External Monitor is not Getting Detected
I am running Wayland via GPU and lately facing the issue after upgrade. GPU hardware is being detected but failed to load.
lspci | grep -E "VGA|3D"
00:02.0 VGA compatible controller: Intel Corporation CoffeeLake-H GT2 [UHD Graphics 630]
01:00.0 VGA compatible controller: NVIDIA Corporation TU117M [GeForce GTX 1650 Mobile / Max-Q] (rev a1)
inxi -Gxx
Use of uninitialized value $data{"current_link_speed"} in substitution (s///) at /usr/bin/inxi line 36113.
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
    driver: i915 v: kernel arch: Gen-9.5 ports: active: eDP-1 empty: none
    bus-ID: 00:02.0 chip-ID: 8086:3e9b
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
    driver: nvidia v: 575.64.05 arch: Turing bus-ID: 01:00.0 chip-ID: 10de:1f91
  Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-11:3 chip-ID: 13d3:56a2
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x1521 res: 1920x1080 hz: 60
    dpi: 142 diag: 394mm (15.5")
  API: EGL v: 1.5 platforms: device: 0 drv: iris device: 1 drv: swrast gbm:
    drv: iris surfaceless: drv: iris wayland: drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.5-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2) device-ID: 8086:3e9b display-ID: :1.0
    wl: wayland-info,wlr-randr x11: xdpyinfo,xprop
udo dmesg | grep -i nvidia
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.18-x86_64 root=UUID=90c832b2-0211-4812-b547-9ff6be81397a rw quiet splash nvidia_drm.modeset=1 resume=UUID=ddee902c-f07b-4935-9dc3-c699b55d3e6d udev.log_priority=3
[    0.074758] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.18-x86_64 root=UUID=90c832b2-0211-4812-b547-9ff6be81397a rw quiet splash nvidia_drm.modeset=1 resume=UUID=ddee902c-f07b-4935-9dc3-c699b55d3e6d udev.log_priority=3
[    3.672020] nvidia: loading out-of-tree module taints kernel.
[    3.672043] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[    3.823306] nvidia-nvlink: Nvlink Core is being initialized, major device number 235
[    3.825414] nvidia 0000:01:00.0: enabling device (0000 -> 0003)
[    3.825559] nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
[    3.873875] NVRM: loading NVIDIA UNIX Open Kernel Module for x86_64  575.64.05  Release Build  (root@)
[    4.372726] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for x86_64  575.64.05  Release Build  (root@)
[    4.527825] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[   36.389965] nvidia 0000:01:00.0: not ready 1023ms after resume; waiting
[   37.477953] nvidia 0000:01:00.0: not ready 2047ms after resume; waiting
[   39.589979] nvidia 0000:01:00.0: not ready 4095ms after resume; waiting
[   44.197951] nvidia 0000:01:00.0: not ready 8191ms after resume; waiting
[   52.901933] nvidia 0000:01:00.0: not ready 16383ms after resume; waiting
[   69.797973] nvidia 0000:01:00.0: not ready 32767ms after resume; waiting
[  103.589959] nvidia 0000:01:00.0: not ready 65535ms after resume; giving up
[  103.650890] [drm:nv_drm_load [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NvKmsKapiDevice
[  103.651190] [drm:nv_drm_register_drm_device [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to register device
nvidia-smi
No devices were found
ps: I am running my laptop with power cable plugged in, so it can’t be power throttle.
Please provide the complete output of:
inxi -zv8
  Kernel: 6.18.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.23.0
  Type: Laptop System: ASUSTeK product: TUF Gaming FX505GT_FX505GT v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: FX505GT v: 1.0 serial: <superuser required>
    uuid: <superuser required> Firmware: UEFI vendor: American Megatrends
    v: FX505GT.311 date: 02/08/2021
  ID-1: BAT0 charge: 34.3 Wh (100%) condition: 34.3/48 Wh (71.4%) volts: 12.21
    min: 11.68 model: Simplo SDI ICR18650 type: Li-ion serial: <filter>
    charging: status: full control: start: N/A end: 100% cycles: 41
  System RAM: total: 32 GiB available: 31.19 GiB used: 3.35 GiB (10.7%)
  Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
    speed: spec: 3200 MT/s actual: 2667 MT/s volts: note: check curr: 1 min: 1
    max: 1 width (bits): data: 64 total: 64 manufacturer: Crucial
    part-no: CT16G4SFRA32A.C8FF serial: <filter>
  Device-2: ChannelA-DIMM1 type: no module installed
  Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
    speed: 2667 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: Samsung part-no: M471A2K43DB1-CTD
    serial: <filter>
  Device-4: ChannelB-DIMM1 type: no module installed
  Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62399
    smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
    ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
    class-ID: 0300
    driver: nvidia v: 575.64.05 alternate: nouveau,nova_core,nvidia_drm
    non-free: 550-580.xx+ status: current (as of 2025-11; EOL~2026-12-xx)
    arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022
    bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:3
    chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x1521 built: 2020 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red:
    x: 0.592 y: 0.349 green: x: 0.329 y: 0.557 blue: x: 0.153 y: 0.118 white:
    x: 0.314 y: 0.329 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
    GT2) device-ID: 8086:3e9b memory: 30.46 GiB unified: yes display-ID: :1.0
  Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK
    driver: sof-audio-pci-intel-cnl alternate: snd_soc_avs,
    snd_sof_pci_intel_cnl, snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:a348
    class-ID: 0403
  Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
    bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
  API: ALSA v: k6.18.12-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
    vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4
  Local Storage: total: 1.38 TiB used: 410.2 GiB (29.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron
    model: 2200V MTFDHBA512TCK size: 476.94 GiB block-size: physical: 512 B
    fw-rev: P1MA0V4 temp: 28.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
    tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
  ID-1: / raw-size: 185.24 GiB size: 181.28 GiB (97.86%)
    used: 48.7 GiB (26.9%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
    label: N/A uuid: 90c832b2-0211-4812-b547-9ff6be81397a
    used: 328 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 474B-0703
  ID-3: /home raw-size: 283.38 GiB size: 277.87 GiB (98.06%)
    used: 151.66 GiB (54.6%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:4
    label: Home FS uuid: bfedcb7c-0b0f-4b4b-a600-bccac5dfa4b6
  ID-4: /mnt/Dump raw-size: 781.51 GiB size: 768.17 GiB (98.29%)
    used: 176.16 GiB (22.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: Misc
    uuid: 1d4f105c-ff09-4ba4-960d-7e968d38304d
  ID-5: /mnt/Projects raw-size: 150 GiB size: 146.59 GiB (97.72%)
    used: 33.67 GiB (23.0%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: Projects
    uuid: d1447d2a-4f0a-479e-b882-298a77094592
  ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: ddee902c-f07b-4935-9dc3-c699b55d3e6d
  Device-1: 1-2:2 info: MosArt 2.4G INPUT DEVICE type: keyboard,mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 062a:385a class-ID: 0301
  Device-2: 1-11:3 info: IMC Networks USB2.0 HD UVC WebCam type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 13d3:56a2 class-ID: 0e02
    serial: <filter>
  Device-3: 1-14:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  System Temperatures: cpu: 38.0 C pch: 44.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1440 libs: 372 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    4: https://manjaro.ynh.ovh/stable/$repo/$arch
    5: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    7: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    8: https://mirror.meowsmp.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 286
  1: cpu: 2.8% command: wireplumber pid: 876 mem: 20.1 MiB (0.0%)
  2: cpu: 2.4% command: brave pid: 2838 mem: 661.6 MiB (2.0%)
  3: cpu: 1.8% command: brave pid: 3154 mem: 313.9 MiB (0.9%)
  4: cpu: 1.2% command: brave pid: 2890 mem: 367.4 MiB (1.1%)
  5: cpu: 1.1% command: brave pid: 3882 mem: 294.7 MiB (0.9%)
  Memory top: 5 of 286
  1: mem: 661.6 MiB (2.0%) command: brave pid: 2838 cpu: 2.4%
  2: mem: 409.1 MiB (1.2%) command: plasmashell pid: 986 cpu: 1.0%
  3: mem: 367.4 MiB (1.1%) command: brave pid: 2890 cpu: 1.2%
  4: mem: 322.6 MiB (1.0%) command: brave pid: 3828 cpu: 0.2%
  5: mem: 313.9 MiB (0.9%) command: brave pid: 3154 cpu: 1.8%
  Processes: 286 Power: uptime: 2h 14m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.42 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 259 default: graphical
    tool: systemctl
  Compilers: clang: 21.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole
    inxi: 3.3.40
I have fixed this issue by installing properietry driver linux618-nvidia-575xx and adding nvidia_drm.fbdev=1.
sudo dmesg | grep -i nvidia
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.18-x86_64 root=UUID=90c832b2-0211-4812-b547-9ff6be81397a rw quiet splash nvidia_drm.modeset=1 nvidia_drm.fbdev=1 resume=UUID=ddee902c-f07b-4935-9dc3-c699b55d3e6d udev.log_priority=3
[    0.074780] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.18-x86_64 root=UUID=90c832b2-0211-4812-b547-9ff6be81397a rw quiet splash nvidia_drm.modeset=1 nvidia_drm.fbdev=1 resume=UUID=ddee902c-f07b-4935-9dc3-c699b55d3e6d udev.log_priority=3
[    4.027803] nvidia: module license 'NVIDIA' taints kernel.
[    4.027809] nvidia: module license taints kernel.
[    4.623919] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
[    4.631829] nvidia 0000:01:00.0: enabling device (0000 -> 0003)
[    4.631962] nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
[    4.684912] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  575.64.05  Fri Jul 18 16:01:21 UTC 2025
[    4.930545] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[    4.968643] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  575.64.05  Fri Jul 18 15:45:08 UTC 2025
[    5.188037] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[    5.367031] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input19
[    5.367091] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input20
[    5.367146] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input21
[    5.367199] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input22
[    6.528733] [drm] Initialized nvidia-drm 0.0.0 for 0000:01:00.0 on minor 1
[    6.621978] nvidia 0000:01:00.0: [drm] fb1: nvidia-drmdrmfb frame buffer device
