Once in a while and for 5 seconds, the video stops, stutters (has hiccups as described by this user that seem to have had a similar issue). For me the sound keeps playing but the video stops and shakes on one frame with tearing
I have had the problem in the past but at some point it stopped happening (did not note if it was related to an update or something). And now it is back.
Do any people have the same issue and/or have a suggestion on how to fix this when it happens. I have noted that it does not happen in Chrome for some reason.
Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=93dada4b-96f7-45c7-8470-ada17ca54ba0 rw quiet
resume=UUID=8512e443-1042-4738-b21e-62d870dea538 udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Gigabyte product: B450 AORUS PRO v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B450 AORUS PRO-CF serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: F40 date: 05/16/2019
System RAM: available: 15.55 GiB used: 13.65 GiB (87.8%)
Info: model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701011
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 2199 high: 2200 min/max: 2200/3800 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
3: 2200 4: 2196 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 bogomips: 91056
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdt_a rdtscp
rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-3 off: HDMI-A-1 empty: DP-1,DP-2 bus-ID: 0b:00.0
chip-ID: 1002:731f class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
s-diag: 583mm (22.95")
Monitor-1: DP-3 mapped: DisplayPort-2 pos: primary model: MSI G241
serial: <filter> built: 2021 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 note: disabled
model: Hitachi X90W D-sub serial: <filter> built: 2007 res: 1920x1080 dpi: 89
gamma: 1.2 size: 410x257mm (16.14x10.12") diag: 484mm (19.1") ratio: 16:10
modes: max: 1440x900 min: 720x400
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon RX 5600 XT (navi10
LLVM 15.0.7 DRM 3.49 6.1.31-2-MANJARO) direct-render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: off
tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0
Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter driver: ath9k
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 06:00.0
chip-ID: 168c:0032 class-ID: 0280
IF: wlp6s0 state: down mac: <filter>
IF-ID-1: br-0558f922d295 state: down mac: <filter>
IF-ID-2: br-0de98694374a state: down mac: <filter>
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-3: br-243699c81122 state: down mac: <filter>
all]
IF-ID-4: br-2880dbdda371 state: down mac: <filter>
all]
IF-ID-5: br-36fe3c32fa4a state: down mac: <filter>
all]
IF-ID-6: br-385f93c9ad61 state: down mac: <filter>
all]
IF-ID-7: br-7010342be934 state: down mac: <filter>
all]
IF-ID-8: br-7f0d9a9ee644 state: down mac: <filter>
all]
IF-ID-9: br-96779ce50630 state: down mac: <filter>
all]
IF-ID-10: br-a9b4e58656fd state: down mac: <filter>
all]
IF-ID-11: br-b1c2fab0d062 state: down mac: <filter>
all]
IF-ID-12: br-cb449da941ba state: down mac: <filter>
all]
IF-ID-13: br-d51ead3a3690 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
Message: Output throttled. IPs: 2; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-14: br-e41d4b81a978 state: down mac: <filter>
all]
IF-ID-15: br-e795634c8607 state: down mac: <filter>
all]
IF-ID-16: br-e88710e59675 state: down mac: <filter>
all]
IF-ID-17: docker0 state: down mac: <filter>
all]
IF-ID-18: veth44cfc66 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-19: veth68a9369 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-20: veth73f4f76 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Local Storage: total: 7.73 TiB used: 420.78 GiB (5.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z42105 temp: 32.9 C
scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000VN008-2DR166
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5980 serial: <filter> fw-rev: SC60 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000VN008-2DR166
ID-1: / raw-size: 448.58 GiB size: 440.47 GiB (98.19%)
used: 410.76 GiB (93.3%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 93dada4b-96f7-45c7-8470-ada17ca54ba0
ID-1: swap-1 type: partition size: 17.18 GiB used: 10.02 GiB (58.3%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: swap
uuid: 8512e443-1042-4738-b21e-62d870dea538
ID-1: /dev/sda1 maj-min: 8:1 size: 1024 KiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda2 maj-min: 8:2 size: 127 MiB fs: <superuser required>
ID-3: /dev/sda3 maj-min: 8:3 size: 3.64 TiB fs: <superuser required>
ID-4: /dev/sdb1 maj-min: 8:17 size: 1024 KiB fs: <superuser required>
ID-5: /dev/sdb2 maj-min: 8:18 size: 127 MiB fs: <superuser required>
ID-6: /dev/sdb3 maj-min: 8:19 size: 3.64 TiB fs: <superuser required>
Device-1: 1-4:2 info: Genesys Logic Logilink CR0012 type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 05e3:0745 class-ID: 0806
serial: <filter>
Hub-4: 3-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0
chip-ID: 05e3:0612 class-ID: 0900
Device-1: 3-2:3 info: Logitech Premium Optical Wheel Mouse (M-BT58)
type: mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: 046d:c03e class-ID: 0301
Device-2: 3-4:4 info: Holtek USB-HID Keyboard type: keyboard,HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 04d9:0295 class-ID: 0300
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-6: 4-1:2 info: Genesys Logic Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 144mA
System Temperatures: cpu: 56.4 C mobo: N/A gpu: amdgpu temp: 59.0 C
mem: 60.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 371 Uptime: 52m wakeups: 0 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1853
pm: pacman pkgs: 1838 libs: 457 tools: pakku,pamac,paru pm: appimage pkgs: 0
pm: flatpak pkgs: 4 pm: snap pkgs: 11 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.27
