External Monitor not detecting
Well, I installed Manjaro KDE a couple of days ago on HP Victus Ryzen 5 5600H. But when I connect an external monitor, it doesn’t detect it. I tried a couple of general solutions but none of them work. So I tried the same with the Manjaro GNOME version and there it worked (on a live USB).
Here is the full information of my system
  Kernel: 5.19.0-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
    root=UUID=6b7b0ba5-2112-43f8-94a3-76e2a591012e rw quiet
    resume=UUID=f9276abb-40be-4938-8f57-9128a290c999 udev.log_priority=3
  Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_wayland vt: 2
  Type: Laptop System: HP product: Victus by HP Laptop 16-e0xxx v: N/A
  Mobo: HP model: 88EC v: 80.56 serial: <superuser required> UEFI: AMI
    v: F.09 date: 07/16/2021
  ID-1: BAT0 charge: 40.4 Wh (81.1%) condition: 49.8/49.8 Wh (100.0%)
    volts: 17.1 min: 15.4 model: HP Primary type: Li-ion serial: <filter>
    status: charging cycles: 56
  Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 4 built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
    model-id: 0x50 (80) stepping: 0 microcode: 0xA50000C
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1416 high: 3300 min/max: 1200/4280 boost: enabled
    scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 1200 2: 1200
    3: 1300 4: 1300 5: 1200 6: 1200 7: 3300 8: 1200 9: 1200 10: 1300 11: 1300
    12: 1300 bogomips: 79080
    STIBP: always-on, RSB filling
  Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Hewlett-Packard
    driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-07) arch: Ampere code: GAxxx process: TSMC n7
    (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25a5 class-ID: 0300
  Device-2: AMD Cezanne vendor: Hewlett-Packard driver: amdgpu v: kernel
    arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie:
    gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
    active: eDP-1 empty: DP-1 bus-ID: 06:00.0 chip-ID: 1002:1638
    class-ID: 0300
  Device-3: Luxvisions Innotech HP Wide Vision HD Camera type: USB
    driver: uvcvideo bus-ID: 1-3:2 chip-ID: 30c9:000e class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
    compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau alternate: fbdev,nv,vesa gpu: nvidia,amdgpu
    display-ID: 0
  Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
  OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.47 5.19.0-2-MANJARO) v: 4.6
    Mesa 22.1.4 direct render: Yes
  Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
  Device-2: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
    link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
    driver: snd_rn_pci_acp3x v: kernel
    alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_sof_amd_renoir
    pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
    bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-4: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
    link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  Sound Server-1: ALSA v: k5.19.0-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.56 running: yes
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
    vendor: Hewlett-Packard driver: rtw89_8852ae v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8852
    class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
    bus-ID: 1-4:3 chip-ID: 0bda:2852 class-ID: e001 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 476.94 GiB used: 15.93 GiB (3.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
    SDBPNTY-512G-1006 size: 476.94 GiB block-size: physical: 512 B
    rev: HPS2 temp: 40.9 C scheme: GPT
  ID-1: / raw-size: 97.5 GiB size: 95.41 GiB (97.86%) used: 15.93 GiB (16.7%)
    fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
  ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 312 KiB
    (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
  ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p6 maj-min: 259:6
  System Temperatures: cpu: 49.6 C mobo: N/A gpu: amdgpu temp: 44.0 C
  Fan Speeds (RPM): fan-1: 0 fan-2: 0
  Processes: 312 Uptime: 21m wakeups: 1 Memory: 14.97 GiB used: 3.6 GiB
  (24.0%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
  gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 1221 lib: 325 flatpak: 0
  Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.20
Hi @jackcompass,
Looks like there might be something amiss with your drivers. Please provide the output for:
mhwd --list
As well as
mhwd --listinstalled
Edit:
Also this, what @bogdancovaciu said:
Nvidia Drivers and Wayland in KDE Plasma do not work yet as you might want. Gnome is indeed ahead of that but still has tons of issues with many applications.
Use X11 session instead.
Even using early kms as described here
still might not give the proper functionality under wayland session …
Thanks for the help but I solved the issue at last. All I had to do was install the optimus-manager and optimus-manager-qt (It’s just GUI to switch the GPU). The external monitor in my case was taking the output from the DGPU so I had to turn that on.
There are a couple of good youtube videos that can describe how to do all of that. This one video I found is really good.
