Thank you for the answers! I masked lvm2-monitor and the boot time has improved significantly.
I have some followup questions:
can I disable appArmor? Since a while it has displayed an error at launch time, along the lines of Cannot load AppArmor profile.
the two things taking up most of of the time are now firmware and loader: is loader a synonym for bootloader? If so, is there anything I can do to decrease that time? I’m thinking that decrypting the disk is probably the main reason, so not much to do there.
appArmor should be left enabled.
You can also disable ModemManager.
wpa_supplicant is for touchpad → If you haven´t got a laptop, you can disable this, too.
UNIT LOAD ACTIVE SUB DESCRIPTION
proc-sys-fs-binfmt_misc.automount loaded active running Arbitrary Executable File Formats File System Automount Point
sys-devices-pci0000:00-0000:00:02.0-drm-card0-card0\x2deDP\x2d1-intel_backlight.device loaded active plugged /sys/devices/pci0000:00/0000:00:02.0/drm/card0/card0-eDP-1/intel_backlight
sys-devices-pci0000:00-0000:00:14.0-usb1-1\x2d3.device loaded active plugged AU9540 Smartcard Reader
sys-devices-pci0000:00-0000:00:14.0-usb1-1\x2d6-1\x2d6:1.0-net-wwp0s20f0u6.device loaded active plugged L830-EB-00 LTE WWAN Modem
sys-devices-pci0000:00-0000:00:14.0-usb1-1\x2d6-1\x2d6:1.2-tty-ttyACM0.device loaded active plugged L830-EB-00 LTE WWAN Modem
sys-devices-pci0000:00-0000:00:14.0-usb2-2\x2d3-2\x2d3:1.0-host0-target0:0:0-0:0:0:0-block-sda.device loaded active plugged SD_MMC
sys-devices-pci0000:00-0000:00:14.0-usb2-2\x2d4-2\x2d4.2-2\x2d4.2:1.2-sound-card1-controlC1.device loaded active plugged HP_USB-C_Universal_Docking_Station
sys-devices-pci0000:00-0000:00:14.0-usb2-2\x2d4-2\x2d4.4-2\x2d4.4:1.0-net-enp0s20f0u4u4.device loaded active plugged RTL8153 Gigabit Ethernet Adapter
sys-devices-pci0000:00-0000:00:1c.6-0000:3d:00.0-net-wlp61s0.device loaded active plugged Wireless 8265 / 8275 (Dual Band Wireless-AC 8265)
sys-devices-pci0000:00-0000:00:1d.0-0000:3e:00.0-nvme-nvme0-nvme0n1-nvme0n1p1.device loaded active plugged LENSE20256GMSP34MEAT2TA 1
sys-devices-pci0000:00-0000:00:1d.0-0000:3e:00.0-nvme-nvme0-nvme0n1-nvme0n1p2.device loaded active plugged LENSE20256GMSP34MEAT2TA 2
sys-devices-pci0000:00-0000:00:1d.0-0000:3e:00.0-nvme-nvme0-nvme0n1.device loaded active plugged LENSE20256GMSP34MEAT2TA
sys-devices-pci0000:00-0000:00:1f.3-sound-card0-controlC0.device loaded active plugged /sys/devices/pci0000:00/0000:00:1f.3/sound/card0/controlC0
sys-devices-pci0000:00-0000:00:1f.6-net-enp0s31f6.device loaded active plugged Ethernet Connection (4) I219-V
sys-devices-platform-IFX0763:00-tpm-tpm0.device loaded active plugged /sys/devices/platform/IFX0763:00/tpm/tpm0
sys-devices-platform-IFX0763:00-tpmrm-tpmrm0.device loaded active plugged /sys/devices/platform/IFX0763:00/tpmrm/tpmrm0
sys-devices-platform-serial8250-tty-ttyS0.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS0
sys-devices-platform-serial8250-tty-ttyS1.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS1
sys-devices-platform-serial8250-tty-ttyS2.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS2
sys-devices-platform-serial8250-tty-ttyS3.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS3
sys-devices-platform-thinkpad_acpi-leds-tpacpi::kbd_backlight.device loaded active plugged /sys/devices/platform/thinkpad_acpi/leds/tpacpi::kbd_backlight
sys-devices-virtual-block-dm\x2d0.device loaded active plugged /sys/devices/virtual/block/dm-0
sys-devices-virtual-misc-rfkill.device loaded active plugged /sys/devices/virtual/misc/rfkill
sys-module-configfs.device loaded active plugged /sys/module/configfs
sys-module-fuse.device loaded active plugged /sys/module/fuse
sys-subsystem-net-devices-enp0s20f0u4u4.device loaded active plugged RTL8153 Gigabit Ethernet Adapter
sys-subsystem-net-devices-enp0s31f6.device loaded active plugged Ethernet Connection (4) I219-V
sys-subsystem-net-devices-wlp61s0.device loaded active plugged Wireless 8265 / 8275 (Dual Band Wireless-AC 8265)
sys-subsystem-net-devices-wwp0s20f0u6.device loaded active plugged L830-EB-00 LTE WWAN Modem
-.mount loaded active mounted Root Mount
boot-efi.mount loaded active mounted /boot/efi
dev-hugepages.mount loaded active mounted Huge Pages File System
dev-mqueue.mount loaded active mounted POSIX Message Queue File System
proc-sys-fs-binfmt_misc.mount loaded active mounted Arbitrary Executable File Formats File System
run-user-1000-doc.mount loaded active mounted /run/user/1000/doc
run-user-1000-gvfs.mount loaded active mounted /run/user/1000/gvfs
run-user-1000.mount loaded active mounted /run/user/1000
sys-fs-fuse-connections.mount loaded active mounted FUSE Control File System
sys-kernel-config.mount loaded active mounted Kernel Configuration File System
sys-kernel-debug.mount loaded active mounted Kernel Debug File System
sys-kernel-tracing.mount loaded active mounted Kernel Trace File System
tmp.mount loaded active mounted Temporary Directory (/tmp)
systemd-ask-password-console.path loaded active waiting Dispatch Password Requests to Console Directory Watch
systemd-ask-password-wall.path loaded active waiting Forward Password Requests to Wall Directory Watch
init.scope loaded active running System and Service Manager
session-2.scope loaded active running Session 2 of user francesco
alsa-restore.service loaded active exited Save/Restore Sound Card State
apparmor.service loaded active exited Load AppArmor profiles
avahi-daemon.service loaded active running Avahi mDNS/DNS-SD Stack
bluetooth.service loaded active running Bluetooth service
cronie.service loaded active running Periodic Command Scheduler
dbus.service loaded active running D-Bus System Message Bus
haveged.service loaded active running Entropy Daemon based on the HAVEGE algorithm
kmod-static-nodes.service loaded active exited Create list of static device nodes for the current kernel
NetworkManager.service loaded active running Network Manager
polkit.service loaded active running Authorization Manager
rtkit-daemon.service loaded active running RealtimeKit Scheduling Policy Service
sddm.service loaded active running Simple Desktop Display Manager
snapd.apparmor.service loaded active exited Load AppArmor profiles managed internally by snapd
systemd-backlight@backlight:intel_backlight.service loaded active exited Load/Save Screen Backlight Brightness of backlight:intel_backlight
systemd-backlight@leds:tpacpi::kbd_backlight.service loaded active exited Load/Save Screen Backlight Brightness of leds:tpacpi::kbd_backlight
systemd-binfmt.service loaded active exited Set Up Additional Binary Formats
systemd-cryptsetup@luks\x2d2a65951d\x2d60d5\x2d4505\x2d9d70\x2daefda7b71f99.service loaded active exited Cryptography Setup for luks-2a65951d-60d5-4505-9d70-aefda7b71f99
systemd-fsck@dev-disk-by\x2duuid-B5FD\x2d6631.service loaded active exited File System Check on /dev/disk/by-uuid/B5FD-6631
systemd-journal-flush.service loaded active exited Flush Journal to Persistent Storage
systemd-journald.service loaded active running Journal Service
systemd-logind.service loaded active running User Login Management
systemd-modules-load.service loaded active exited Load Kernel Modules
systemd-random-seed.service loaded active exited Load/Save Random Seed
systemd-remount-fs.service loaded active exited Remount Root and Kernel File Systems
systemd-sysctl.service loaded active exited Apply Kernel Variables
systemd-timesyncd.service loaded active running Network Time Synchronization
systemd-tmpfiles-setup-dev.service loaded active exited Create Static Device Nodes in /dev
systemd-tmpfiles-setup.service loaded active exited Create Volatile Files and Directories
systemd-udev-trigger.service loaded active exited Coldplug All udev Devices
systemd-udevd.service loaded active running Rule-based Manager for Device Events and Files
systemd-update-utmp.service loaded active exited Update UTMP about System Boot/Shutdown
systemd-user-sessions.service loaded active exited Permit User Sessions
tlp.service loaded active exited TLP system startup/shutdown
udisks2.service loaded active running Disk Manager
upower.service loaded active running Daemon for power management
user-runtime-dir@1000.service loaded active exited User Runtime Directory /run/user/1000
user@1000.service loaded active running User Manager for UID 1000
wpa_supplicant.service loaded active running WPA supplicant
-.slice loaded active active Root Slice
system-getty.slice loaded active active system-getty.slice
system-modprobe.slice loaded active active system-modprobe.slice
system-systemd\x2dbacklight.slice loaded active active system-systemd\x2dbacklight.slice
system-systemd\x2dcoredump.slice loaded active active system-systemd\x2dcoredump.slice
system-systemd\x2dcryptsetup.slice loaded active active Cryptsetup Units Slice
system-systemd\x2dfsck.slice loaded active active system-systemd\x2dfsck.slice
system.slice loaded active active System Slice
user-1000.slice loaded active active User Slice of UID 1000
user.slice loaded active active User and Session Slice
avahi-daemon.socket loaded active running Avahi mDNS/DNS-SD Stack Activation Socket
dbus.socket loaded active running D-Bus System Message Bus Socket
dm-event.socket loaded active listening Device-mapper event daemon FIFOs
lvm2-lvmpolld.socket loaded active listening LVM2 poll daemon socket
snapd.socket loaded active listening Socket activation for snappy daemon
systemd-coredump.socket loaded active listening Process Core Dump Socket
systemd-journald-audit.socket loaded active running Journal Audit Socket
systemd-journald-dev-log.socket loaded active running Journal Socket (/dev/log)
systemd-journald.socket loaded active running Journal Socket
systemd-rfkill.socket loaded active listening Load/Save RF Kill Switch Status /dev/rfkill Watch
systemd-udevd-control.socket loaded active running udev Control Socket
systemd-udevd-kernel.socket loaded active running udev Kernel Socket
basic.target loaded active active Basic System
blockdev@dev-mapper-luks\x2d2a65951d\x2d60d5\x2d4505\x2d9d70\x2daefda7b71f99.target loaded active active Block Device Preparation for /dev/mapper/luks-2a65951d-60d5-4505-9d70-aefda7b71f99
cryptsetup.target loaded active active Local Encrypted Volumes
getty.target loaded active active Login Prompts
graphical.target loaded active active Graphical Interface
local-fs-pre.target loaded active active Local File Systems (Pre)
local-fs.target loaded active active Local File Systems
multi-user.target loaded active active Multi-User System
network.target loaded active active Network
paths.target loaded active active Paths
remote-fs.target loaded active active Remote File Systems
slices.target loaded active active Slices
smartcard.target loaded active active Smart Card
sockets.target loaded active active Sockets
sound.target loaded active active Sound Card
swap.target loaded active active Swap
sysinit.target loaded active active System Initialization
time-set.target loaded active active System Time Set
timers.target loaded active active Timers
veritysetup.target loaded active active Local Verity Integrity Protected Volumes
logrotate.timer loaded active waiting Daily rotation of log files
man-db.timer loaded active waiting Daily man-db regeneration
pamac-cleancache.timer loaded active waiting Monthly clean packages cache
pamac-mirrorlist.timer loaded active waiting Generate mirrorlist weekly
shadow.timer loaded active waiting Daily verification of password and group files
systemd-tmpfiles-clean.timer loaded active waiting Daily Cleanup of Temporary Directories
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
132 loaded units listed. Pass --all to see loaded but inactive units, too.
To show all installed unit files use 'systemctl list-unit-files'.
