External monitor not detected by display through HDMI
Hi, I just received a new external monitor but it’s not detected at all by my laptop.
The external monitor is the Gigabyte G27Q 27" QHD IPS 144Hz.
My laptop is fairly recent: Dell Inspiron 7405 2n1 with 8 × AMD Ryzen 7 4700U with Radeon Graphics and 16GB RAM
When I type Xandr, HDMI says that it’s disconnected while it’s actually connected to the monitor. I have also tried with USB 3 with the same result. For DP, I have a mini DP on the laptop so I can’t test it until I have the right cable.
Here the output of inxi -Faz :
  Kernel: 6.1.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: hpet available: acpi_pm
    root=UUID=6d2e7cfe-b338-4801-874d-e07f3ad000c4 rw quiet splash
    mem_sleep_default=deep
    cryptdevice=UUID=0497ba9b-f001-4406-9f8a-d29d092ef26e:luks-0497ba9b-f001-4406-9f8a-d29d092ef26e
    root=/dev/mapper/luks-0497ba9b-f001-4406-9f8a-d29d092ef26e apparmor=1
  Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
  Type: Convertible System: Dell product: Inspiron 7405 2n1 v: 1.4.0
    serial: <superuser required> Chassis: type: 31 v: 1.4.0
  Mobo: Dell model: 0NNDRC v: A00 serial: <superuser required> UEFI: Dell
    v: 1.4.0 date: 10/26/2020
  ID-1: BAT0 charge: 37.0 Wh (100.0%) condition: 37.0/53.0 Wh (69.9%)
    volts: 16.2 min: 15.0 model: SMP-ATL3.56 DELL 9077G0C type: Li-poly
    serial: <filter> status: full
  Device-1: hid-0018:04F3:2A82.0004-battery model: 04F31234:00 04F3:2A82
    serial: N/A charge: N/A status: N/A
  Info: model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP
    arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x8600104
  Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
    desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 2199 high: 4080 min/max: 1400/2000 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 2042 2: 1535
    3: 1570 4: 2025 5: 2000 6: 1659 7: 2685 8: 4080 bogomips: 31948
  Type: spec_rstack_overflow mitigation: SMT disabled
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Renoir vendor: Dell driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 03:00.0
    chip-ID: 1002:1636 class-ID: 0300 temp: 54.0 C
  Device-2: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.4:8
    chip-ID: 046d:085c class-ID: 0102 serial: <filter>
  Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:3 chip-ID: 0c45:671b
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x14d4 built: 2017
    res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
    diag: 354mm (13.9") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  API: OpenGL v: 4.6 Mesa 23.1.6-2 renderer: AMD Radeon Graphics (renoir
    LLVM 15.0.7 DRM 3.49 6.1.49-1-MANJARO) direct-render: Yes
  Device-1: AMD Renoir Radeon High Definition Audio vendor: Dell
    bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Dell
    driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Logitech H390 headset with microphone
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-1.3:6 chip-ID: 046d:0a8f class-ID: 0300
  Device-5: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.1.49-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.78 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:5 chip-ID: 8087:0029
    class-ID: e001
  Local Storage: total: 476.94 GiB used: 330.28 GiB (69.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC511 NVMe 512GB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 11004101 temp: 53.9 C
    scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
    used: 330.28 GiB (70.6%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-0497ba9b-f001-4406-9f8a-d29d092ef26e
    used: 468 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 54.0 C mobo: 42.0 C gpu: amdgpu temp: 55.0 C
  Fan Speeds (rpm): cpu: 3390
  Processes: 301 Uptime: 1h 29m wakeups: 4 Memory: total: 16 GiB note: est.
  available: 15 GiB used: 8.01 GiB (53.4%) Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
  Packages: 1961 pm: pacman pkgs: 1900 libs: 442 tools: pamac pm: flatpak
  pkgs: 34 pm: snap pkgs: 27 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
  running-in: konsole inxi: 3.3.29
Copy the terminal output and post it as “preformatted text” by using the </> icon button.
Hdmi is often only fed by the dedicated GPU and might not work when using on-demand card mode. Have a look at this thread, it might help: AMD discrete GPU cannot be initialised
why is it irrelevant?
Linked to the wrong post. Edited my post above.
Thanks a lot. I included the output in my initial post.
Yep, AMD Ryzen 7 4700U with Radeon Graphics. Try to disable the integrated radeon graphic card in Bios. Hopefully, once the AMD is permanently on your hdmi should work.
I don’t see any option in the BIOS to deactivate the Radeon Graphic card. Is there any other way I can do it?
Actually, all of a sudden, it started working. No idea why. Thanks a lot.
