Hello everyone,
I run Manjaro on my work laptop. My desktop environment is xfce and the laptop has dual GPU (Intel/Nvidia). Here is the output of inxi:
Kernel: 5.10.36-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=0e604cf3-198d-42cd-8f8e-57e88fccaa92 rw usbcore.autosuspend=-1
quiet resume=UUID=3c5c7eb3-af88-45d8-a52a-f6012fb6e9e5
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
Type: Laptop System: ASUSTeK product: UX430UNR v: 1.0 serial: <filter>
Mobo: ASUSTeK model: UX430UNR v: 1.0 serial: <filter>
UEFI: American Megatrends v: UX430UNR.203 date: 08/23/2017
ID-1: BAT0 charge: 14.6 Wh (81.1%) condition: 18.0/48.9 Wh (36.9%)
volts: 11.6 min: 11.6 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Charging cycles: 504
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 15.5 GiB used: 3.33 GiB (21.5%)
Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: E0 cache: L2: 8 MiB bogomips: 32012
Speed: 800 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 800 2: 800 3: 801
4: 800 5: 800 6: 800 7: 800 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX150] driver: N/A alternate: nouveau
bus-ID: 01:00.0 chip-ID: 10de:1d10 class-ID: 0302
Device-3: Realtek USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 0bda:58e4 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.20.11 driver: loaded: intel
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.0.3
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.10.36-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: f040
bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 1-1.3:6 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp0s20f0u1u3 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 1-8:5 chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 301.48 GiB (63.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD8SN8U512G1002
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 1002 scheme: GPT
ID-1: / raw-size: 63.96 GiB size: 62.71 GiB (98.04%) used: 45.59 GiB (72.7%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 0e604cf3-198d-42cd-8f8e-57e88fccaa92
used: 264 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 5C6E-9EF4
ID-3: /home raw-size: 396.84 GiB size: 389.62 GiB (98.18%)
used: 255.88 GiB (65.7%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 524ab128-d587-4420-bfe2-c0879c99acd9
ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 3c5c7eb3-af88-45d8-a52a-f6012fb6e9e5
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Hub-2: 1-1:2 info: Microchip (formerly SMSC) Hub ports: 4 rev: 2.1
speed: 480 Mb/s chip-ID: 0424:2744 class-ID: 0900
Device-1: 1-1.1:4 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Device-2: 1-1.3:6 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 2.1 speed: 480 Mb/s
power: 180mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
Hub-3: 1-1.4:8 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-6:3 info: Realtek USB2.0 HD UVC WebCam type: Video
Device-2: 1-8:5 info: Intel Bluetooth wireless interface type: Bluetooth
Device-3: 1-9:7 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 04f3:0903 class-ID: 0000
Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-5: 2-1:2 info: Microchip (formerly SMSC) Hub ports: 2 rev: 3.1
speed: 5 Gb/s chip-ID: 0424:5744 class-ID: 0900
System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3000
Processes: 240 Uptime: 59m wakeups: 3 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1809 lib: 453
Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.04
I always use an external monitor which is connected to the laptop via HDMI. Since this morning, the monitor is not recognized anymore. I have tried several HDMI cables and monitors, but to no effect: screens can’t pick up any signal from my laptop.
I started by checking the latest updates I ran with pacman, suspecting that something might have been changed after reboot. But the latest update was several days (and reboots) ago, involving no kernel or graphic driver.
I also checked that the HDMI port was indeed detected with xrandr:
xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
eDP1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 310mm x 170mm
1920x1080 60.01*+ 59.93
1680x1050 59.88
1400x1050 59.98
1600x900 60.00 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1368x768 60.00 59.88 59.85
1280x800 59.81 59.91
1280x720 59.86 60.00 59.74
1024x768 60.00
1024x576 60.00 59.90 59.82
960x540 60.00 59.63 59.82
800x600 60.32 56.25
864x486 60.00 59.92 59.57
640x480 59.94
720x405 59.51 60.00 58.99
640x360 59.84 59.32 60.00
DP1 disconnected (normal left inverted right x axis y axis)
HDMI1 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
After reading a few topics on the forum, I am starting to think that my dual graphics installation might be problematic. Notably, you can see in inxi that the Nvidia card says it has no driver (only an alternate). I am not sure if this is normal.
Any idea what might be the problem? I would appreciate any guidance
Thanks for your time!
