I connected an external HDMI monitor with my laptop for the first time today. The same monitor worked fine on another Manjaro+KDE laptop before. Now, it freezes with delays between a few to tens of minutes and only unfreezes when I e.g. change the framerate in system settings.
I can still change the brightness via ddcutil
or xrandr
. Changing framerate with xrandr -r
/--rate
does not unfreeze it, only via system settings. journalctl
contains nothing relevant at the time of the freeze. I read about setting NVidia “performance mode”, but all the config UIs I found to set that are for Ubuntu or Windows. Restarting kwin_x11
or toggling compositing does not help. I read about some old driver bugs, but those were supposedly fixed years ago. My graphics card works fine otherwise.
A full ddcutil
dump during the frozen state is here: ddcutils - Pastebin.com
My system, kernel and display info and some relevant package versions are here:
[fabian@nova ~]$ inxi -zv8
Kernel: 6.12.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=2db0e7ff-e65a-4547-bfee-11c52d36d6d3 rw quiet
cryptdevice=UUID=5f8bee24-4ef7-4133-a91d-725356237ac9:luks-5f8bee24-4ef7-4133-a91d-725356237ac9
root=/dev/mapper/luks-5f8bee24-4ef7-4133-a91d-725356237ac9 splash
resume=/dev/mapper/luks-cb4b194c-d901-4f40-8ab6-2a5b4bb59bb5
udev.log_priority=3 snd-hda-intel.model=clevo-p950
Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.14.0
wm: kwin_x11 tools: avail: cinnamon-screensaver vt: 2 dm: SDDM
Type: Laptop System: Notebook product: PD5x_7xSNC_SND_SNE v: N/A
serial: <superuser required> Chassis: No Enclosure type: 10
Mobo: Notebook model: PD5x_7xSNC_SND_SNE serial: <superuser required>
uuid: <superuser required> UEFI: INSYDE v: 1.07.07TDES date: 03/28/2023
ID-1: BAT0 charge: 73.8 Wh (100.0%) condition: 73.8/77.3 Wh (95.5%)
volts: 12.6 min: 11.4 model: Notebook BAT type: Li-ion serial: <filter>
status: full
System RAM: total: 64 GiB available: 62.5 GiB used: 30.04 GiB (48.1%)
Device-1: Controller0-ChannelA-DIMM0 type: DDR5 detail: synchronous
size: 32 GiB speed: 4800 MT/s volts: curr: 1 width (bits): data: 64
total: 64 manufacturer: Kingston part-no: 9905789-057.A00G
serial: <filter>
Device-2: Controller1-ChannelA-DIMM0 type: DDR5 detail: synchronous
serial: <filter>
Info: model: 13th Gen Intel Core i7-13700HX bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xBF (191) stepping: 2
microcode: 0x3A
Topology: cpus: 1x dies: 1 clusters: 10 cores: 16 threads: 24 mt: 8 tpc: 2
st: 8 smt: enabled cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32
KiB, 8x64 KiB L2: 14 MiB desc: 8x1.2 MiB, 2x2 MiB L3: 30 MiB
desc: 1x30 MiB
Speed (MHz): avg: 2034 min/max: 800/2100:1500 scaling:
driver: intel_pstate governor: powersave cores: 1: 2034 2: 2034 3: 2034
4: 2034 5: 2034 6: 2034 7: 2034 8: 2034 9: 2034 10: 2034 11: 2034 12: 2034
13: 2034 14: 2034 15: 2034 16: 2034 17: 2034 18: 2034 19: 2034 20: 2034
21: 2034 22: 2034 23: 2034 24: 2034 bogomips: 110616
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep serialize sha_ni smap smep split_lock_detect ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
xtopology xtpr
conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Alder Lake-HX GT1 [UHD Graphics 770] vendor: CLEVO/KAPOK
driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:4688 class-ID: 0300
Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile]
vendor: CLEVO/KAPOK driver: nvidia v: 570.144 alternate: nouveau,nvidia_drm
non-free: 550-570.xx+ status: current (as of 2025-04) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4
speed: 16 GT/s lanes: 8 ports: active: none empty: DP-3, DP-4, HDMI-A-3,
eDP-2 bus-ID: 01:00.0 chip-ID: 10de:28e0 class-ID: 0300
Device-3: Bison BisonCam NB Pro driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:2 chip-ID: 5986:214c
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia unloaded: nouveau
alternate: fbdev,nv,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1354x381mm (53.31x15.00")
s-diag: 1407mm (55.38")
Monitor-1: HDMI-1-0 pos: right res: N/A size: 597x336mm (23.5x13.23")
modes: N/A
Monitor-2: eDP-1 pos: primary,left res: mode: 2560x1440 hz: 165
scale: 100% (1) dpi: 171 size: 381x214mm (15x8.43") diag: 437mm (17.2")
modes: N/A
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau drv: nvidia
platforms: device: 0 drv: nvidia device: 1 drv: nouveau device: 2 drv: iris
device: 3 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11:
drv: iris inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (ADL-S GT1)
device-ID: 8086:4688 memory: 30.52 GiB unified: yes
API: Vulkan v: 1.4.313 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4060 Laptop GPU driver: nvidia v: 570.144 device-ID: 10de:28e0
surfaces: N/A device: 1 type: integrated-gpu name: Intel UHD Graphics
(ADL-S GT1) driver: mesa intel v: 25.0.5-arch1.1 device-ID: 8086:4688
surfaces: N/A
Device-1: Intel Raptor Lake High Definition Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0403
Device-2: NVIDIA AD107 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 01:00.1
chip-ID: 10de:22be class-ID: 0403
API: ALSA v: k6.12.28-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.2 status: off with: wireplumber status: off
tools: pw-cat,pw-cli,wpctl
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
with: pulseaudio-alsa type: plugin tools: pacat, pactl, pamixer,
pavucontrol, pulsemixer
Device-1: Intel Raptor Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7a70 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: CLEVO/KAPOK driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 6d:00.0
IF: enp109s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:3 chip-ID: 8087:0026
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: yes pairing: yes class-ID: 7c010c
Device-1: luks-cb4b194c-d901-4f40-8ab6-2a5b4bb59bb5 maj-min: 254:1
type: LUKS dm: dm-1 size: 128 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 128 GiB
Device-2: luks-5f8bee24-4ef7-4133-a91d-725356237ac9 maj-min: 254:0
type: LUKS dm: dm-0 size: 3.51 TiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 3.51 TiB
Local Storage: total: 3.64 TiB used: 2.81 TiB (77.1%)
model: WD BLACK SN850X 4000GB size: 3.64 TiB block-size: physical: 512 B
fw-rev: 624361WD temp: 39.9 C scheme: GPT
ID-1: / raw-size: 3.51 TiB size: 3.46 TiB (98.40%) used: 2.81 TiB (81.2%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-5f8bee24-4ef7-4133-a91d-725356237ac9 label: root
uuid: 2db0e7ff-e65a-4547-bfee-11c52d36d6d3
used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: BOOT
uuid: E23A-375C
ID-1: swap-1 type: partition size: 128 GiB used: 1.5 MiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-cb4b194c-d901-4f40-8ab6-2a5b4bb59bb5 label: swap
uuid: b5bbd8c7-16aa-4447-b8b6-7b110d4bfeb1
Device-1: 1-2:4 info: Areson Corp Laser mouse type: mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 25a7:2410 class-ID: 0300
Device-2: 1-3:5 info: MosArt 2 4Ghz Wireless Transceiver [for Delux M618
Plus Vertical Mouse] type: keyboard,mouse driver: hid-generic,usbhid
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 062a:4c01 class-ID: 0301
Device-3: 1-8:2 info: Bison BisonCam NB Pro type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 5986:214c class-ID: 0e02 serial: <filter>
Device-4: 1-14:3 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
System Temperatures: cpu: 62.5 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 2314 libs: 557 tools: pamac,yay
pm: rpm pkgs: 0 pm: flatpak pkgs: 0
1: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
2: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
3: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
4: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
5: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
6: https://manjaro.ynh.ovh/stable/$repo/$arch
7: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
8: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
No active dnf repos in: /etc/dnf/dnf.conf
Processes:
CPU top: 5 of 556
1: cpu: 100% command: ps pid: 330604 mem: 3.97 MiB (0.0%)
2: cpu: 57.4% command: telegram-desktop pid: 1629 mem: 752.2 MiB (1.1%)
3: cpu: 33.5% command: plasma-systemmonitor pid: 1628
mem: 289.9 MiB (0.4%)
4: cpu: 28.0% command: konsole pid: 330554 mem: 235.7 MiB (0.3%)
5: cpu: 23.3% command: java pid: 18188 mem: 8331.9 MiB (13.0%)
Memory top: 5 of 556
1: mem: 8331.9 MiB (13.0%) command: java pid: 18188 cpu: 23.3%
2: mem: 6184.1 MiB (9.6%) command: java pid: 19036 cpu: 9.8%
3: mem: 1114.2 MiB (1.7%) command: plasmashell pid: 1266 cpu: 2.3%
4: mem: 962.3 MiB (1.5%) command: exe pid: 3117 cpu: 10.8%
5: mem: 855.1 MiB (1.3%) command: firefox pid: 1569 cpu: 4.9%
Processes: 556 Power: uptime: 18h 38m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.97 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 19.1.7 gcc: 15.1.1 Shell: Bash v: 5.2.37
running-in: konsole inxi: 3.3.38
[fabian@nova ~]$ mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-linux 2024.05.06 true PCI
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-prime 2025.01.13 false PCI
[fabian@nova ~]$ mhwd-kernel -li
Currently running: 6.12.28-1-MANJARO (linux612)
* linux612
* linux66
[fabian@nova ~]$ lsb_release -sirc
ManjaroLinux 25.0.3 Zetar
[fabian@nova ~]$ yay -Q | grep -e nvidia -e kde
kde-builder-git r468.c104915-1
kde-cli-tools 6.3.5-1
kde-gtk-config 6.3.5-1
kdeclarative 6.14.0-1
kdeclarative5 5.116.0-1
kdeconnect 25.04.1-1
kdecoration 6.3.5-1
kded 6.14.0-1
kded5 5.116.0-1
kdegraphics-mobipocket 25.04.1-1
kdegraphics-thumbnailers 25.04.1-1
kdelibs4support 5.116.0-2
kdenetwork-filesharing 25.04.1-1
kdenlive 25.04.1-1
kdeplasma-addons 6.3.5-1
kdesignerplugin 5.116.0-2
kdesu 6.14.0-1
kdesu5 5.116.0-1
lib32-nvidia-utils 570.144-1
libblockdev 3.3.0-1
libblockdev-crypto 3.3.0-1
libblockdev-fs 3.3.0-1
libblockdev-loop 3.3.0-1
libblockdev-mdraid 3.3.0-1
libblockdev-nvme 3.3.0-1
libblockdev-part 3.3.0-1
libblockdev-swap 3.3.0-1
libkdegames 25.04.1-1
linux612-nvidia 570.144-8
linux66-nvidia 570.144-5
manjaro-kde-settings 20241119-1
mhwd-nvidia 570.144-3
mhwd-nvidia-390xx 390.157-20
mhwd-nvidia-470xx 470.256.02-12
nvidia-driver-assistant 0.21.51.03-1
nvidia-prime 1.0-5
nvidia-settings 570.144-3
nvidia-utils 570.144-3
polkit-kde-agent 6.3.5-1
qt5-base 5.15.16+kde+r131-1
qt5-declarative 5.15.16+kde+r22-3
qt5-imageformats 5.15.16+kde+r2-3
qt5-location 5.15.16+kde+r7-4
qt5-multimedia 5.15.16+kde+r2-3
qt5-quickcontrols2 5.15.16+kde+r5-3
qt5-speech 5.15.16+kde+r1-3
qt5-svg 5.15.16+kde+r5-3
qt5-tools 5.15.16+kde+r3-6
qt5-wayland 5.15.16+kde+r60-1
qt5-webchannel 5.15.16+kde+r3-3
qt5-websockets 5.15.16+kde+r2-3
xdg-desktop-portal-kde 6.3.5-1
[fabian@nova ~]$ ddcutil detect
(set_connector_for_businfo_using_edid) Failed to find connector name for /dev/i2c-18 using EDID 0x5e1d0d3e7bc4
Failed to find connector name for /dev/i2c-18, set_connector_for_businfo_using_edid at line 1236 in file i2c_bus_core.c.
I2C_Bus_Info at: 0x5e1d0d3be3b0
Flags: I2C_BUS_EXISTS | I2C_BUS_ACCESSIBLE | I2C_BUS_PROBED | I2C_BUS_X50_EDID
Bus /dev/i2c-18 found: true
Bus /dev/i2c-18 probed: true
errno for open: OK(0): success
drm_connector_found_by: DRM_CONNECTOR_NOT_CHECKED (0)
last_checked_asleep: false
Display connectors reported by /sys:
Connector: card0-HDMI-A-3
i2c_busno: -1
connector_id: 111
enabled: disabled
status: disconnected
edid: None
Connector: card0-DP-3
i2c_busno: -1
connector_id: 103
enabled: disabled
edid: None
Connector: card0-DP-4
i2c_busno: -1
connector_id: 107
enabled: disabled
edid: None
Connector: card0-eDP-2
i2c_busno: -1
connector_id: 114
enabled: disabled
edid: None
Connector: card1-HDMI-A-1
i2c_busno: 3
connector_id: 262
enabled: disabled
edid: None
Connector: card1-HDMI-A-2
i2c_busno: 5
connector_id: 276
enabled: disabled
edid: None
Connector: card1-DP-1
i2c_busno: 10
connector_id: 250
enabled: disabled
edid: None
Connector: card1-DP-2
i2c_busno: 11
connector_id: 268
enabled: disabled
edid: None
Connector: card1-eDP-1
i2c_busno: 9
connector_id: 241
enabled: enabled
status: connected
edid:
+0 +4 +8 +c 0 4 8 c
+0000 00 ff ff ff ff ff ff 00 09 e5 9d 09 00 00 00 00 ................
+0010 27 1e 01 04 a5 26 15 78 03 0f 95 ae 52 43 b0 26 '....&.x....RC.&
+0020 0f 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01 .PT.............
+0030 01 01 01 01 01 01 09 64 00 b0 a0 a0 78 50 30 20 .......d....xP0
+0040 36 00 7d d6 10 00 00 18 00 00 00 fd 0c 30 a5 02 6.}..........0..
+0050 02 46 01 0a 20 20 20 20 20 20 00 00 00 fe 00 42 .F.. .....B
+0060 4f 45 20 43 51 0a 20 20 20 20 20 20 00 00 00 fe OE CQ. ....
+0070 00 4e 45 31 37 33 51 48 4d 2d 4e 59 33 0a 01 be .NE173QHM-NY3...
+0080 70 13 79 00 00 03 01 14 19 13 01 84 ff 09 af 00 p.y.............
+0090 2f 00 1f 00 9f 05 77 00 02 00 05 00 00 00 00 00 /.....w.........
+00a0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
+00b0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
+00c0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
+00d0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
+00e0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
+00f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 84 90 ................
Invalid display
I2C bus: /dev/i2c-9
DRM connector: card1-eDP-1
EDID synopsis:
Mfg id: BOE - BOE
Model:
Product code: 2461 (0x099d)
Serial number:
Binary serial number: 0 (0x00000000)
Manufacture year: 2020, Week: 39
This is a laptop display. Laptop displays do not support DDC/CI.
Display 1
I2C bus: /dev/i2c-18
EDID synopsis:
Mfg id: VSC - ViewSonic Corporation
Model: XG2705-2K
Product code: 55098 (0xd73a)
Serial number: WBJ221000006
Binary serial number: 16843009 (0x01010101)
Manufacture year: 2022, Week: 10
VCP version: 2.2
