I’ve been trying for hours to find a solution and couldn’t find anything useful. Can someone give me a step by step tutorial that can help me set this up. I am new to manjiro linux and linux in general and a noob coder.
I don’t recall I ever created a guide on this but I do have a repo for the manjaro version.
Couldn’t make it work.
I run a manjaro powered webserver on a 2GB Pi4 using an argon case with a m.2 disk expansion.
So you probably did something wrong - I can’t fix that.
Please provide the links from the manual - use the example below - I don’t know if they change something since I did my setup - it is unlikely - however possible.
~~~ https://download.argon40/argon1.sh ~~~
I checked the custom packages.
The one named raspi-gpio-git needed manual intervention as I got the following message
configure.ac:5: error: version mismatch. This is Automake 1.16.5,
configure.ac:5: but the definition used by this AM_INIT_AUTOMAKE
configure.ac:5: comes from Automake 1.16.1. You should recreate
configure.ac:5: aclocal.m4 with aclocal and run automake again.
WARNING: 'automake-1.16' is probably too old.
You should only need it if you modified 'Makefile.am' or
'configure.ac' or m4 files included by 'configure.ac'.
The 'automake' program is part of the GNU Automake package:
<https://www.gnu.org/software/automake>
It also requires GNU Autoconf, GNU m4 and Perl in order to run:
<https://www.gnu.org/software/autoconf>
<https://www.gnu.org/software/m4/>
<https://www.perl.org/>
I am not an expert on these scripts - I could fix it by running automake without arguments and rerun makepkg -i - your mileage may vary.
I’ve a Raspberry pi 4 8GB ram. I erased my Manjaro and decided to go for Twister OS. Thanks for the feedback tho.
