Hi there,
I am basically trying to get my external microphone to work with KDE but it doesn’t seem to be recognised with KDE
I have an Intel laptop with 8th gen i5. When I conect my microphone to the headphone/mic combo port it detects a headphoe but no mic. This an external mic only. I am unsure what to do. Oh and yes I have set the mode to Analogue stero duplex.
Also this is the output of pacmd list cards
Memory blocks currently allocated: 142, size: 1.2 MiB.
Memory blocks allocated during the whole lifetime: 3345590, size: 188.5 MiB.
Memory blocks imported from other processes: 128, size: 1.0 MiB.
Memory blocks exported to other processes: 0, size: 0 B.
Total sample cache size: 11.5 KiB.
Default sample spec: s16le 2ch 44100Hz
Default channel map: front-left,front-right
Default sink name: alsa_output.pci-0000_00_1f.3.hdmi-stereo.equalizer
Default source name: alsa_output.pci-0000_00_1f.3.analog-stereo.monitor
Memory blocks of type POOL: 14 allocated/1785224 accumulated.
Memory blocks of type POOL_EXTERNAL: 0 allocated/0 accumulated.
Memory blocks of type APPENDED: 0 allocated/0 accumulated.
Memory blocks of type USER: 0 allocated/0 accumulated.
Memory blocks of type FIXED: 0 allocated/1191672 accumulated.
Memory blocks of type IMPORTED: 128 allocated/368694 accumulated.
29 module(s) loaded.
index: 0
argument: <>
used: -1
load once: yes
properties:
module.author = "Lennart Poettering"
module.description = "Automatically restore the volume/mute state of devices"
module.version = "13.0"
index: 1
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore the volume/mute/device state of streams"
index: 2
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore profile of cards"
index: 3
argument: <>
used: -1
load once: yes
properties:
module.description = "Augment the property sets of streams with additional static information"
index: 4
argument: <>
used: -1
load once: yes
properties:
module.author = "David Henningsson"
module.description = "Switches ports and profiles when devices are plugged/unplugged"
index: 5
argument: <>
used: -1
load once: yes
properties:
module.description = "Detect available audio hardware and load matching drivers"
index: 6
argument: <device_id="0" name="pci-0000_00_1f.3" card_name="alsa_card.pci-0000_00_1f.3" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1">
used: 1
load once: no
properties:
module.description = "ALSA Card"
index: 7
argument: <channels=2>
used: -1
load once: yes
properties:
module.description = "Adds JACK sink/source ports when JACK is started"
index: 8
argument: <>
used: -1
load once: yes
properties:
module.author = "Frédéric Dalleau, Pali Rohár"
module.description = "Policy module to make using bluetooth devices out-of-the-box easier"
index: 9
argument: <>
used: -1
load once: yes
properties:
module.author = "João Paulo Rechi Vita"
module.description = "Detect available Bluetooth daemon and load the corresponding discovery module"
index: 10
argument: <>
used: -1
load once: yes
properties:
module.description = "Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers"
index: 11
argument: <>
used: -1
load once: yes
properties:
module.author = "Tanu Kaskinen"
module.description = "D-Bus interface"
index: 12
argument: <>
used: -1
load once: no
properties:
module.description = "Native protocol (UNIX sockets)"
index: 13
argument: <>
used: -1
load once: yes
properties:
module.author = "Sylvain Baubeau"
module.description = "GSettings Adapter"
index: 14
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore the default sink and source"
index: 15
argument: <>
used: -1
load once: yes
properties:
module.description = "When a sink/source is removed, try to move its streams to the default sink/source"
index: 16
argument: <>
used: -1
load once: yes
properties:
module.author = "Colin Guthrie"
module.description = "Always keeps at least one sink loaded even if it's a null one"
index: 17
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically set device of streams based on intended roles of devices"
index: 18
argument: <>
used: -1
load once: yes
properties:
module.description = "When a sink/source is idle for too long, suspend it"
index: 19
argument: <>
used: -1
load once: yes
properties:
module.description = "Create a client for each ConsoleKit session of this user"
index: 20
argument: <>
used: -1
load once: yes
properties:
module.description = "Create a client for each login session of this user"
index: 21
argument: <>
used: -1
load once: yes
properties:
module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
index: 22
argument: <>
used: -1
load once: yes
properties:
module.description = "Mute & cork streams with certain roles while others exist"
index: 23
argument: <>
used: -1
load once: yes
properties:
module.description = "Detect when various filters are desirable"
index: 24
argument: <>
used: -1
load once: yes
properties:
module.description = "Load filter sinks automatically when needed"
index: 27
argument: <display=:0>
used: -1
load once: no
properties:
module.description = "X11 credential publisher"
index: 28
argument: <display=:0 session_manager=local/rodude123s-pavilion-x360:@/tmp/.ICE-unix/2066,unix/rodude123s-pavilion-x360:/tmp/.ICE-unix/2066>
used: -1
load once: no
properties:
module.description = "X11 session management"
index: 31
argument: <>
used: 1
load once: no
properties:
module.author = "Jason Newton"
module.description = "General Purpose Equalizer"
index: 37
argument: <>
used: -1
load once: no
properties:
module.description = "Command line interface protocol (UNIX sockets)"
2 sink(s) available.
* index: 5
driver: <module-equalizer-sink.c>
flags: HW_MUTE_CTRL LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 1000
volume: front-left: 45080 / 69%, front-right: 45080 / 69%
balance 0.00
base volume: 65536 / 100%
volume steps: 65537
muted: no
current latency: 0.00 ms
max request: 0 KiB
max rewind: 0 KiB
monitor source: 5
sample spec: float32le 2ch 44100Hz
Stereo
used by: 0
linked by: 1
configured latency: 0.00 ms; range is 0.50 .. 1837.50 ms
module: 31
properties:
device.master_device = "alsa_output.pci-0000_00_1f.3.hdmi-stereo"
device.class = "filter"
device.description = "FFT based equalizer on Built-in Audio Analog Stereo"
device.icon_name = "audio-card"
index: 11
driver: <module-alsa-card.c>
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9039
volume: front-left: 45080 / 69% / -9.75 dB, front-right: 45080 / 69% / -9.75 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
max request: 0 KiB
max rewind: 0 KiB
monitor source: 11
sample spec: s16le 2ch 48000Hz
Stereo
used by: 0
linked by: 1
card: 0 <alsa_card.pci-0000_00_1f.3>
module: 6
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC295 Analog"
alsa.id = "ALC295 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xb1228000 irq 141"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "9d71"
device.product.name = "Sunrise Point-LP HD Audio"
device.string = "front:0"
device.buffering.buffer_size = "352800"
device.buffering.fragment_size = "176400"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Built-in Audio Analog Stereo"
alsa.mixer_name = "Realtek ALC295"
alsa.components = "HDA:10ec0295,103c83c4,00100002 HDA:8086280b,80860101,00100000"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
ports:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
active port: <analog-output-speaker>
3 source(s) available.
index: 5
flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 1000
volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 0
linked by: 0
monitor_of: 5
module: 31
properties:
device.description = "Monitor Source of FFT based equalizer on Built-in Audio Analog Stereo"
device.class = "monitor"
* index: 11
state: SUSPENDED
suspend cause: IDLE
priority: 1030
volume: front-left: 60944 / 93% / -1.89 dB, front-right: 60944 / 93% / -1.89 dB
balance 0.00
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 0
linked by: 0
monitor_of: 11
module: 6
properties:
device.description = "Monitor of Built-in Audio Analog Stereo"
alsa.card = "0"
device.bus = "pci"
device.string = "0"
index: 12
state: SUSPENDED
suspend cause: IDLE
priority: 9039
volume: front-left: 30421 / 46% / -20.00 dB, front-right: 30421 / 46% / -20.00 dB
balance 0.00
base volume: 6554 / 10% / -60.00 dB
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 0
linked by: 0
configured latency: 0.00 ms; range is 0.50 .. 2000.00 ms
module: 6
properties:
device.api = "alsa"
alsa.device = "0"
alsa.card = "0"
device.bus = "pci"
ports:
analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
properties:
analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: no)
properties:
active port: <analog-input-mic>
14 client(s) logged in.
index: 0
driver: <module-systemd-login.c>
owner module: 20
properties:
application.name = "Login Session 2"
systemd-login.session = "2"
index: 3
driver: <module-x11-xsmp.c>
owner module: 28
properties:
application.name = "XSMP Session on KDE as 1024b25f1cf1e0000160223992400000020660004"
xsmp.vendor = "KDE"
xsmp.client.id = "1024b25f1cf1e0000160223992400000020660004"
index: 7
driver: <protocol-native.c>
owner module: 12
properties:
application.name = "QPulse"
native-protocol.peer = "UNIX socket client"
native-protocol.version = "33"
application.process.id = "2084"
application.process.user = "rodude123"
application.process.host = "rodude123s-pavilion-x360"
application.process.binary = "plasmashell"
application.language = "en_GB.UTF-8"
window.x11.display = ":0"
application.process.machine_id = "851ef20a2d834816bdea4756f2b9614b"
application.process.session_id = "2"
index: 8
owner module: 12
properties:
application.name = "Chrome input"
application.process.id = "2332"
application.process.binary = "teams"
application.icon_name = "teams"
index: 11
owner module: 12
properties:
application.process.id = "3122"
application.process.binary = "kdeconnectd"
index: 12
owner module: 12
properties:
application.name = "Skype"
application.process.id = "3643"
index: 14
owner module: 12
properties:
application.process.id = "4714"
application.process.binary = "ckb-next"
application.icon_name = "ckb-next"
index: 16
owner module: 12
properties:
application.name = "libcanberra"
application.version = "0.30"
application.id = "org.freedesktop.libcanberra"
index: 24
owner module: 12
properties:
application.process.id = "2109"
application.process.binary = "latte-dock"
index: 28
owner module: 12
properties:
application.name = "Spotify"
application.process.id = "12467"
application.process.binary = "spotify"
application.icon_name = "spotify-client"
index: 32
driver: <module-dbus-protocol.c>
owner module: 11
properties:
application.name = "D-Bus client"
index: 39
owner module: 12
properties:
application.name = "Firefox"
window.x11.screen = "0"
application.process.id = "40848"
application.process.binary = "firefox"
application.icon_name = "firefox"
index: 41
owner module: 12
properties:
index: 52
driver: <cli.c>
owner module: 37
properties:
application.name = "UNIX socket client"
1 card(s) available.
index: 0
owner module: 6
properties:
alsa.card = "0"
device.bus = "pci"
device.string = "0"
device.description = "Built-in Audio"
profiles:
input:analog-stereo: Analog Stereo Input (priority 65, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 6500, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6565, available: unknown)
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: unknown)
output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (priority 5965, available: unknown)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
output:hdmi-stereo-extra3+input:analog-stereo: Digital Stereo (HDMI 4) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround-extra3+input:analog-stereo: Digital Surround 5.1 (HDMI 4) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround71-extra3+input:analog-stereo: Digital Surround 7.1 (HDMI 4) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (priority 5700, available: no)
output:hdmi-stereo-extra4+input:analog-stereo: Digital Stereo (HDMI 5) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround-extra4+input:analog-stereo: Digital Surround 5.1 (HDMI 5) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround71-extra4+input:analog-stereo: Digital Surround 7.1 (HDMI 5) Output + Analog Stereo Input (priority 665, available: no)
off: Off (priority 0, available: unknown)
active profile: <output:analog-stereo+input:analog-stereo>
sinks:
alsa_output.pci-0000_00_1f.3.analog-stereo/#11: Built-in Audio Analog Stereo
sources:
alsa_output.pci-0000_00_1f.3.analog-stereo.monitor/#11: Monitor of Built-in Audio Analog Stereo
alsa_input.pci-0000_00_1f.3.analog-stereo/#12: Built-in Audio Analog Stereo
ports:
properties:
properties:
properties:
properties:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: yes)
properties:
device.product.name = "VX2410 SERIES"
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
properties:
2 sink input(s) available.
index: 12
flags: START_CORKED
state: CORKED
sink: 11 <alsa_output.pci-0000_00_1f.3.analog-stereo>
balance 0.00
muted: no
requested latency: 980.00 ms
Stereo
resample method: speex-float-1
module: 31
properties:
media.name = "Equalized Stream"
media.role = "filter"
module-stream-restore.id = "sink-input-by-media-role:filter"
index: 14
flags: START_CORKED
state: CORKED
sink: 5 <alsa_output.pci-0000_00_1f.3.hdmi-stereo.equalizer>
volume: front-left: 65535 / 100% / -0.00 dB, front-right: 65535 / 100% / -0.00 dB
balance 0.00
muted: no
current latency: 2931.59 ms
Stereo
resample method: (null)
module: 12
client: 28 <Spotify>
properties:
media.role = "music"
media.name = "Spotify"
module-stream-restore.id = "sink-input-by-media-role:music"
0 source output(s) available.
1 cache entrie(s) available.
index: 0
Stereo
length: 11776
duration: 0.1 s
volume: n/a
balance 0.00
lazy: no
filename: <n/a>
properties:
media.role = "event"
event.id = "audio-volume-change"
event.description = "Volume Control Feedback Sound"
media.name = "audio-volume-change"
media.filename = "/usr/share/sounds/freedesktop/stereo/audio-volume-change.oga"
Thanks,
rodude123
