External monitor is not detected
Hello everyone,
I’m writing to you because I’m having trouble with my screen. I’m on a laptop, and an external screen is undetected when I plug it in.
I use X11.
    ~  echo $XDG_SESSION_TYPE         ✔
x11
    ~  glxinfo | grep server         ✔
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
    ~  xrandr         127 ✘
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
   1920x1080    144.00*+  60.00 +  59.97    59.96    59.93
   1680x1050     59.95    59.88
   1400x1050     74.76    59.98
   1600x900      59.99    59.94    59.95    59.82
   1280x1024     85.02    75.02    60.02
   1400x900      59.96    59.88
   1280x960      85.00    60.00
   1440x810      60.00    59.97
   1368x768      59.88    59.85
   1280x800      59.99    59.97    59.81    59.91
   1152x864      75.00
   1280x720      60.00    59.99    59.86    59.74
   1024x768      85.00    75.05    60.04    85.00    75.03    70.07    60.00
   1024x768i     86.96
   960x720       85.00    75.00    60.00
   928x696       75.00    60.05
   896x672       75.05    60.01
   1024x576      59.95    59.96    59.90    59.82
   960x600       59.93    60.00
   832x624       74.55
   960x540       59.96    59.99    59.63    59.82
   800x600       85.00    75.00    70.00    65.00    60.00    85.14    72.19    75.00    60.32    56.25
   840x525       60.01    59.88
   864x486       59.92    59.57
   700x525       74.76    59.98
   800x450       59.95    59.82
   640x512       85.02    75.02    60.02
   700x450       59.96    59.88
   640x480       85.09    60.00    85.01    72.81    75.00    59.94
   720x405       59.51    58.99
   720x400       85.04
   684x384       59.88    59.85
   640x400       59.88    59.98    85.08
   576x432       75.00
   640x360       59.86    59.83    59.84    59.32
   640x350       85.08
   512x384       85.00    75.03    70.07    60.00
   512x384i      87.06
   512x288       60.00    59.92
   416x312       74.66
   480x270       59.63    59.82
   400x300       85.27    72.19    75.12    60.32    56.34
   432x243       59.92    59.57
   320x240       85.18    72.81    75.00    60.05
   360x202       59.51    59.13
   360x200       85.04
   320x200       85.27
   320x180       59.84    59.32
   320x175       85.27
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
I think the problem may be related to this:
    ~  systemctl status optimus-manager         ✔
Unit optimus-manager.service could not be found.
There is some info about my system.
I am looking forward to the guides. Thanks in advance for your help!
Mykhailo.
Hi @MOrydoroha, and welcome!
I think you are correct, because in your system information, forr the Nvidia card, it states:
driver: N/A
So I think you are correct. But there might be a driver available for it. Please provide the output of:
mhwd --listinstalled
And
mhwd --list
…please.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Thank you for the fast reply!
Here is the requested info:
> Installed PCI configs:
mhwd --list
> 0000:37:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2023.09.12                true            PCI
> 0000:01:00.0 (0300:10de:28e0) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-prime            2023.03.23               false            PCI
          video-nvidia            2024.05.03               false            PCI
           video-linux            2024.05.06                true            PCI
> 0000:00:02.0 (0300:8086:46a6) Display controller Intel Corporation:
may you also post the followings
and
glxinfo | grep server && echo $XDG_SESSION_TYPE
x11
the nvidia-driver is missing as you can read in the inxi
Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: ASUSTeK
    driver: N/A alternate
you should install the propietary driver first
sudo mhwd -a pci nonfree 0300
as desribed in the wiki
afterwards install envycontrol
pamac install envycontrol
and switch to nvidia
sudo envycontrol -s nvidia
[sudo] password for morydoroha:
> Using config 'video-hybrid-intel-nvidia-prime' for device: 0000:01:00.0 (0300:10de:28e0) Display controller nVidia Corporation
> Using config 'video-hybrid-intel-nvidia-prime' for device: 0000:00:02.0 (0300:8086:46a6) Display controller Intel Corporation
> Installing video-hybrid-intel-nvidia-prime...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-prime/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
 core downloading...
 extra downloading...
 multilib downloading...
warning: nvidia-utils-550.90.07-7 is up to date -- skipping
warning: nvidia-prime-1.0-4 is up to date -- skipping
warning: lib32-nvidia-utils-550.90.07-2 is up to date -- skipping
warning: linux419-nvidia-550.90.07-4 is up to date -- skipping
warning: linux61-nvidia-550.90.07-5 is up to date -- skipping
error: target not found: linux65-nvidia
Error: pacman failed!
Error: script failed!
try to force the installation
sudo mhwd -f -i pci video-hybrid-intel-nvidia-prime
Still failing
 core downloading...
that’s the problem, the kernel 6.5 is eol (end of live). you need to update your system to an actual kernel first.
Thank you so much!
