED)
On other devices, e.g. my Android phone, I get a certificate to “accept” when I configure Eduroam the first time. Android 13 has this (new?) feature “Trust on First Use” which seems to work fine. My colleagues on OSX are asked to accept the certificate in a popup on first connection.
When I try to configure on Manjaro I get no such question about accepting a certificate, nor do I see any option to “blindly trust” certificates.
My issue could be unrelated to certificate I suppose, but gut feeling says this might be an issue.
What exactly did your IT department change in the config options? Ask them to tell you who signed the certificate and for which domain.
Blindly trusting a certificate is never a good idea.
The usual problem with Eduroam is that Linux won’t by default downgrade authentication sessions to older and lower security protocols (SSL 3, TLS < 1.2). And apparently many Eduroam institutions have ancient radius servers that require those protocols…
