External touch monitor not working
Hi Manjaro team,
I’ve recently bought an external touch monitor connected via an hdmi for the video signal and by an usbc for power and touch signal.
While the video part works without a problem the touch gives no signal at all and it’s a software issue since works fine on a windows machine.
I’ve tried to follow various online guide on how to solve the issue but I mostly found outdated resources or no solution at all: if someone would be able to help it would be great :wink:
command that I’ve tried:
$ sudo cat dev input event*
No such device
$ less proc/bus/input/devices:
I: Bus=0003 Vendor=2a94 Product=564d Version=0111
N: Name="G2Touch Multi-Touch by G2TSP"
P: Phys=usb-0000:00:14.0-1/input0
S: Sysfs=/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:2A94:564D.000B/input/input28
U: Uniq=
H: Handlers=event20 mouse2
B: PROP=2
B: EV=1b
B: KEY=400 0 0 0 0 0
B: ABS=260800000000003
B: MSC=20
$ lsusb and xinput list
$ sudo libinput list-devices
Device:           G2Touch Multi-Touch by G2TSP
Kernel:           /dev/input/event20
Group:            5
Seat:             seat0, default
Capabilities:     touch
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Middle emulation: n/a
Calibration:      identity matrix
Scroll methods:   none
Click methods:    none
Disable-w-typing: n/a
Accel profiles:   n/a
Rotation:         n/a
(G2Touch Multi-Touch by G2TSP)
Edit: additional info
$ inxi -Fxza
  Kernel: 5.7.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
  root=UUID=332fbe2a-5b0a-4ab4-ac78-0390163712ba rw quiet apparmor=1
  security=apparmor resume=UUID=da553de5-64fa-4e7d-b41f-970e77568c26
  udev.log_priority=3
  Desktop: GNOME 3.36.4 tk: GTK 3.24.22 wm: gnome-shell dm: GDM 3.36.3
  Distro: Manjaro Linux
  Type: Laptop System: LENOVO product: 80Q7 v: Lenovo ideapad 300-15ISK
  serial: <filter> Chassis: type: 10 v: Lenovo ideapad 300-15ISK
  serial: <filter>
  Mobo: LENOVO model: Paris 5A8 v: SDK0J40709 WIN serial: <filter>
  UEFI: LENOVO v: D5CN43WW date: 12/16/2015
  ID-1: BAT0 charge: 17.0 Wh condition: 17.0/31.7 Wh (54%) volts: 16.1/14.4
  model: SANYO L15S4A01 type: Li-poly serial: <filter> status: Full
  Topology: Dual Core model: Intel Core i7-6500U bits: 64 type: MT MCP
  arch: Skylake family: 6 model-id: 4E (78) stepping: 3 microcode: D6
  L2 cache: 4096 KiB
  bogomips: 20810
  Speed: 500 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 763 2: 560
  3: 648 4: 500
  Type: l1tf
  Type: srbds status: Vulnerable: No microcode
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:1916
  Device-2: Syntek Lenovo EasyCamera type: USB driver: uvcvideo
  bus ID: 1-4:3 chip ID: 174f:14e9 serial: <filter>
  Display: wayland server: X.Org 1.20.8 compositor: gnome-shell
  driver: intel unloaded: modesetting alternate: fbdev,vesa display ID: :0
  screens: 1
  Screen-1: 0 s-res: 3286x1080 s-dpi: 96 s-size: 869x286mm (34.2x11.3")
  s-diag: 915mm (36")
  Monitor-1: XWAYLAND0 res: 1366x768 hz: 60 dpi: 102
  size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
  Monitor-2: XWAYLAND1 res: 1920x1080 hz: 60 dpi: 143
  OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 20.1.5
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
  chip ID: 8086:9d70
  Sound Server: ALSA v: k5.7.14-1-MANJARO
  vendor: Lenovo driver: r8169 v: kernel port: 3000 bus ID: 01:00.0
  chip ID: 10ec:8168
  IF: enp1s0 state: down mac: <filter>
  Device-2: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
  v: kernel port: 3000 bus ID: 02:00.0 chip ID: 8086:3166
  Local Storage: total: 1.02 TiB used: 309.72 GiB (29.7%)
  ID-1: /dev/sda vendor: Western Digital model: WD10JPCX-24UE4T0
  size: 931.51 GiB block size: physical: 4096 B logical: 512 B
  speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1A01 scheme: GPT
  ID-2: /dev/sdb vendor: Samsung model: SSD 750 EVO 120GB size: 111.79 GiB
  block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  serial: <filter> rev: 1B6Q scheme: GPT
  ID-1: / raw size: 55.88 GiB size: 54.75 GiB (97.98%)
  used: 11.61 GiB (21.2%) fs: ext4 dev: /dev/sdb2
  ID-2: /home raw size: 93.13 GiB size: 91.17 GiB (97.89%)
  used: 16.63 GiB (18.2%) fs: ext4 dev: /dev/sda2
  ID-1: swap-1 type: partition size: 18.63 GiB used: 0 KiB (0.0%)
  priority: -2 dev: /dev/sda1
  System Temperatures: cpu: 50.0 C mobo: N/A
  Processes: 207 Uptime: 8m Memory: 11.57 GiB used: 1.79 GiB (15.4%)
  Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: 1245 apt: 1
  pacman: 1240 lib: 312 flatpak: 0 snap: 4 Shell: Zsh v: 5.8
  running in: gnome-terminal inxi: 3.1.05
$ sudo dmesg | grep usb
[  238.607833] usb 1-1: new full-speed USB device number 18 using xhci_hcd
[  238.749885] usb 1-1: New USB device found, idVendor=2a94, idProduct=564d, bcdDevice= 2.00
[  238.749895] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  238.749901] usb 1-1: Product: Multi-Touch by G2TSP
[  238.749906] usb 1-1: Manufacturer: G2Touch
[  238.762050] input: G2Touch Multi-Touch by G2TSP as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:2A94:564D.0013/input/input32
[  238.762825] hid-multitouch 0003:2A94:564D.0013: input,hidraw2: USB HID v1.11 Device [G2Touch Multi-Touch by G2TSP] on usb-0000:00:14.0-1/input0
[  238.765552] hid-generic 0003:2A94:564D.0014: hiddev1,hidraw3: USB HID v1.11 Device [G2Touch Multi-Touch by G2TSP] on usb-0000:00:14.0-1/input1
[  238.820914] usb 1-1: USB disconnect, device number 18
[  240.837887] usb 1-1: new full-speed USB device number 19 using xhci_hcd
[  240.979497] usb 1-1: New USB device found, idVendor=2a94, idProduct=564d, bcdDevice= 2.00
[  240.979506] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  240.979512] usb 1-1: Product: Multi-Touch by G2TSP
[  240.979516] usb 1-1: Manufacturer: G2Touch
[  240.988800] input: G2Touch Multi-Touch by G2TSP as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:2A94:564D.0015/input/input33
[  240.989239] hid-multitouch 0003:2A94:564D.0015: input,hidraw2: USB HID v1.11 Device [G2Touch Multi-Touch by G2TSP] on usb-0000:00:14.0-1/input0
[  240.992225] hid-generic 0003:2A94:564D.0016: hiddev1,hidraw3: USB HID v1.11 Device [G2Touch Multi-Touch by G2TSP] on usb-0000:00:14.0-1/input1
[  314.807170] usb 1-1: USB disconnect, device number 19
[  315.351121] usb 1-1: new full-speed USB device number 20 using xhci_hcd
[  315.492427] usb 1-1: New USB device found, idVendor=2a94, idProduct=564d, bcdDevice= 2.00
[  315.492428] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  315.492430] usb 1-1: Product: Multi-Touch by G2TSP
[  315.492430] usb 1-1: Manufacturer: G2Touch
[  315.497364] input: G2Touch Multi-Touch by G2TSP as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:2A94:564D.0017/input/input34
[  315.497437] hid-multitouch 0003:2A94:564D.0017: input,hidraw2: USB HID v1.11 Device [G2Touch Multi-Touch by G2TSP] on usb-0000:00:14.0-1/input0
[  315.498185] hid-generic 0003:2A94:564D.0018: hiddev1,hidraw3: USB HID v1.11 Device [G2Touch Multi-Touch by G2TSP] on usb-0000:00:14.0-1/input1
[  317.679385] usb 1-1: USB disconnect, device number 20
[  318.237978] usb 1-1: new full-speed USB device number 21 using xhci_hcd
[  318.379877] usb 1-1: New USB device found, idVendor=2a94, idProduct=564d, bcdDevice= 2.00
[  318.379881] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  318.379883] usb 1-1: Product: Multi-Touch by G2TSP
[  318.379885] usb 1-1: Manufacturer: G2Touch
[  318.386631] input: G2Touch Multi-Touch by G2TSP as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:2A94:564D.0019/input/input35
[  318.386839] hid-multitouch 0003:2A94:564D.0019: input,hidraw2: USB HID v1.11 Device [G2Touch Multi-Touch by G2TSP] on usb-0000:00:14.0-1/input0
[  318.388543] hid-generic 0003:2A94:564D.001A: hiddev1,hidraw3: USB HID v1.11 Device [G2Touch Multi-Touch by G2TSP] on usb-0000:00:14.0-1/input1
Update 18/08:
Since I work under a wayland session it’s actually correct that the device doesn’t show up in $ xinput --list since wayland mask the X server apparently.
I’ve found that the right way of working is by using $ sudo libinput debug-events for which I obtain
-event20  DEVICE_REMOVED   G2Touch Multi-Touch by G2TSP      seat0 default group5  cap:t  size 320x180mm ntouches 10
-event20  DEVICE_ADDED     G2Touch Multi-Touch by G2TSP      seat0 default group12 cap:t  size 320x180mm ntouches 10 calib
 event20  DEVICE_REMOVED   G2Touch Multi-Touch by G2TSP      seat0 default group12 cap:t  size 320x180mm ntouches 10
 event20  DEVICE_ADDED     G2Touch Multi-Touch by G2TSP      seat0 default group13 cap:t  size 320x180mm ntouches 10 calib
 event20  DEVICE_REMOVED   G2Touch Multi-Touch by G2TSP      seat0 default group13 cap:t  size 320x180mm ntouches 10
 event20  DEVICE_ADDED     G2Touch Multi-Touch by G2TSP      seat0 default group14 cap:t  size 320x180mm ntouches 10 calib
 event20  DEVICE_REMOVED   G2Touch Multi-Touch by G2TSP      seat0 default group14 cap:t  size 320x180mm ntouches 10
-event20  DEVICE_ADDED     G2Touch Multi-Touch by G2TSP      seat0 default group15 cap:t  size 320x180mm ntouches 10 calib
The device after a few touches (around 10) gets removed and the next touch seems to add it back. By looking at the journal I notice that the device gets handled two times in succession
$ journalctl
ago 18 16:21:41 ■■■■■■■■■■■■■■ kernel: usb 1-1: new full-speed USB device number 24 using xhci_hcd
ago 18 16:21:41 ■■■■■■■■■■■■■■ kernel: usb 1-1: New USB device found, idVendor=2a94, idProduct=564d, bcdDevice= 2.00
ago 18 16:21:41 ■■■■■■■■■■■■■■ kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
ago 18 16:21:41 ■■■■■■■■■■■■■■ kernel: usb 1-1: Product: Multi-Touch by G2TSP
ago 18 16:21:41 ■■■■■■■■■■■■■■ kernel: usb 1-1: Manufacturer: G2Touch
ago 18 16:21:41 ■■■■■■■■■■■■■■ kernel: input: G2Touch Multi-Touch by G2TSP as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:2A94:564D.0021/input/input39
ago 18 16:21:41 ■■■■■■■■■■■■■■ kernel: hid-multitouch 0003:2A94:564D.0021: input,hidraw2: USB HID v1.11 Device [G2Touch Multi-Touch by G2TSP] on usb-0000:00:14.0-1/input0
ago 18 16:21:41 ■■■■■■■■■■■■■■ kernel: hid-generic 0003:2A94:564D.0022: hiddev1,hidraw3: USB HID v1.11 Device [G2Touch Multi-Touch by G2TSP] on usb-0000:00:14.0-1/input1
ago 18 16:21:41 ■■■■■■■■■■■■■■ kernel: usb 1-1: USB disconnect, device number 24
ago 18 16:21:41 ■■■■■■■■■■■■■■ gnome-shell[1415]: Impossible to monitor trash: Gio.IOErrorEnum: Operation not supported
ago 18 16:21:41 ■■■■■■■■■■■■■■ gnome-shell[1415]: Impossible to enumerate trash children: Gio.IOErrorEnum: Operation not supported
ago 18 16:21:41 ■■■■■■■■■■■■■■ fido_id[5046]: usb1: Failed to open report descriptor at '/sys/devices/pci0000:00/0000:00:14.0/usb1/report_descriptor': No such file or directory
ago 18 16:21:41 ■■■■■■■■■■■■■■ fido_id[5051]: usb1: Failed to open report descriptor at '/sys/devices/pci0000:00/0000:00:14.0/usb1/report_descriptor': No such file or directory
ago 18 16:21:41 ■■■■■■■■■■■■■■ gnome-shell[1415]: Could not open device /dev/input/event20: Could not get device info for path /dev/input/event20: No such file or directory
ago 18 16:21:42 ■■■■■■■■■■■■■■ gnome-shell[1415]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
ago 18 16:21:42 ■■■■■■■■■■■■■■ gnome-shell[1415]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
ago 18 16:21:42 ■■■■■■■■■■■■■■ gnome-shell[1415]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
ago 18 16:21:42 ■■■■■■■■■■■■■■ gnome-shell[1415]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
ago 18 16:21:42 ■■■■■■■■■■■■■■ gnome-shell[1415]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
ago 18 16:21:42 ■■■■■■■■■■■■■■ gnome-shell[1415]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
ago 18 16:21:42 ■■■■■■■■■■■■■■ gnome-shell[1415]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
ago 18 16:21:42 ■■■■■■■■■■■■■■ gnome-shell[1415]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
ago 18 16:21:42 ■■■■■■■■■■■■■■ gnome-shell[1415]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
ago 18 16:21:43 ■■■■■■■■■■■■■■ kernel: usb 1-1: new full-speed USB device number 25 using xhci_hcd
ago 18 16:21:43 ■■■■■■■■■■■■■■ dbus-daemon[621]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service' requested by ':1.891' (uid=974 pid=5040 commago 18 16:21:43 ■■■■■■■■■■■■■■ kernel: usb 1-1: new full-speed USB device number 25 using xhci_hcd
ago 18 16:21:43 ■■■■■■■■■■■■■■ dbus-daemon[621]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service' requested by ':1.891' (uid=974 pid=5040 comm="/usr/lib/colord-sane " label="unconfined")
ago 18 16:21:43 ■■■■■■■■■■■■■■ dbus-daemon[621]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.Avahi.service': Unit dbus-org.freedesktop.Avahi.service not found.
ago 18 16:21:43 ■■■■■■■■■■■■■■ kernel: usb 1-1: New USB device found, idVendor=2a94, idProduct=564d, bcdDevice= 2.00
ago 18 16:21:43 ■■■■■■■■■■■■■■ kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
ago 18 16:21:43 ■■■■■■■■■■■■■■ kernel: usb 1-1: Product: Multi-Touch by G2TSP
ago 18 16:21:43 ■■■■■■■■■■■■■■ kernel: usb 1-1: Manufacturer: G2Touch
ago 18 16:21:43 ■■■■■■■■■■■■■■ kernel: input: G2Touch Multi-Touch by G2TSP as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:2A94:564D.0023/input/input40
ago 18 16:21:43 ■■■■■■■■■■■■■■ kernel: hid-multitouch 0003:2A94:564D.0023: input,hidraw2: USB HID v1.11 Device [G2Touch Multi-Touch by G2TSP] on usb-0000:00:14.0-1/input0
ago 18 16:21:43 ■■■■■■■■■■■■■■ kernel: hid-generic 0003:2A94:564D.0024: hiddev1,hidraw3: USB HID v1.11 Device [G2Touch Multi-Touch by G2TSP] on usb-0000:00:14.0-1/input1
ago 18 16:21:44 ■■■■■■■■■■■■■■ dbus-daemon[621]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service' requested by ':1.892' (uid=974 pid=5040 comm="/usr/lib/colord-sane " label="unconfined")
ago 18 16:21:44 ■■■■■■■■■■■■■■ dbus-daemon[621]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.Avahi.service': Unit dbus-org.freedesktop.Avahi.service not found.
The driver seems to be loaded, but the X11 section doesn’t show the touchscreen as a virtual input device, so can you add:
Section "InputClass"
    Identifier "libinput touchscreen catchall"
    MatchIsTouchscreen "on"
    MatchDevicePath "/dev/input/event*"
    Driver "libinput"
EndSection
to /etc/X11/xorg.conf.d/xx-libinput.conf where xx is the number of your libinput.conf and if that file does not exist, take 40 and restart X (or reboot).
I’ve done it however no change occured
What’s the output of xinput list now?
It’s the same as before
I’m out of ideas then…
:sob:
Update (both as a reply and as an edit in the first post):
Since i work under a wayland session it’s actually correct that the device doesn’t show up in $ xinput --list since wayland mask the X server apparently.
$ journalctl
