I’m no longer able to use my Nvidia Pascal (1070Ti) GPU with this update. I replaced the nvidia-575 packages with nvidia-580 as others in this thread (which this post was split from) have, but my external monitor no longer appears as an output device, though the GPU itself still appears to be detected.
I’m using Manjaro Stable, KDE Plasma 6, and Wayland, running the latest LTS kernel. eDP-1 is my laptop’s internal screen.
$ kscreen-doctor -o
Output: 1 eDP-1 4926fa1b-509f-4c18-afa6-fb8b33241fcb
enabled
connected
priority 1
Panel
replication source:0
Modes: 1:2880x1800@90.00*! 2:1600x1200@59.87 3:1600x1200@89.91 4:1280x1024@59.90 5:1280x1024@89.91 6:1024x768@59.92 7:1024x768@89.72 8:2560x1600@59.99 9:2560x1600@89.95 10:1920x1200@59.88 11:1920x1200@89.91 12:1280x800@59.81 13:1280x800@89.89 14:2880x1620@59.96 15:2880x1620@89.94 16:2560x1440@59.96 17:2560x1440@89.92 18:1920x1080@59.96 19:1920x1080@89.93 20:1600x900@59.95 21:1600x900@89.88 22:1368x768@59.88 23:1368x768@89.74 24:1280x720@59.85 25:1280x720@89.80
Custom modes: None
Geometry: 0,0 1800x1125
Scale: 1.6
Rotation: 1
Overscan: 0
Vrr: incapable
RgbRange: Automatic
HDR: incapable
Wide Color Gamut: incapable
ICC profile: none
Color profile source: sRGB
Color power preference: prefer efficiency and performance
Brightness control: supported, set to 100% and dimming to 100%
Color resolution: automatic (10), range: [6; 12] bits per color
Allow EDR: always
Sharpness control: unsupported
Automatic brightness: unsupported
$ nvidia-smi -L
GPU 0: NVIDIA GeForce GTX 1070 Ti (UUID: GPU-de9781ec-8992-2ba4-6c02-2d08e6204402)
$ pamac list --installed | grep nvidia
lib32-nvidia-580xx-utils 580.173.02-2 multilib 290.4 MB
linux-firmware-nvidia 20260622-1 core 108.6 MB
linux612-nvidia-580xx 580.173.02-4 extra 92.4 MB
linux618-nvidia-580xx 580.173.02-5 extra 92.3 MB
mhwd-nvidia 610.43.03-1 extra 1.1 kB
mhwd-nvidia-390xx 390.157-28 extra 1.9 kB
mhwd-nvidia-470xx 470.256.02-19 extra 1.8 kB
mhwd-nvidia-580xx 580.173.02-3 extra 1.9 kB
nvidia-580xx-settings 580.173.02-2 extra 1.6 MB
nvidia-580xx-utils 580.173.02-3 extra 947.2 MB
nvidia-driver-assistant 0.23.48.01-7 extra 994.9 kB
nvidia-prime 1.0-6 extra 758 bytes
I then disconnected the GPU and rebooted, and I couldn’t get to Plasma even on the laptop screen then:
$ journalctl --user -xeu plasma-plasmashell.service --boot -1
Jul 12 16:18:07 roxide systemd[1294]: Starting KDE Plasma Workspace...
░░ Subject: A start job for unit UNIT has begun execution
░░ Defined-By: systemd
░░ A start job for unit UNIT has begun execution.
░░ The job identifier is 238.
Jul 12 16:18:08 roxide plasmashell[2096]: could not connect to display
Jul 12 16:18:08 roxide plasmashell[2096]: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
Jul 12 16:18:08 roxide plasmashell[2096]: Could not load the Qt platform plugin "xcb" in "" even though it was found.
Jul 12 16:18:08 roxide plasmashell[2096]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: wayland-brcm, wayland-egl, wayland, vkkhrdisplay, linuxfb, offscreen, minimalegl, eglfs, minimal, xcb, vnc.
Jul 12 16:18:08 roxide systemd-coredump[2100]: [🡕] Process 2096 (plasmashell) of user 1000 dumped core.
Stack trace of thread 2096:
#0 0x00007f4b62a9981c n/a (libc.so.6 + 0x9981c)
#1 0x00007f4b62a3e150 raise (libc.so.6 + 0x3e150)
#2 0x00007f4b62a2567d abort (libc.so.6 + 0x2567d)
#3 0x00007f4b632968e4 n/a (libQt6Core.so.6 + 0x968e4)
#4 0x00007f4b6329771d _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x9771d)
#5 0x00007f4b63ae72da n/a (libQt6Gui.so.6 + 0xe72da)
#6 0x00007f4b63bae228 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x1ae228)
#7 0x00007f4b63389175 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x189175)
#8 0x00007f4b63bae32b _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x1ae32b)
#9 0x00007f4b654fe876 _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xfe876)
#10 0x0000558d92012345 n/a (plasmashell + 0x26345)
#11 0x00007f4b62a27741 n/a (libc.so.6 + 0x27741)
#12 0x00007f4b62a27879 __libc_start_main (libc.so.6 + 0x27879)
#13 0x0000558d92013c25 n/a (plasmashell + 0x27c25)
░░ Subject: Process 2096 (plasmashell) dumped core
░░ Documentation: man:core(5)
░░ Process 2096 (plasmashell) crashed and dumped core.
░░ This usually indicates a programming error in the crashing program and
░░ should be reported to its vendor as a bug.
Jul 12 16:18:08 roxide systemd[1294]: plasma-plasmashell.service: Main process exited, code=dumped, status=6/ABRT
░░ Subject: Unit process exited
░░ An ExecStart= process belonging to unit UNIT has exited.
When I log out, the greeter does work via the nvidia card, I’m able to see it on my external monitor (connected only via the nvidia card). When I log in using X11, I get no output on either screen (possibly unsurprising as my X11 config isn’t maintained). When I log in as a newly-created test account, the problem is the same.
fc-cache -r made no difference to any of these issues.
I tried holding back all of the nvidia updates using IgnorePkg and running the rest, unfortunately (but unsurprisingly) that left me with a system that didn’t display anything on either screen. Timeshifted back to before the update for now (in the hope that someone here has a good suggestion, or that I think of something else to try).
I’ve tried updating my kernel to 7.1.3 and trying the update again, which gave me the second behaviour (no plasmashell on either screen - external monitor continued to show the disk encryption prompt, internal screen showed boot messages and could be switched to other TTYs and used, but no DE could be started).
Here’s the output of inxi -zv8, first with the working 575 drivers:
Kernel: 6.18.36-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
root=UUID=16dcafc5-10e0-41c5-857e-5abba1b78367 rw quiet
cryptdevice=UUID=f8342397-87d0-4c39-a7e9-68a9d9e84a7c:luks-f8342397-87d0-4c39-a7e9-68a9d9e84a7c
root=/dev/mapper/luks-f8342397-87d0-4c39-a7e9-68a9d9e84a7c apparmor=1
security=apparmor
resume=/dev/mapper/luks-3edc484e-94c5-47d9-a2bb-c2f49463338f
udev.log_priority=3 i915.enable_psr=0
Desktop: KDE Plasma v: 6.6.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: PCSpecialist product: Standard v: Standard
serial: <filter>
Mobo: TongFang model: PH4TRX1 v: Standard serial: <filter> part-nu: 0001
uuid: 6ab4dd00-474b-11ec-be4f-ea734fc8010a Firmware: UEFI vendor: American
Megatrends LLC. v: N.1.12A02 date: 06/03/2021
ID-1: BAT0 charge: 34.2 Wh (95%) condition: 36/52.2 Wh (68.9%) volts: 12.01
min: 11.61 model: standard type: Li-ion serial: <filter> charging:
status: not charging cycles: N/A
System RAM: total: 16 GiB available: 15.36 GiB used: 4.73 GiB (30.8%)
igpu: 60 MiB
Array-1: capacity: 128 GiB note: check slots: 2 modules: 2 EC: None
max-module-size: 64 GiB note: est.
Device-1: Controller0-ChannelA-DIMM0 type: DDR4 detail: synchronous
size: 8 GiB speed: 2667 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMSX8GX4M1A2666C18 serial: N/A
Device-2: Controller1-ChannelA-DIMM0 type: DDR4 detail: synchronous
Slot: 1 type: PCIe status: available length: short volts: 3.3
bus-ID: 00:00.0
bus-ID: 00:00.0
bus-ID: 00:00.0
bus-ID: 00:00.0
bus-ID: 00:00.0
Info: model: 11th Gen Intel Core i5-11300H socket: U3E1 bits: 64
type: MT MCP arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xBE
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
desc: 4x1.2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1093 min/max: 400/4400 base/boost: 3100/4400 scaling:
driver: intel_pstate governor: powersave volts: 0.9 V ext-clock: 100 MHz
cores: 1: 1093 2: 1093 3: 1093 4: 1093 5: 1093 6: 1093 7: 1093 8: 1093
bogomips: 49766
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp
rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2
tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Type: indirect_target_selection mitigation: Aligned branch/return thunks
conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Type: vmscape status: Not affected
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: AIstone Global
driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
built: 2020-21 ports: active: none off: eDP-1 empty: DP-1, DP-2, DP-3,
DP-4, HDMI-A-1, HDMI-A-2, HDMI-A-3, HDMI-A-4 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA GP104 [GeForce GTX 1070 Ti] driver: nvidia v: 575.64.05
alternate: nouveau,nova_core,nvidia_drm non-free: 550-580.xx+
status: legacy-active (EOL~2028-09-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 4
link-max: lanes: 16 ports: active: DP-5 off: HDMI-A-5
empty: DP-6,DP-7,DVI-D-1 bus-ID: 03:00.0 chip-ID: 10de:1b82 class-ID: 0300
Device-3: Anker PowerConf C200
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.1:6 chip-ID: 291a:3369
class-ID: 0300 serial: <filter>
Device-4: Chicony Integrated IR Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:5 chip-ID: 04f2:b71a
Display: unspecified server: X.Org v: 24.1.12 with: Xwayland v: 24.1.12
compositor: kwin_wayland driver: X: loaded: modesetting,nvidia dri: iris
gpu: i915,nvidia,nvidia-nvswitch display-ID: :1 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: DP-5 res: mode: 2560x1440 hz: 75 scale: 100% (1) dpi: 90
size: 725x428mm (28.54x16.85") diag: 842mm (33.15") modes: N/A
drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: nvidia mesa v: 575.64.05
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1070 Ti/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.4.350 layers: 4 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1070 Ti driver: nvidia v: 575.64.05 device-ID: 10de:1b82
surfaces: N/A device: 1 type: integrated-gpu name: Intel Iris Xe Graphics
(TGL GT2) driver: mesa intel v: 26.1.2-arch1.2 device-ID: 8086:9a49
surfaces: N/A
Device-1: Intel 500 Series Family On-Package High Definition Audio
vendor: AIstone Global driver: snd_hda_intel v: kernel
alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 4 link-max: lanes: 16
bus-ID: 03:00.1 chip-ID: 10de:10f0 class-ID: 0403
API: ALSA v: k6.18.36-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.6 status: n/a (root, process)
with: pipewire-media-session status: active tools: pw-cat,pw-cli
Server-4: PulseAudio v: 17.0-98-gb096 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.2.4:13
chip-ID: 0b95:1790 class-ID: 0a00 serial: <filter>
IF: eth0 state: up speed: 1000 Mbps duplex: unknown mac: <filter>
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
IP v4: <filter> scope: global
IP v6: <filter> scope: global
IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:8 chip-ID: 8087:0026
class-ID: e001
Device-1: luks-f8342397-87d0-4c39-a7e9-68a9d9e84a7c maj-min: 253:0
type: LUKS dm: dm-0 size: 936.65 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 936.66 GiB
Device-2: luks-3edc484e-94c5-47d9-a2bb-c2f49463338f maj-min: 253:1
type: LUKS dm: dm-1 size: 16.91 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 16.91 GiB
Local Storage: total: 953.87 GiB used: 754.97 GiB (79.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU010TZ
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 34.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 315d 14h cycles: 1,287
read-units: 36,242,905 [18.5 TB] written-units: 33,029,083 [16.9 TB]
ID-1: / raw-size: 936.65 GiB size: 920.88 GiB (98.32%)
used: 754.97 GiB (82.0%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
maj-min: 253:0 mapped: luks-f8342397-87d0-4c39-a7e9-68a9d9e84a7c
label: N/A uuid: 16dcafc5-10e0-41c5-857e-5abba1b78367
used: 688 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: NO_LABEL uuid: 5FDE-EF93
ID-1: swap-1 type: partition size: 16.91 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 253:1
mapped: luks-3edc484e-94c5-47d9-a2bb-c2f49463338f label: swap
uuid: d35a017c-b749-45c8-a658-20dae2741e10
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-4: 3-1:2 info: Genesys Logic Hub ports: 2 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
Hub-5: 3-1.2:18 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 3-1.2.3:19 info: 8BitDo IDLE type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 2dc8:3109 class-ID: 0300
serial: <filter>
Hub-6: 3-2:3 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 3-2.1:6 info: Anker PowerConf C200 type: video,audio,HID
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo interfaces: 5 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 200mA
chip-ID: 291a:3369 class-ID: 0300 serial: <filter>
Device-2: 3-2.2:9 info: Logitech G502 SE HERO Gaming Mouse type: mouse,HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c08b class-ID: 0300
serial: <filter>
Hub-7: 3-2.3:11 info: VIA Labs VL812 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2812
Device-1: 3-2.3.4:12 info: Metadot Das Keyboard 4 type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 24f0:0140 class-ID: 0300
Device-2: 3-6:5 info: Chicony Integrated IR Camera type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b71a class-ID: 0e02
serial: <filter>
Device-3: 3-10:8 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-8: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-9: 4-1:2 info: Genesys Logic GL3523 Hub ports: 2 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
Device-1: 4-1.1:11 info: Realtek Card Reader type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 800mA chip-ID: 0bda:0316 class-ID: 0806
serial: <filter>
Hub-10: 4-1.2:12 info: Genesys Logic Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
Device-1: 4-1.2.4:13 info: ASIX AX88179 Gigabit Ethernet
type: communication,CDC-data driver: cdc_ncm interfaces: 2 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 184mA
Hub-11: 4-2:3 info: Genesys Logic Hub ports: 4 rev: 3.2
Hub-12: 4-2.3:5 info: VIA Labs VL812 Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0812
System Temperatures: cpu: 48.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 2180 libs: 498 tools: pamac pm: flatpak pkgs: 0
1: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
2: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
3: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
4: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
5: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
6: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
7: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
Active pacman repo servers in: /etc/pacman.d/mirrorlist.arch4edu
1: https://repository.arch4edu.org/$arch
Processes:
CPU top: 5 of 317
1: cpu: 23.3% command: firefox pid: 2025 mem: 882.7 MiB (5.6%)
2: cpu: 23.0% command: systemd pid: 4196 mem: 12.9 MiB (0.0%)
3: cpu: 11.7% command: firefox pid: 3785 mem: 306.5 MiB (1.9%)
4: cpu: 8.9% command: kwin_wayland pid: 1233 mem: 287.6 MiB (1.8%)
5: cpu: 5.7% command: firefox pid: 3051 mem: 305.9 MiB (1.9%)
Memory top: 5 of 317
1: mem: 882.7 MiB (5.6%) command: firefox pid: 2025 cpu: 23.3%
2: mem: 580.2 MiB (3.6%) command: firefox pid: 2634 cpu: 3.0%
3: mem: 420.1 MiB (2.6%) command: firefox pid: 2208 cpu: 1.7%
4: mem: 395.8 MiB (2.5%) command: plasmashell pid: 1358 cpu: 2.4%
5: mem: 352.1 MiB (2.2%) command: firefox pid: 2214 cpu: 1.3%
Processes: 317 Power: uptime: 12m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.04 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 260 default: graphical tool: systemctl
Compilers: clang: 22.1.6 gcc: 16.1.1 Shell: Sudo (sudo) v: 1.9.17p2
default: Bash v: 5.3.15 running-in: konsole inxi: 3.3.41
And with the 580 drivers (but still on kernel 6.18, as that seemed like the closest-to-working configuration):
Kernel: 6.18.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
security=apparmor
Desktop: KDE Plasma v: 6.6.6 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
serial: <filter>
ID-1: BAT0 charge: 34.2 Wh (95%) condition: 36/52.2 Wh (68.9%) volts: 11.99
System RAM: total: 16 GiB available: 15.36 GiB used: 2.65 GiB (17.2%)
igpu: 60 MiB
bus-ID: 00:00.0
bus-ID: 00:00.0
bus-ID: 00:00.0
bus-ID: 00:00.0
bus-ID: 00:00.0
microcode: 0xBE
Speed (MHz): avg: 400 min/max: 400/4400 base/boost: 3100/4400 scaling:
cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400 8: 400
bogomips: 49766
xtpr
built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4,
HDMI-A-1, HDMI-A-2, HDMI-A-3, HDMI-A-4 bus-ID: 00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Device-2: NVIDIA GP104 [GeForce GTX 1070 Ti] driver: nvidia v: 580.173.02
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.0
Display: unspecified server: X.Org v: 24.1.13 with: Xwayland v: 24.1.13
gpu: i915 display-ID: :1 screens: 1
Screen-1: 0 s-res: 2880x1800 s-dpi: 96 s-size: 762x476mm (30.00x18.74")
s-diag: 898mm (35.37")
Monitor-1: eDP-1 model-id: CSO 0x1402 built: 2020 res: mode: 2880x1800
hz: 90 scale: 100% (1) dpi: 242 gamma: 1.2 chroma: red: x: 0.639 y: 0.329
green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
size: 302x188mm (11.89x7.4") diag: 356mm (14") ratio: 16:10
modes: 2880x1800
drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 26.1.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL
GT2) device-ID: 8086:9a49 memory: 15 GiB unified: yes
API: Vulkan v: 1.4.350 layers: 4 device: 0 type: integrated-gpu name: Intel
Iris Xe Graphics (TGL GT2) driver: mesa intel v: 26.1.4-arch1.1
device-ID: 8086:9a49 surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1070 Ti driver: nvidia v: 580.173.02
device-ID: 10de:1b82 surfaces: N/A
API: ALSA v: k6.18.38-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.7 status: n/a (root, process)
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.2.4:7
IF: eth0 state: up speed: N/A duplex: unknown mac: <filter>
class-ID: e001
Components:
Components:
Local Storage: total: 953.87 GiB used: 754.39 GiB (79.1%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 35.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 315d 15h cycles: 1,288
read-units: 36,254,903 [18.5 TB] written-units: 33,052,037 [16.9 TB]
used: 754.39 GiB (81.9%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
Hub-5: 3-1.2:4 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 3-1.2.3:7 info: 8BitDo IDLE type: HID driver: hid-generic,usbhid
interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 2dc8:3109 class-ID: 0300 serial: <filter>
serial: <filter>
serial: <filter>
Device-1: 4-1.1:4 info: Realtek Card Reader type: mass storage
serial: <filter>
Hub-10: 4-1.2:6 info: Genesys Logic Hub ports: 4 rev: 3.2
Device-1: 4-1.2.4:7 info: ASIX AX88179 Gigabit Ethernet
System Temperatures: cpu: 46.0 C mobo: N/A
Packages: pm: pacman pkgs: 2185 libs: 501 tools: pamac pm: flatpak pkgs: 0
Processes:
CPU top: 5 of 281
1: cpu: 12.2% command: syncthing pid: 1193 mem: 123.4 MiB (0.7%)
2: cpu: 8.6% command: plasmashell pid: 1402 mem: 396.9 MiB (2.5%)
3: cpu: 6.0% command: konsole pid: 1957 mem: 192.9 MiB (1.2%)
4: cpu: 4.7% command: kwin_wayland pid: 1253 mem: 258.5 MiB (1.6%)
5: cpu: 4.6% command: duplicati pid: 1572 mem: 228.9 MiB (1.4%)
Memory top: 5 of 281
1: mem: 396.9 MiB (2.5%) command: plasmashell pid: 1402 cpu: 8.6%
2: mem: 258.5 MiB (1.6%) command: kwin_wayland pid: 1253 cpu: 4.7%
3: mem: 228.9 MiB (1.4%) command: duplicati pid: 1572 cpu: 4.6%
4: mem: 192.9 MiB (1.2%) command: konsole pid: 1957 cpu: 6.0%
5: mem: 141.0 MiB (0.8%) command: baloo_file pid: 1252 cpu: 3.5%
Processes: 281 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle
Init: systemd v: 261 default: graphical tool: systemctl
