Hello,
I have a feeling others have this problem too but it is so confusing to me I can’t understand solutions offered in other threads so any help is really appreciated.
inxi -zv8
[flex@thinkpad Smart Plug]$ inxi -zv8
Kernel: 6.1.100-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=a964c5a4-8b74-4c63-9380-46cf11acfada rw quiet apparmor=1
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Laptop System: LENOVO product: 20L5000UUS v: ThinkPad T480
Mobo: LENOVO model: 20L5000UUS v: SDK0K17763 WIN
serial: <superuser required>
part-nu: LENOVO_MT_20L5_BU_Think_FM_ThinkPad T480
uuid: <superuser required> UEFI: LENOVO v: N24ET70W (1.45 )
date: 07/22/2022
ID-1: BAT0 charge: 20.1 Wh (100.0%) condition: 20.1/24.0 Wh (83.8%)
volts: 12.7 min: 11.5 model: SMP 01AV421 type: Li-poly serial: <filter>
status: full cycles: 239
ID-2: BAT1 charge: 18.2 Wh (100.0%) condition: 18.2/23.9 Wh (75.9%)
volts: 12.7 min: 11.4 model: LGC 01AV490 type: Li-poly serial: <filter>
status: full cycles: 228
System RAM: total: 12 GiB available: 11.58 GiB used: 3.36 GiB (29.0%)
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous unbuffered
(unregistered) size: 4 GiB speed: 2400 MT/s volts: curr: 1 width (bits):
data: 64 total: 64 manufacturer: Samsung part-no: M471A5143SB1-CRC
serial: <filter>
Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: 2400 MT/s volts: curr: 1 width (bits):
data: 64 total: 64 manufacturer: Crucial part-no: BLS8G4S240FSD.16FBD
serial: <filter>
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 505 high: 700 min/max: 400/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 642 4: 700
5: 700 6: 400 7: 400 8: 400 bogomips: 32012
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: DP-4,DP-5
off: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: Chicony Integrated Camera (1280x720@30) driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:4
chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: i965 gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
s-diag: 1052mm (41.43")
Monitor-1: not-matched mapped: DP-2-2 pos: primary,right res: 1920x1080
hz: 60 dpi: 93 size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Monitor-2: not-matched mapped: DP-2-3 pos: left res: 1920x1080 hz: 60
Monitor-3: eDP-1 note: disabled model: LG Display 0x0521 built: 2016
res: 1920x1080 dpi: 158 gamma: 1.2 chroma: red: x: 0.580 y: 0.361 green:
x: 0.333 y: 0.561 blue: x: 0.161 y: 0.118 white: x: 0.314 y: 0.329
size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9
modes: 1920x1080
API: EGL v: 1.4 hw: drv: intel i965 platforms: device: 0 drv: i965
device: 1 drv: swrast gbm: drv: i965 surfaceless: drv: i965 x11: drv: i965
inactive: wayland
API: OpenGL v: 4.6 compat-v: 3.3 vendor: intel mesa v: 21.3.9-arch.6
glx-v: 1.4 direct-render: yes renderer: Mesa DRI Intel UHD Graphics 620
(KBL GT2) device-ID: 8086:5917 memory: 2.93 GiB unified: yes
API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu
name: Intel UHD Graphics 620 (KBL GT2) driver: mesa intel
v: 24.1.3-manjaro1.1 device-ID: 8086:5917 surfaces: xcb,xlib
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo ThinkPad T480
driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
snd_sof_pci_intel_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Device-2: Lenovo ThinkPad Dock USB Audio
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-1.4.4:6 chip-ID: 17ef:306f class-ID: 0300
API: ALSA v: k6.1.100-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.2.1 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
Device-1: Intel Ethernet I219-V vendor: Lenovo ThinkPad T480 driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d8 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24fd
class-ID: 0280
Info: services: mld, NetworkManager, sshd, systemd-timesyncd,
wpa_supplicant
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 8087:0a2b
class-ID: e001
Local Storage: total: 931.51 GiB used: 268.98 GiB (28.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 033 scheme: GPT
ID-1: / raw-size: 76.44 GiB size: 75.07 GiB (98.20%) used: 37.14 GiB (49.5%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: manjaro-root
uuid: a964c5a4-8b74-4c63-9380-46cf11acfada
ID-2: /boot/efi raw-size: 500 MiB size: 496 MiB (99.20%)
used: 25.7 MiB (5.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: SYSTEM
uuid: D691-2D28
ID-3: /home raw-size: 288.56 GiB size: 282.96 GiB (98.06%)
used: 199.32 GiB (70.4%) fs: ext4 dev: /dev/sda6 maj-min: 8:6
label: manjaro-home uuid: cfccf10e-3c1d-4000-a6fa-d69a88d11b89
ID-4: /run/media/flex/ntfs-share raw-size: 100 GiB size: 100 GiB (100.00%)
used: 32.5 GiB (32.5%) fs: ntfs dev: /dev/sda7 maj-min: 8:7
label: ntfs-share uuid: 36DEABA3181A8B49
ID-1: swap-1 type: partition size: 10.36 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda10 maj-min: 8:10 label: swap
uuid: 89997f3c-de33-4e1e-9e6f-a2220dd1237b
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 293.6 GiB fs: ntfs label: Windows
uuid: 989C91C19C9199F8
ID-3: /dev/sda4 maj-min: 8:4 size: 1.05 GiB fs: ntfs label: Recovery
uuid: E650920F5091E719
ID-4: /dev/sda8 maj-min: 8:8 size: 70 GiB fs: exfat label: MACOS-SHARE
uuid: F7CE-DAFE
ID-5: /dev/sda9 maj-min: 8:9 size: 91 GiB fs: exfat label: MACOS
uuid: 77F8-DB37
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-4:2 info: Lenovo USB Billboard type: billboard,HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 17ef:3076 class-ID: 0300
serial: <filter>
Device-2: 1-7:3 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0a2b class-ID: e001
Device-3: 1-8:4 info: Chicony Integrated Camera (1280x720@30) type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b604 class-ID: 0e02
serial: <filter>
Device-4: 1-9:5 info: Synaptics Metallica MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 06cb:009a class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
Device-1: 2-3:2 info: Realtek Card Reader type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 800mA chip-ID: 0bda:0316 class-ID: 0806
serial: <filter>
Hub-4: 3-1:2 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:3073
Device-1: 3-1.2:3 info: Lenovo Professional Wireless Keyboard and Mouse
Combo type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
chip-ID: 17ef:609b class-ID: 0300
Hub-5: 3-1.4:4 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1
Device-1: 3-1.4.1:5 info: Lenovo Optical Mouse type: mouse
chip-ID: 17ef:608d class-ID: 0301
Device-2: 3-1.4.4:6 info: Lenovo ThinkPad Dock USB Audio type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-7: 4-1:2 info: Lenovo USB3.0 Hub ports: 4 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 17ef:3072
Hub-8: 4-1.4:3 info: Lenovo USB3.0 Hub ports: 1 rev: 3.0
System Temperatures: cpu: 42.0 C pch: 38.5 C mobo: N/A
Fan Speeds (rpm): fan-1: 0
Packages: pm: pacman pkgs: 1845 libs: 461 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://mirrors2.manjaro.org/stable/$repo/$arch
Processes:
CPU top: 5 of 264
1: cpu: 24.1% command: brave pid: 3381 mem: 228.8 MiB (1.9%)
2: cpu: 15.2% command: brave pid: 3181 mem: 256.5 MiB (2.1%)
3: cpu: 11.7% command: brave pid: 2884 mem: 479.5 MiB (4.0%)
4: cpu: 7.2% command: brave pid: 2924 mem: 157.5 MiB (1.3%)
5: cpu: 5.2% command: brave pid: 2981 mem: 232.8 MiB (1.9%)
Memory top: 5 of 264
1: mem: 479.5 MiB (4.0%) command: brave pid: 2884 cpu: 11.7%
2: mem: 422.0 MiB (3.5%) command: plasmashell pid: 1843 cpu: 2.8%
3: mem: 311.4 MiB (2.6%) command: spectacle pid: 2847 cpu: 1.7%
4: mem: 261.9 MiB (2.2%) command: brave pid: 3141 cpu: 3.4%
5: mem: 256.5 MiB (2.1%) command: brave pid: 3181 cpu: 15.2%
Processes: 264 Power: uptime: 12m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 4.62 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: Bash v: 5.2.26
running-in: konsole inxi: 3.3.35
I am using Manjaro KDE on a laptop connected to two external monitors. I have a multi-boot setup so when I boot up initially I get the grub bootloader screen, which appears on both monitors, and I can choose which OS to boot in to so I choose Manjaro but then the external monitors loose signal and they go blank and start going to sleep… the monitors display the message “No signal”. If I wiggle the mouse and press keys on the keyboard the monitors come back on.
Sometimes on one of the monitors the desktop is black like in this screenshot I made showing the display on both external monitors right after a boot up:
The desktop on that left monitor is still usable, just the background is black.
I’m not really sure how to debug but I found this command in another thread so I ran it right after the problem happened:
sudo journalctl -b | grep plasmashell
[flex@thinkpad Smart Plug]$ sudo journalctl -b | grep plasmashell
Aug 05 12:31:24 thinkpad plasmashell[1843]: KPackageStructure of KPluginMetaData(pluginId:"org.kde.plasma.simplemenu"
, fileName: "/usr/share/plasma/plasmoids/org.kde.plasma.simplemenu/metadata.json") does not match requested format "P
lasma/Applet"
Aug 05 12:31:24 thinkpad plasmashell[1843]: kde.plasmashell: Aborting shell load: The activity manager daemon (kactiv
itymanagerd) is not running.
Aug 05 12:31:24 thinkpad plasmashell[1843]: kde.plasmashell: If this Plasma has been installed into a custom prefix,
verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Aug 05 12:31:25 thinkpad plasmashell[1843]: kf.plasma.quick: Applet preload policy set to 1
Aug 05 12:31:25 thinkpad plasmashell[1843]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui
/main.qml:196:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for prop
erty "minimumWidth"
erty "minimumWidth"
erty "minimumWidth"
Aug 05 12:31:27 thinkpad systemd[1]: media-4TB1.automount: Got automount request for /media/4TB1, triggered by 2150 (
plasmashell)
Aug 05 12:31:27 thinkpad plasmashell[1843]: org.kde.plasma.kicker: Entry is not valid "applications:org.kde.kdeconnec
t.sms.desktop" 0x0
Aug 05 12:31:27 thinkpad plasmashell[1843]: org.kde.plasma.kicker: Entry is not valid "applications:teams.desktop" 0x
0
Aug 05 12:31:27 thinkpad plasmashell[1843]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/cont
ents/ui/main.qml:162:21: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
Aug 05 12:31:27 thinkpad plasmashell[1843]: qml: SystemTray ItemLoader: Invalid state, cannot determine source!
Aug 05 12:31:29 thinkpad plasmashell[1843]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to Print
erFinishingsChanged(QString, QString, QString, uint, QString, bool) :
Aug 05 12:31:30 thinkpad plasmashell[1843]: org.kde.plasma.kicker: Entry is not valid "applications:org.kde.kdeconnec
t.sms.desktop" 0x0
Aug 05 12:31:30 thinkpad plasmashell[1843]: org.kde.plasma.kicker: Entry is not valid "applications:teams.desktop" 0x
0
Aug 05 12:31:30 thinkpad plasmashell[1843]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/cont
Aug 05 12:31:30 thinkpad plasmashell[1843]: qml: SystemTray ItemLoader: Invalid state, cannot determine source!
Aug 05 12:31:30 thinkpad plasmashell[1843]: qt.core.qobject.connect: QObject::connect: No such signal Solid::Backends
::Fstab::FstabStorageAccess::repairRequested(QString)
::Fstab::FstabStorageAccess::repairDone(Solid::ErrorType, QVariant, QString)
Aug 05 12:31:31 thinkpad plasmashell[1843]: file:///usr/lib/qt6/qml/org/kde/plasma/workspace/calendar/MonthViewHeader
.qml:50:26: QML PlasmoidHeading: Binding loop detected for property "leftInset"
Aug 05 12:31:31 thinkpad plasmashell[1843]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Aug 05 12:31:32 thinkpad plasmashell[1843]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Aug 05 12:31:33 thinkpad plasmashell[1843]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Aug 05 12:32:27 thinkpad plasmashell[1843]: qt.core.qobject.connect: QObject::connect: No such signal Solid::Backends
Aug 05 12:32:41 thinkpad plasmashell[1843]: qt.core.qobject.connect: QObject::connect: No such signal Solid::Backends
Aug 05 12:33:27 thinkpad plasmashell[1843]: qt.core.qobject.connect: QObject::connect: No such signal Solid::Backends
Aug 05 12:34:27 thinkpad plasmashell[1843]: qt.core.qobject.connect: QObject::connect: No such signal Solid::Backends
Aug 05 12:35:27 thinkpad plasmashell[1843]: qt.core.qobject.connect: QObject::connect: No such signal Solid::Backends
Aug 05 12:36:27 thinkpad plasmashell[1843]: qt.core.qobject.connect: QObject::connect: No such signal Solid::Backends
If I run this command:
kquitapp5 plasmashell && kstart5 plasmashell
…it fixes things but next time I reboot I will probably have the same problem and sometimes it occurs even while I am already booted… the displays flicker and loose signal so I have to press keys on the keyboard and they come back on.
What is the problem here? I haven’t done a fresh Manjaro install for around 2 years. Do I need to re-install everything or what other debugging could I do please?
Cheers,
Flex
